    InputShaping Plugin shows only zeros with Toolboard 1lc
    Plugins for DWC and DSF
    2.2k
    • Heartleander81undefined
      Heartleander81 @mfs12
      @mfs12 20_2021-10-08_12.32.09.csv
      Heartleander81undefined mfs12undefined 2 Replies Last reply Reply Quote 1
        Heartleander81 @Heartleander81
        ACC from duet
        IS Plugin
        Sorry for the Bad Picture Quality
        • mfs12undefined
          mfs12 @Heartleander81
          @heartleander81, @dc42,
          The plugin behaves here correctly as the file reports a sample rate of zero. This is why only zeros are displayed. I am not sure why RRF reports a sample rate of zero despite recording all those samples.
          From https://forum.duet3d.com/assets/uploads/files/1633689320062-20_2021-10-08_12.32.09.csv:
          998,-0.031,-0.125,1.039
          999,-0.031,-0.125,1.039
          Rate 0, overflows 0
          Visit me on github at https://github.com/mfs12/
            dc42 administrators @Heartleander81
            @heartleander81 did you resolve this issue, or are you still getting only zeros along the bottom of the plot?
            Heartleander81undefined 1 Reply Last reply Reply Quote 0
              Heartleander81 @dc42
              @dc42 There are still zeros displayed. Unfortunately.
              • mfs12undefined
                mfs12
                Another user reported a similar issue.
                https://forum.duet3d.com/topic/25745/input-shaping/
                  @mfs12 I have See it, thanks. 😀
                  • mfs12undefined mfs12 marked this topic as a question
                    Heartleander81
                    Good Morning.
                    I have now updated to 3.4 Beta 6 and Pre 7.
                    Unfortunately the problem that the frequencies are not displayed is still there.
                      @heartleander81 please can you attach the latest .csv file that was generated when you ran the IS plugin.
                      • mfs12undefined
                        mfs12
                        @Heartleander81, i added now an option in the "record tab" to not delete the generated files by the IS plugin.
                          Heartleander81
                          is-393cb560-none-X-0.csv
                            @mfs12 When I look at the IS file in the Duet accelerometer, it shows frequencies.
                            • mfs12undefined
                              mfs12
                              for some reason your device report a rate of 0. which is strange and causing the problems.
                                @mfs12 OK. What could be the trigger for this?
                                Is there a way to do tests to find out what might be the cause?
                                dc42undefined 2 Replies Last reply Reply Quote 0
                                  @heartleander81 I am still trying to work out how this could happen.
                                    dc42 administrators @dc42
                                    @Heartleander81 I've managed to reproduce this by disconnecting the interrupt signal from the accelerometer. So I think your board has a hardware fault. Which revision of tool board is it? If it is a rev. 1.1 board, does it have a diode soldered on the underside in one corner of the board?
                                      @heartleander81 I've added a test of the interrupt line in the firmware:
                                      • Please install the tool board firmware from https://www.dropbox.com/sh/wtgcvkuaq52x3aq/AAADVEzSwypcIZSwExX0M4RQa?dl=0 on your tool board. It is compatible with 3.4.0beta6 main board firmware.
                                      • When that's done, send this command to attempt data collection: M956 S1000 A0
                                      • If that command reports failure, run M122 B20 to get the tool board diagnostics.
                                        M956 S1000 A0
                                        Error: M956: missing parameter 'P'
                                        M956 P20.0 S1000 A0
                                        Error: M956: Failed to start accelerometer data collection
                                        M122 B20
                                        Diagnostics for board 20: Duet TOOL1LC rev 1.1 or later firmware version 3.4.0beta6+1 (2021-11-09 14:39:48)
                                        Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1)
                                        Never used RAM 2628, free system stack 2788 words
                                        Tasks: Move(notifyWait,0.0%,153) HEAT(notifyWait,0.2%,115) CanAsync(notifyWait,0.0%,64) CanRecv(notifyWait,0.0%,77) CanClock(notifyWait,0.0%,64) ACCEL(notifyWait,0.0%,27) TMC(notifyWait,3.0%,57)
                                        MAIN(running,91.9%,350) IDLE(ready,0.0%,27) AIN(delaying,5.0%,142), total 100.0%
                                        Last reset 00:05:21 ago, cause: software
                                        Last software reset data not available
                                        Driver 0: pos 0, 701.5 steps/mm,standstill, SG min 0, read errors 0, write errors 1, ifcnt 23, reads 29639, writes 11, timeouts 0, DMA errors 0, steps req 0 done 0
                                        Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
                                        Peak sync jitter 1/5, peak Rx sync delay 584, resyncs 0/1, no step interrupt scheduled
                                        VIN voltage: min 25.4, current 25.4, max 25.4
                                        MCU temperature: min 31.6C, current 40.8C, max 40.8C
                                        Last sensors broadcast 0x00000002 found 1 229 ticks ago, 0 ordering errs, loop time 0
                                        CAN messages queued 6248, send timeouts 0, received 2891, lost 0, free buffers 37, min 37, error reg 110000
                                        dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0
                                        Accelerometer: LIS3DH, status: 00, INT1 error!
                                        I2C bus errors 0, naks 3, other errors 0
                                        The Rest must I look in 1h when my Child is sleep
                                          @heartleander81 thanks, that shows that the INT1 signal on your board is not connected. Please email warranty@duet3d.com. Although if you have a v1.1 board and a soldering iron, you might want to check visually the soldering of that diode first.
                                            Ypu mean this ? I can test to soldering
