    BL TOUCH ON DUET3
    152
    • marioys97
      marioys97 last edited by
      Hi I'm trying to use a BLTouch on a DUET3 6HC but it can't make it work. This is my config
      M558 P9 C"^io5.in" H5 F100 T2000
      M950 S0 C"io5.out" ; Servo
      G31 P25 X0 Y55 Z2
      T3P3Tony PCR 2 Replies Last reply Reply Quote 0
      • T3P3Tony
        T3P3Tony administrators @marioys97 last edited by
        @marioys97 how is it not working?
        Have you followed the information here:
        https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_BLTouch
        are your deploy probe and retract probe files setup correctly?
        www.duet3d.com
        marioys97 T3P3Tony 2 Replies Last reply Reply Quote 0
        • marioys97
          marioys97 @T3P3Tony last edited by
          @t3p3tony everything is connected as that guide explains. I`m connecting everything to the io5 port. The deployprobe and retract are located at sys folder being m280 p0 s90 and m280 p0 s10.
          • T3P3Tony
            T3P3Tony administrators @T3P3Tony last edited by T3P3Tony
            @t3p3tony said in BL TOUCH ON DUET3:
            So does it not deploy and retract? what errors flash?
            www.duet3d.com
            • PCR
              PCR @marioys97 last edited by
              @marioys97 can you post a photo of the wiring.? IMO the creality BL touch has a diffrent wire color. which can be quite confsuing...
              PCR 1 Reply Last reply Reply Quote 0
              • PCR
                PCR @PCR last edited by
                @pcr for example this one
                so in you case look at this
                counting from left to right
                1. GND
                2. 5V
                3. io5.out
                4. GND
                5. io5.in
                • marioys97
                  everything is connected to io5 port. Brown and black are connected to GND, red to 5v, yellow to io5.out and white to io5.in
                  • PCR
                    @marioys97 please make a picture. Does the BL touch Light Up?
                    marioys97 1 Reply Last reply Reply Quote 0
                    • marioys97
                      marioys97 @PCR last edited by
                      @pcr it does light up, it makes a couple of deploys and rectracts and then it stops working. The red led is light up but then it doesn´t do anything when I run m280 commands
