CONSTANT AJAX disconnect errors
307
54.8k
  • undefined
    Thanks. I can't see anything wrong in the M122 report. it's interesting that you have a a reconnection count of 1 indicating that the WiFi module became disconnected from the router and successfully connected again, even though you have a very high signal strength.
    • undefined
      KeeganB
      David,
      I think I have established a bit of a pattern in my situation. It seems that right at the beginning of every new print, it disconnects. Then sometime after that (I estimate between 15-30mins) it just reconnects itself and is fine from then until I start the next print.
      Artemis
      Rostock Max v2
      Orion
      • undefined
        I did a little investigation this morning, and I found that for homing moves (i.e. G1 S1 moves), the maximum step rate possible is many times lower than for ordinary moves. So a high microstepping value can cause MaxReps to get very high during a homing move even if the combination of M350 microstepping and M203 maximum speeds is OK for normal moves. So if your print files have a G28 homing command at the start, that could be why you get a disconnection at the start of a print. The workaround for this particular issue is to use slower homing moves.
        • undefined
          KeeganB
          I will try slower homing moves. I don't have a separate G28 at the start of my prints, but there is on inside of beg.g that runs (as G32) at the start of all prints.
          My micro stepping is 16x
          I should add though, that it doesn't necessarily disconnect during the homing move, sometimes it can be a few minutes into the print.
          Artemis
          Rostock Max v2
          Orion
          • undefined
            I would not expect you to have this problem with only x16 microstepping.
            • undefined
              Jarery
              Similar to KeeganB, my board is set to 16x micro stepping (with interpolation).
              I also do not have a G28 homing in any of my Gcode but as KeeganB states in my Bed command is a G28 at the start. After that the Gcode has no homing until finished.
              My disconnects happen early in a print but unlike KeeganB, mine has never reconnected on its own that I'm aware of.
              I have never seen the reconnect count above 0.
              Edit: mine don't always happen only near start of a print, just that they are a high chance at start. Mine also disconnects just sitting idle sometime.
              I'm about a week away from commissioning a second delta with another duet wifi, based on dc42's large Kossel build. So in a week or so I'll be able to tell if both boards exhibit the same behaviour in my wifi network or if its specific to the one board.
              • undefined
                lolorc
                Hi there.
                I also have the constant disconnections.
                the disconnections also happen when the printer is idle…
                I also have a tons of issue uploading g-code files through wifi. (when usb is plugged)
                • undefined
                  BlackTom
                  I have had the same kind of issue with 1.19.2, 1.19 is correct.
                  I had issues when I was running my bed compensation routine and I had it too when I was printing,
                  I always finish by being disconnected of the web interface when I print and I cannot reconnect to it.
                  The print continue without issue until it's done so it doesn't affect it
                  The only way to get back access to the web interface is by powering off / on the board,
                  • undefined
                    lolorc
                    @bloood3d:
                    same here.
                    • undefined
                      bot
                      What about when you do a "hard refresh" of the web page through the web browser? On chrome this is done by holding the CTRL key while clicking refresh. In the past, this has helped me get back into a web interface session.
                      *not actually a robot
                      • undefined
                        KeeganB
                        bot,
                        That hasn't worked for me. I have also tried loading the page on difference devices.
                        Artemis
                        Rostock Max v2
                        Orion
                        • undefined
                          RGN01
                          I'm commissioning my new Duet WiFi and have the same issue. I've tried it in two locations (both no more than 10 feet from the WiFi router) and with three clients (desktop PC, Android tablet and Android mobile phone all running Chrome). The desktop PC is best but it still drops the connection frequently - perhaps every 15 minutes - despite the printer not even being fully commissioned (the most it has done is home the towers and heatbed auto set up) and the PC is being used for browsing and email.
                          I hope that this is resolved as it is a bit concerning to someone new to the Duet (which I think is absolutely great!)
                          • undefined
                            Have you tried increasing the number of retries in the DWC settings?
                            • undefined
                              RGN01
                              Thanks, David.
                              I increased it to 5 earlier this evening and it seems to be OK so far on the desktop PC (about 90 minutes) - but the printer and PC are effectively idle.
                              It was set to one initially, is there a recommended larger setting, or is it trial and error?
                              I'll monitor this as I start adding and testing functionality to the printer - and report back.
                              • undefined
                                1 is rather low, I think 3 would be a better default.
                                • undefined
                                  KeeganB
                                  At this point I can confidently say mine fits the pattern I mentioned earlier. Every print it starts fine and after a few minutes it disconnects. After probably 30 mins or so, it reconnects without issue and stays connected until I start the next new print.
                                  David, I am considering downgrading to 1.19. Is there any reason not to?
                                  Artemis
                                  Rostock Max v2
                                  Orion
                                  • undefined
                                    Jarery
                                    Interesting yours reconnects. Mine never has, retries I've changed to 5, 10, to no effect.
                                    • undefined
                                      KeeganB
                                      Jarery,
                                      It may just be that the webpage is auto reloaded by the browser when I come back to the computer and pull it up.
                                      Artemis
                                      Rostock Max v2
                                      Orion
                                      • undefined
                                        RGN01
                                        Thanks, David. I've dropped it to 3 and am testing that. SO far, so good!
                                        • undefined
                                          snomon
                                          Hi guys, I'm having the same problem..Im trying to tell it to print something but it keeps giving me AJAX errors..ctrl+r a few times, i get in at some point. The print then keeps messing up and having me to reset it, not sure why
                                          2:55:56 AMM122
                                          Used output buffers: 3 of 32 (15 max)
                                          RepRapFirmware for Duet WiFi version 1.19.2 running on Duet WiFi 1.0
                                          Board ID: 08DDM-9FAM2-LW4SD-6J9F6-3S46N-12X7W
                                          Static ram used: 21176
                                          Dynamic ram used: 96104
                                          Recycled dynamic ram: 1504
                                          Stack ram used: 1304 current, 5920 maximum
                                          Never used ram: 6368
                                          Last reset 00:12:18 ago, cause: power up
                                          Last software reset reason: User, spinning module GCodes, available RAM 3136 bytes (slot 4)
                                          Software reset code 0x0003, HFSR 0x00000000, CFSR 0x00000000, ICSR 0x00400000, BFAR 0xe000ed38, SP 0xffffffff
                                          Error status: 0
                                          Free file entries: 10
                                          SD card longest block write time: 9.7ms
                                          MCU temperature: min 51.1, current 53.7, max 55.9
                                          Supply voltage: min 23.4, current 24.1, max 24.6, under voltage events: 0, over voltage events: 0
                                          Driver 0: stalled standstill
                                          Driver 1: stalled standstill
                                          Driver 2: stalled standstill
                                          Driver 3: standstill
                                          Driver 4: standstill
                                          Date/time: 2017-09-21 02:55:52
                                          Slowest main loop (seconds): 0.167053; fastest: 0.000034
                                          MaxReps: 6, StepErrors: 0, FreeDm: 240, MinFreeDm 234, MaxWait: 10780ms, Underruns: 0, 0
                                          Scheduled moves: 5, completed moves: 5
                                          Bed compensation in use: none
                                          Bed heater = 0, chamber heater = -1
                                          Heater 0 is on, I-accum = 0.0
                                          Heater 1 is on, I-accum = 0.3
                                          Segments left: 0
                                          Movement lock held by null
                                          http is idle in state(s) 0
                                          telnet is idle in state(s) 0
                                          file is idle in state(s) 0
                                          serial is idle in state(s) 0
                                          aux is idle in state(s) 0
                                          daemon is idle in state(s) 0
                                          queue is idle in state(s) 0
                                          Code queue is empty.
                                          Network state is running
                                          WiFi firmware version 1.19.2
                                          WiFi MAC address 60:01:94:34:40:06
                                          WiFi Vcc 3.14, reset reason Turned on by main processor
                                          WiFi flash size 4194304, free heap 36896
                                          WiFi IP address 192.168.20.81
                                          WiFi signal strength -57dBm
                                          Reconnections 0
                                          HTTP sessions: 1 of 8
                                          Socket states: 2 0 0 0 0 0 0 0
                                          Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                                          2:55:49 AMConnection established!
                                          2:55:24 AMDisconnected.
                                          2:55:16 AMConnection established!
                                          2:55:11 AMDisconnected.
                                          2:55:03 AMConnection established!
                                          2:55:01 AMDisconnected.
                                          2:54:53 AMConnection established!
                                          2:54:15 AMDisconnected.
                                          2:52:10 AMConnection established!
                                          2:46:32 AMDisconnected.
                                          2:43:49 AMConnection established!
                                          2:41:46 AMDisconnected.
                                          2:39:46 AMConnection established!
                                          2:38:11 AMDisconnected.
                                          2:33:01 AMConnection established!
                                          2:32:52 AMDisconnected.
                                          2:32:40 AMCalibrated 6 factors using 13 points, deviation before 0.028 after 0.014
                                          2:31:48 AMM32 Enclosure bracket v10(1).gcode
                                          File Enclosure bracket v10(1).gcode selected for printing
                                          2:30:54 AMM0 H1
                                          File Enclosure bracket v10(0).gcode print time was 0h 9m
                                          2:30:07 AMM25
                                          Printing paused
                                          2:25:29 AMConnection established!
                                          2:24:55 AMDisconnected.
                                          2:21:20 AMCalibrated 6 factors using 13 points, deviation before 0.091 after 0.024
                                          2:20:42 AMM32 Enclosure bracket v10(0).gcode
                                          File Enclosure bracket v10(0).gcode selected for printing
                                          2:20:14 AMM0 H1
                                          2:19:53 AMM25
                                          Printing paused
                                          2:11:17 AMCalibrated 6 factors using 13 points, deviation before 0.071 after 0.014
                                          2:10:35 AMM32 Enclosure bracket v10(0).gcode
                                          2:10:08 AMM122
                                          Used output buffers: 1 of 32 (14 max)
                                          Dynamic ram used: 96200
                                          Recycled dynamic ram: 1408
                                          Stack ram used: 4048 current, 9104 maximum
                                          Never used ram: 3184
                                          Last reset 00:31:37 ago, cause: power up
                                          Error status: 0
                                          MCU temperature: min 54.7, current 55.3, max 55.6
                                          Supply voltage: min 23.4, current 24.0, max 24.4, under voltage events: 0, over voltage events: 0
                                          Driver 0: standstill
                                          Date/time: 2017-09-21 02:10:06
                                          Slowest main loop (seconds): 0.176147; fastest: 0.000000
                                          MaxReps: 0, StepErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
                                          Scheduled moves: 0, completed moves: 0
                                          Bed probe heights: 0.245 0.225 0.020 -0.266 -0.374
                                          Heater 1 is on, I-accum = 0.5
                                          Segments left: 0
                                          http is ready with "M122" in state(s) 0
                                          WiFi flash size 4194304, free heap 32424
                                          Reconnections 0
                                          Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                                          2:10:00 AMM0 H1
                                          File Enclosure bracket v10.gcode print time was 0h 14m
                                          53 out of 307
