    CONSTANT AJAX disconnect errors
    307
    54.8k
    • KeeganBundefined
      KeeganB
      Thanks David.
      My board was shipped with 1.18.
      I understand that network issues are near impossible to replicate. I wish there was more detailed log info or something I could get to you. I am able to force a reconnect via USB with M552 S-1/S1
      The real frustration comes when doing calibration prints and etc. It disconnects so quickly I can't make any adjustments easily; baby stepping, extrusion, temp etc to do on-the-fly adjustments. That, and every time I want to start a new test print I have to go through the reconnect process every time.
      I feel pretty confident my network is not the issue, but I have been toying with the idea of upgrading my router and other network equipment, so maybe I will do that now just in case. I've also considered taking on my my extra routers and setting up a clean dummy network to test.
      David, is there any possible advantage in doing a "clean" install of 1.19.2. Meaning, could/should I format the SD card and do a completely clean install of everything, and then just paste in my config values as needed?
      Artemis
      Rostock Max v2
      Orion
      • Jareryundefined
        Jarery
        @KeeganB:
        Thanks David.
        My thoughts also.
        I'm also not happy with 1.19 in regards to 1.18.
        All the additions are awesome, and I always use volumetric extrusion and other features not in 1.18. But if i have no method of connecting to the system the features it has are a moot point.
        • Dougal1957undefined
          Dougal1957
          I Did have an issue to start with which was almost instant disconnects I fitted an AP Extender and got round it but then when I moved the printer back to it rightful location the issue re-appeared turns out my WiFi AP Credentials for the original AP was corrupt deleting them and re-applying fixed the problem not saying it will fix you issues but may be worth a try?
          FWIW I am using a netgear WiFi router (D6400)
          • KeeganBundefined
            KeeganB
            Sorry Dougal,
            I am not following what you are suggesting? Are you saying the credentials saved to the DUET for connecting to your AP were bad?
            Artemis
            Rostock Max v2
            Orion
              Dougal1957
              yes indeed
              • KeeganBundefined
                KeeganB
                Thanks, I will certainly try that. It won't hurt anything and if it resolves this issue, Ill be ecstatic!
                Artemis
                Rostock Max v2
                Orion
                  Dougal1957
                  Use the M588 to remove it from the list first before trying to re-instate it
                  • KeeganBundefined
                    KeeganB
                    I didn't have much time last night, but I tested your idea Dougal. Nope 😞
                    Artemis
                    Rostock Max v2
                    Orion
                      Dougal1957
                      I didn't think it would TBH your symptoms are different to what mine were but it was worth a try.
                      • KeeganBundefined
                        KeeganB
                        Yeah, I wasn't holding much hope, but it was easy enough to give it a shot! Thanks
                        Artemis
                        Rostock Max v2
                        Orion
                        • TimVukmanundefined
                          TimVukman
                          Hi
                          I am jumping in here too as I had written my own post on this issue between last night and today. I will collect some data based on the gcodes posted here that will provide the data. I have not been able to connect today because I upgraded to 1.20.7 and something must have gone wrong because now I can't get the Wifi to initialize.
                          I can say that I never had the connection to the printer drop when I was running 1.18.2. That says the connection from the printer to the network and from the DWC to the printer both had enough signal strength. I will get the numbers if I can.
                            TimVukman
                            Hi
                            I am going to try to downgrade to 1.18.2 since that is when everything was working properly. I currently can't initialize the Wifi module. Any way to test if it is ok?
                              @TimVukman:
                              Hi
                              Did you follow the upgrade instructions at https://duet3d.com/wiki/Upgrading_to_DuetWiFiFirmware_1.19 ? In particular, the but about using M587 to enter your WIFI access point ssid and password.
                              • KeeganBundefined
                                KeeganB
                                Send M552 S-1
                                wait for it to complete
                                Send M552 S1
                                Try that?
                                Artemis
                                Rostock Max v2
                                Orion
                                  TimVukman
                                  Hi dc42
                                  Yes, to the letter.
                                  I'm stuck trying to downgrade back to 1.18.2
                                  Erased the board
                                  tried bossac with the drivers installed.
                                  listcomports returns COM5 - Escher 3D - USB\lots of characters
                                  bossac.exe –p=COM5 -e -w -v -b DuetWifiFirmware returns
                                  No board found on COM5
                                  Frustrated beyond belief
                                    Why do people insist on erasing the firmware, when it is almost never necessary?
                                      TimVukman
                                      Hi dc42
                                      To be very clear, I did not choose to erase my firmware and never would have.
                                      I am trying to recover from my firmware quitting on it's own. I was trying to setup the IR Probe. The board went from connecting reliably and functioning very nicely to not connecting at all and indicating USB errors.
                                      From there I followed the troubleshooting documentation on the Wiki.
                                      Suggesting that I chose to erase the firmware on my own is not going to help me set the board up so that I can use it.
                                      Perhaps the documentation should be revisited so that it is consistent, located in a single place with suggestions on what to look for to aid in understanding what has gone wrong and flow-charted with a path to follow.
                                      Even better would be a software tool that could be started on the board if not remotely (or set as the temporary boot path on the memory card) that could look at the board / firmware and tell the user if it was ok - ie don't erase me, I'm fine! Even a statement in the installation instructions to the effect of "Don't erase the firmware - it is almost never necessary" would help.
                                      In my other thread last night you indicated that there was a bug in windows that shut down the USB ports if they switched too quickly which would render them looking like they were gone.
                                      Maybe the troubleshooting documentation should have proposed a way to make sure that the ports were properly reset before it suggested the erase / reset course of action. Windows users would never find themselves coming across this bug in the normal usage of windows where USB connects are not frequently even disconnected or changed.
                                      There are a large number of posts on this forum indicating that people are experiencing issues with connections and the 1.19 release of firmware. If the process was functioning properly and properly documented, there would not be so many posts.
                                      The documentation states that the process implemented in this has changed, and upgrading needs to be handled carefully. That would be a good place to include some of the information and suggestions that have come to light - before people like me start troubleshooting the situation based on the physical evidence they are looking at.
                                      I am very understanding and I know well how things do not always go according to plan. I also know that there are frequently unforeseen issues that could not have been predicted that crop up and cause issues. I also would only post as a last resort, which in this case was too late.
                                      I appreciate your assistance and I wish to work through the issue to recover my board.
                                      I am moving slowly in my other thread and documenting everything that is happening, trusting that we will recover the board, so I will not be off trying things on my own that might make sense to me based on what I am seeing.
                                      Tim
                                        The process to recover a non-working board is documented at https://duet3d.com/wiki/What_to_do_if_your_Duet_or_Duet_WiFi_won%27t_respond. I've just added a couple of steps.
                                        HTH David
                                          TimVukman
                                          Hi David
                                          I was documenting my actions in my other thread. I did post to have one closed because they were converging into 1 issue which is the one you have addressed here.
                                          I appreciate the updated documentation and I will follow it to the letter and report back.
                                          Thanks
                                          Tim
                                            TimVukman
                                            "Check the voltage indication LEDs
                                            If you have a PanelDue, disconnect it from the Duet to reduce the load on the 5V supply. "
                                            Done
                                            "Then connect your Duet to a PC using the USB cable."
                                            Done
                                            "Do not apply VIN power to the Duet at this point."
                                            Ok, not powered on.
                                            "Check the LEDs on the Duet. There should be a red LED illuminated close to the USB connector."
                                            I have one illuminated on either side of the USB connector. (I don't remember seeing the one between the USB port and the memory card slot being lit before.)
                                            "On the Duet 0.8.5 and Duet WiFi, the red 5V LED at the edge of the board should also be lit, so should the green 3.3V LED."
                                            I have a red and a green along the edge of the board.
                                            "Connect to a PC via USB and look for the port
                                            If the LEDs are correctly lit, go to your PC and see whether a new COM port appeared when you plugged in the USB cable. Under Windows you do this by loading Device Manager, then expand "Ports - COM and LPT"."
                                            Interesting!!!, I now have Bossa Program Port (COM6)!!!. I always checked by running listcomports from a Dos CMD window.
                                            "If a port called "Bossa port" is shown then the firmware has been erased. Perhaps you pressed the Erase button. You need to re-install firmware via USB. How to do this for the Duet WiFi is described in section "Fall-back procedure #3" in Updating main firmware."
                                            Ok, I will retrieve that document and carry on from there.
                                            " The Bossa Port should appear; if it does then you can upload firmware using SAM-BA or Bossa/bossac 1.8 as described in section "Fall-back procedure #3" in Updating main firmware."
                                            Will do
                                            From this document
                                            https://duet3d.com/wiki/Updating_main_firmware
                                            "Fallback procedure #3
                                            Only use this if the firmware on the Duet WiFi has been corrupted, or if you have accidentally pressed the Erase button, so you can’t connect over USB with Pronterface even with WiFi disabled in config.g."
                                            That is my situation.
                                            "You will need a Windows or Linux PC."
                                            Ok, Got one handy - Windows 10
                                            "Download the main firmware file (DuetWiFiFirmware.bin for the Duet WiFi, DuetEthernetFirmware.bin for the Duet Ethernet) from https://github.com/dc42/RepRapFirmware/releases."
                                            This link goes to a directory of individual files under 1.19.2, not a packaged .zip file (Since I only want the one file that's ok)
                                            "Verify that the downloaded firmware file has the correct size, as shown on the page you downloaded it from."
                                            Size matches at 323KB
                                            "Download and install SAM-BA version 2.17 from here http://www.microchip.com/DevelopmentTools/ProductDetails.aspx?PartNO=Atmel%20SAM-BA%20In-system%20Programmer"
                                            Version 2.17 downloaded
                                            "Connect the Duet WiFi to your PC via USB. Press the Erase button on the Duet WiFi, then the Reset button."
                                            Done (Checked Ports in Device Manager - Bossa Program Port (Com6) still there
                                            "Load SAM-BA. It usually detects the correct COM port automatically. "
                                            SAM-BA selected COM1 (Communications Port)
                                            I selected COM6
                                            There is another port listed which is \USBSerial\COM6
                                            Select board at91sam4e8-ek. Press Connect.
                                            Select board. Received "Invalid Chip ID" popup message stating
                                            "Can't connect at91SAM4c8-ek"
                                            I'm sure I selected at91sam4e8-ek"
                                            Tried again on COM6 - same message except it says at91sam4e8-ek
                                            Tried again on \USBSerial\COM6 - same message including at91sam4e8-ek
                                            Tried again on COM1 and it took a little longer to respond but I got the same message.
                                            Device Manager is still showing Com6 as Bossa Program Port (Com6)
                                            "In the Send File Name box enter or browse to the DuetWiFiFirmware.bin file to be loaded, then press Send File (leave the Address at the default of 0x400000). On completion it will invite you to lock the region; press Yes.
                                            If desired, press Compare sent file with memory.
                                            Press the Execute button next to the Boot from Flash option in the Scripts box. Then exit SAM-BA."
                                            I could not do the block above because of the Can't connect at91sam4e8-ek so I am going to continue on with the reset of the document
                                            "If you are unable to run SAM-BA (for example because you want to update the firmware from a Mac), you can alternatively use Bossa 1.18 (not an earlier version) from https://github.com/shumatech/BOSSA/releases. "
                                            Downloaded and installed.
                                            "The interactive version (Bossa) does not work on high dpi screens, but you can still use the command line version (bossac). If you use the interactive version, you must check boxes Erase all, Lock, and Boot from Flash before pressing Write. If you use the command line version, try this command line:"
                                            Windows version posts an error on startup and does not run
                                            Copied command line version into same directory as DuetWifiFirmware.bin
                                            "bossac –port=COMxx -U true -e -w -v -b path\DuetWiFiFirmware.bin -R"
                                            Replace COMxx in the above by the COM port number (e.g. COM3) and replace path\DuetWiFiFirmware.bin to the path and name of the firmware file to install."
                                            entered bossac –port=COM6 -U true -e -w -v -b DuetWifiFirmware.bin -R
                                            returned error message "bossav: extra arguments found"
                                            From the help file, the option -U indicates it is used to "force serial port detection to USB if BOOL is 1 [default]"
                                            I read it as [BOOL] is defaulted to 1 earlier in the help file by including -b because it says the default for BOOL is 1. Therefore, the -U will default to force serial port detection to USB because that is the default for -U if -b is used.
                                            Removed "true" from command line argument
                                            Entered bossac –port=COM6 -b -U -e -w -v-DuetWifiFirmware.bin -R
                                            Returned
                                            Erase flash
                                            Done in 4.022 seconds
                                            Write 330452 bytes to flash (646 pages)
                                            Done in 10.251 seconds
                                            Verify 330452 bytes of flash
                                            Verify successful
                                            Done in 9.250 seconds
                                            Set boot flash true
                                            So. I am taking a bit of a break and then I believe I need to continue back at Fallback Position 1
                                            I thank you so much for the expanded documentation which was critical to my getting this far.
                                            If I may, I would suggest placing -b in front of -U and removing the word true from your document. I have verified the command above.
                                            I mean nothing by my statement and I am not correcting your command for bossac.exe. There are a million different command line exe with all sort of different options tagged along behind them. I just checked the help file to see if I could spot something I would recognize.
                                            Best regards,
                                            Tim
