    FILAMENT_RUNOUT_DISTANCE_MM or similar at reprap?
    Firmware wishlist
    1.6k
    • OwenDundefined
      OwenD
      Just confirming that this is now possible with 3.4.0b7
      Albeit you must be aware that the macro called is now filament_error.g, not filament-error.g
      i.e. must have an underscore "_" and not a hyphen "-"
      There is also a problem if filament_error.g contains an M291 as described here
      filament_error.g
      ;0:/sys/filament_error.g
      ;run when a filament sensor error is detected.  Print will be paused bt Daemon.g after runout distance.
      var runoutDistance = 350 ; this is just so you can change easily
      ; first check that we are not currently in an error state and the switch has been toggled again.
      if (global.filamentDistance !=0) || !(state.status = "processing")
      	echo "Filament sensor triggered, but already no print in progress.  No action taken"
      	M99 ; exit macro
      echo "filament_error.g run"
      G4 P10 ; delay 10ms to debounce
      if sensors.filamentMonitors[0].status="ok"
      	echo "switch bounce detected - error cancelled"
      	M99 ; break out if sensor value is zero again (bouncing)
      echo {"Filament error type " ^ param.P ^ " detected on extruder " ^ param.D}
      ;M291 R"Filament Error" P{"Filament error type " ^ param.P ^ " detected on extruder " ^ param.D} S1 T3
      var thisExtruderValue = move.extruders[tools[state.currentTool].filamentExtruder].position
      set global.filamentDistance = var.thisExtruderValue + var.runoutDistance
      echo "filament_error.g run - print will be paused after " ^ var.runoutDistance ^ "mm"
      In daemon.g
      (Note this is run in a while loop so it's called at intervals less than 10 seconds)
      while true
      	; I have a bunch of other stuff in here
      	;check the filament runout
      	if state.currentTool != -1
      		if (move.extruders[tools[state.currentTool].filamentExtruder].position > global.filamentDistance)  &&  (global.filamentDistance !=0) && (state.status = "processing")
      			echo "paused called from daemon - filament runout"
      			M25 ; pause print if filament has run out
      	G4 S2 ; add a delay for these checks
      In resume.g we reset the distance
      	set global.filamentDistance = 0 ; reset filament sensor extrusion distance
      ;do all the other stuff needed for resuming
      You also need to set the distance to zero in start.g
      else
      	abort "Filament sensor shows no filament loaded.  Print aborted"
      and of course define the global in config.g
      if !exists(global.filamentDistance)
      	global filamentDistance = 0 ; global for use to allow filament to feed for set distance after sensor trips
      else
      apakundefined 1 Reply Last reply Reply Quote 2
      • apakundefined
        apak @OwenD
        thanks, will try
        MrTwinkysundefined 1 Reply Last reply Reply Quote 0
        • apakundefined
          apak
          This post is deleted!
          • MrTwinkysundefined
            MrTwinkys @apak
            @apak any word on whether or not this is functioning correctly? I would like to set this up for a reverse Bowden setup also.
            • selva_tviundefined selva_tvi referenced this topic
