    problems with Stringing
    • lui2004
      lui2004 last edited by lui2004
      Hi
      Ender5
      Micro Swiss Direct Drive
      All Metal Hotend genuine with 0.4 Nozzle
      Extruder Motor: Compact But Powerful motor 0.9°
      Filament:
      its new filament i have buy it yesterday
      sunlu
      Petg 1.75
      Temp: 235°C , Bed: 70°C
      I have try to reduce stringing with retract from 1.0 to 3.5 but nothing always stringing.
      i use the firmware retract and also for test retraction with Prusaslicer alway the same result.
      if you need something like config or other please tell me i will repost it
      thanks
      • T3P3Tony
        T3P3Tony administrators @lui2004 last edited by
        @lui2004 are you sure the retraction is working, and by the amount you set? For example can you see that 1mm is being retracted when its set to 1mm and 3.5mm when its set to 3.5mm. What impact does it have changing the retraction amoung in steps through a test print like you show above, for example changing from 0mm at the bottom to 4mm retraction near the top?
        www.duet3d.com
        • lui2004
          @t3p3tony
          i can see the differences between 0 and 4mm on retraction
          PetrKroupa 1 Reply Last reply Reply Quote 0
          • PetrKroupa
            PetrKroupa @lui2004 last edited by
            @lui2004 - What's your nozzle? Cheap nozzles quite often cause this problem.
            BigOne:Duet3 6HC +1LC + Rpi4, mosquito hotend, 400x400x420
            SmallOne : Duet3 6HC +1LC + Rpi4, mosquito hotend, 210x250x210
            Petr
            lui2004 1 Reply Last reply Reply Quote 0
            • lui2004
              lui2004 @PetrKroupa last edited by
              @petrkroupa
              cheap ? 1 plated copper nozzle arround 17€ 😀
              • PetrKroupa
                @lui2004 - OK let's say, we can eliminate the nozzle. 😀
                Try to dry the filament. Even if it's new, it doesn't always mean it's dry.
                Petr
