    CONSTANT AJAX disconnect errors
    307
    54.9k
    • Jareryundefined
      Jarery
      Currently I cannot connect at all anymore via web. Ive tried clearing cache, safari and chrome, rebooted the printer 3 times, cycled the wifi on/off.
      Consol says it connects to my network and lists assigned ip, but unable to connect.
      Edit : connected after about 20min of throwing things at it
      Via USB my M122 network is :
      Network state is running
      WiFi firmware version 1.19.2
      WiFi MAC address 5c:cf:7f:a4:a1:64
      WiFi Vcc 3.13, reset reason Turned on by main processor
      WiFi flash size 4194304, free heap 39944
      WiFi IP address 192.168.2.54
      WiFi signal strength -33dBm
      Reconnections 0
      HTTP sessions: 0 of 8
      Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
      • KeeganBundefined
        KeeganB
        Ok, after a few more nights of testing, I can confidently say the following:
        1. It will stay connected forever at idle.
        2. It seems to stay connected forever running G32 commands, and other manual control commands
        3. Within minutes of starting a new print, it disconnects. EVERY SINGLE TIME. The same AJAX error every time.
        4. After approximately 30-60 mins, it can be reconnected fine and will stay connected forever or until I start a new print.
        I am still on 1.19.2, but may downgrade as this is really annoying.
        Artemis
        Rostock Max v2
        Orion
          Is the "Error reason:" given in the Ajax disconnect message Timeout, or something else?
          • KeeganBundefined
            KeeganB
            @dc42:
            Sorry, I should have included that. Yes, I believe that is the error message. It’s the same message every time.
            Artemis
            Rostock Max v2
            Orion
            • Jareryundefined
              Jarery
              my Ajax error is the same, doesn't say what the cause is whether timeout or other.
              Just states "an AJAX error has been reported, so the current session has been terminated. Please check if your printer is still on and try to connect again "
              I also disconnect every print but mine do not reconnect.
              Edit:
              I'm just commissioning a second DuetWifi delta, it has :
              Firmware Version: 1.18.1 (2017-04-09)
              WiFi Server Version: 1.03 (ch fork)
              Web Interface Version: 1.15a
              And if I force a disconnect, the warning message has at the bottom "Reason: Timeout". This bottom line is not present at all in the 19.2 firmware disconnects issue. Cannot print yet so unable to tell if the issue is board related or wifi network.
              • Jareryundefined
                Jarery
                Comissioned my 2nd duet wifi printer.
                Board came with 1.18.1 firmware. No disconnects when printing. Although only did few prints, 10 min long or so.
                Upgraded to 1.19.2, disconnected a coulee min into my first print. Ajax error message again has no line on the bottom stating reason.
                So i have 2 new Duet wifi's, both disconnect from my Asus RT-AC3100 wifi network on every print.
                The chances its a "bad board" or slim as it happens on both boards.
                The chances its my network settings are low as Ive set everything to set channel, etc, and it works on 1.18 without disconnects.
                There is something in 1.19 that just makes it appear to timeout
                • KeeganBundefined
                  KeeganB
                  I've never downgraded a Duet. Is it the same process as the update from 1.18 to 1.19.2 was, but in reverse?
                  Artemis
                  Rostock Max v2
                  Orion
                    I really wish there was some way I could reproduce the problem you are experiencing. AFAIK you are the only user who finds 1.19.2 less reliable than 1.18.
                    Downgrading to 1.18 you will need to do a simultaneous install of both DuetWiFiFirmware and DuetWiFiServer. If the board was shipped with 1.19 firmware originally then you will also need to install DuetWiFiFirmware.bin on the WiFi module.
                    Then you will need to follow the connection instructions for 1.18 and earlier.
                    • lolorcundefined
                      lolorc
                      i also find 1.19.2 less reliable than 1.8 with regard to the wireless/ajax issue. (sorry I'm not really helping with the debugging at the moment, house for sell, can't use my printer as often as I wish)
                      • KeeganBundefined
                        KeeganB
                        Thanks David.
                        My board was shipped with 1.18.
                        I understand that network issues are near impossible to replicate. I wish there was more detailed log info or something I could get to you. I am able to force a reconnect via USB with M552 S-1/S1
                        The real frustration comes when doing calibration prints and etc. It disconnects so quickly I can't make any adjustments easily; baby stepping, extrusion, temp etc to do on-the-fly adjustments. That, and every time I want to start a new test print I have to go through the reconnect process every time.
                        I feel pretty confident my network is not the issue, but I have been toying with the idea of upgrading my router and other network equipment, so maybe I will do that now just in case. I've also considered taking on my my extra routers and setting up a clean dummy network to test.
                        David, is there any possible advantage in doing a "clean" install of 1.19.2. Meaning, could/should I format the SD card and do a completely clean install of everything, and then just paste in my config values as needed?
                        Artemis
                        Rostock Max v2
                        Orion
                        • Jareryundefined
                          Jarery
                          @KeeganB:
                          Thanks David.
                          My thoughts also.
                          I'm also not happy with 1.19 in regards to 1.18.
                          All the additions are awesome, and I always use volumetric extrusion and other features not in 1.18. But if i have no method of connecting to the system the features it has are a moot point.
                          • Dougal1957undefined
                            Dougal1957
                            I Did have an issue to start with which was almost instant disconnects I fitted an AP Extender and got round it but then when I moved the printer back to it rightful location the issue re-appeared turns out my WiFi AP Credentials for the original AP was corrupt deleting them and re-applying fixed the problem not saying it will fix you issues but may be worth a try?
                            FWIW I am using a netgear WiFi router (D6400)
                            • KeeganBundefined
                              KeeganB
                              Sorry Dougal,
                              I am not following what you are suggesting? Are you saying the credentials saved to the DUET for connecting to your AP were bad?
                              Artemis
                              Rostock Max v2
                              Orion
                                Dougal1957
                                yes indeed
                                • KeeganBundefined
                                  KeeganB
                                  Thanks, I will certainly try that. It won't hurt anything and if it resolves this issue, Ill be ecstatic!
                                  Artemis
                                  Rostock Max v2
                                  Orion
                                    Dougal1957
                                    Use the M588 to remove it from the list first before trying to re-instate it
                                    • KeeganBundefined
                                      KeeganB
                                      I didn't have much time last night, but I tested your idea Dougal. Nope 😞
                                      Artemis
                                      Rostock Max v2
                                      Orion
                                        Dougal1957
                                        I didn't think it would TBH your symptoms are different to what mine were but it was worth a try.
                                        • KeeganBundefined
                                          KeeganB
                                          Yeah, I wasn't holding much hope, but it was easy enough to give it a shot! Thanks
                                          Artemis
                                          Rostock Max v2
                                          Orion
                                          • TimVukmanundefined
                                            TimVukman
                                            Hi
                                            I am jumping in here too as I had written my own post on this issue between last night and today. I will collect some data based on the gcodes posted here that will provide the data. I have not been able to connect today because I upgraded to 1.20.7 and something must have gone wrong because now I can't get the Wifi to initialize.
                                            I can say that I never had the connection to the printer drop when I was running 1.18.2. That says the connection from the printer to the network and from the DWC to the printer both had enough signal strength. I will get the numbers if I can.
