    Advise on smart effector mount with orbital extruder
    • gorf26
      gorf26 last edited by
      Here is a few pic's of a mount i just made, and would like some advice of if it looks doable, i haven't connected or used the smart effector as of yet, but came up with this mount. to use the direct drive..
      I seem to have enough clearance for the rods and, the mount isn't hitting any of the solder pads..
      and i think it should still have enough flex to trigger probe, but not sure..?
      Any thoughts
      Gary
      • T3P3Tony
        T3P3Tony administrators @gorf26 last edited by
        @gorf26 there should be enough flex to trigger - and you can check by connecting up the VCC, GND and OUT lines and configuring it as a probe. then a tap should register a quick change in the z probe value reported by DWC.
        www.duet3d.com
        gorf26 1 Reply Last reply Reply Quote 0
        • gorf26
          gorf26 @T3P3Tony last edited by
          @t3p3tony
          I have my config setup for the piezo would that setup work for a test of will need to modify it..
          Thanks gary
