    intermittent SD card read fail
    • Fireflynj
      Fireflynj last edited by
      have a D300vs that came with a Duet WiFi 1.0, sometimes when try to start a print I get a message that it cannot read the SD card, I power cycle the machine and then it is fine and seems to print projects fine once I start them.
      what procedure should I do to determine the issue.
      SIam droftarts 2 Replies Last reply Reply Quote 0
      • SIam
        SIam @Fireflynj last edited by
        @fireflynj the simplest way is to test a new SD-Card, to which you copy the data from the old SD-Card
        https://duet3d.dozuki.com/Wiki/SD_Card#Section_Formatting
        Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
        Duet WiFi 1.02 or later + DueX5
        RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
        Duet WiFi Server: 1.26
        Duet Web Control 3.4.0beta4 (2021-09-27)
        Fireflynj 1 Reply Last reply Reply Quote 0
        • droftarts
          droftarts administrators @Fireflynj last edited by
          @fireflynj see https://duet3d.dozuki.com/Wiki/SD_Card#Section_Troubleshooting_SD_Card_issues
          • Fireflynj
            Fireflynj @SIam last edited by
            @siam thank you for the reply
            so I got a brand new Sandisk Ultra 16gb, formatted as per instructions with SD card formatter.
            I still get a msg, exact msg is " Error 1 accessing SD card"
