    SSD Files
    171
    • Hayden1993
      Hayden1993 last edited by
      I'm in the process of setting up my cnc machine using the duet3, I had to format the sd card as it wouldn't read it.. Can anyone supply me with the latest files to copy over please?
      Any help would be much appreciated
      droftarts o_lampe 2 Replies Last reply Reply Quote 0
      • droftarts
        droftarts administrators @Hayden1993 last edited by
        @hayden1993 See https://duet3d.dozuki.com/Wiki/SD_Card#Section_Creating_the_file_structure
        While the configuration tool doesn't create a CNC machine very well, just create a basic config and then edit it later. See https://duet3d.dozuki.com/Wiki/Configuring_RepRapFirmware_for_a_CNC_machine
        • o_lampe
          o_lampe @Hayden1993 last edited by
          @hayden1993 said in SSD Files:
          Did you know it needs a specific formatter tool for SD-cards? I don't know where I found mine, but it's called SD card-formatter from Tuxera
          Hayden1993 1 Reply Last reply Reply Quote 0
          • Hayden1993
            Hayden1993 @o_lampe last edited by
            @o_lampe
            Thanks, I think this is where I'm going wrong as it was still showing files on it afterward.
            Thank you
            • droftarts
              @hayden1993 on the same page I linked earlier https://duet3d.dozuki.com/Wiki/SD_Card#Section_Formatting
              • Hayden1993
                Hayden1993 @droftarts last edited by
                @droftarts
                Thank you!
                With regards to creating the new image, I haven't got a clue on the settings I need, is there a default/standard image/SSD file I can download that would have come with my version of duet3?
                Hayden
                • droftarts
                  @hayden1993 use the configuration tool defaults but select your board and firmware version on the second page. It will probably force you to chose some endstops and heaters (delete the heaters as you’re configuring a CNC), then create the configuration set. You’ll get a zip file. Decompress this and copy the sys and www folders to the SD card. Follow the ‘getting connected’ guide to set up networking.
                  There is an SD card image, but it is big as it has the setup for Raspberry Pi on it too, and you’re going to have to go through the config stage anyway.
                  • Hayden1993
                    @droftarts
                    Okay thank you, I'll try and get it done this afternoon and hopefully see some movement.
                    • droftarts
                      @hayden1993 well, for movement, you WILL need to know some configuration values for your motors. There is a page on the configuration tool to set motor max speed, acceleration and stepper driver current. Find these out and put them in. Use conservative values to start with.
                      • JADoglio
                        JADoglio last edited by
                        You should find more than you need here.
                        e45aa0ed-165b-4915-a504-a7ec7cb06236-image.png https://betrue3d.dk/rpi-and-duet-3-why-and-how/
                        https://github.com/Duet3D/DuetSoftwareFramework/wiki/SBC-Setup-Guide
                        https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3
                        • Hayden1993
                          I didn't get chance to play around with the duet3 yesterday but I formatted the SD card using the mentioned program and get generated a new copy to transfer to my SD card (As below) does this look right? So now its a case of putting the SD card in and connecting to it?
                          Thanks
                          droftarts 1 Reply Last reply Reply Quote 1
                          • droftarts
                            @hayden1993 assuming that the contents of the folders is correct. There’s an example at the end of this section https://duet3d.dozuki.com/Wiki/SD_Card#Section_Creating_the_file_structure
