    Z homing issu whit endstop please help
    132
    • bartekp
      bartekp last edited by bartekp
      Hello Guys , I try to not give up but duet still win with me , My issue is that in my corexy Z lift not responding with Z endstop . My printer is Tronxy x5 sa
      When I make homing Z the axis move and not respodning to z stop switch ,and even I make M119 And make test and show me result as At min stop by Z axis if I push z stop switch . But when homing just go high as Tank to brake eveything
      My qyestions for this topic ar
      If I have two motors on Z axis do I need two zstops? If yes where to connect seccond ?
      Is the posibility that I ahve bltouch sensor and he made the problems with Z stop ??
      The switch led on the duet next to Z cable socket responding to using z switch .
      my config g
      M350 Z16 E16 I0 ; configure microstepping without interpolation
      M350 X16 Y16 I1 ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z2756.00 E675.00 ; set steps per mm
      M566 X900.00 Y900.00 Z20.00 E600.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X30000.00 Y30000.00 Z20.00 E6000.00 ; set maximum speeds (mm/min)
      M201 X5000.00 Y5000.00 Z10.00 E500.00 ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E550 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X500 Y500 Z600 S0 ; set axis maxima
      M574 Z1 S1 P"zstop" ; configure active-high endstop for high end on Z via pin ^zstop
      M558 P5 C"^zprobe.in" H5 F120 T12000 ; set Z probe type to switch and the dive height + speeds
      G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
      M557 X70:500 Y70:500 S20 ; define mesh grid
      home all
      ; homeall.g
      ; called to home all axes
      ; generated by RepRapFirmware Configuration Tool v3.3.3 on Mon Oct 04 2021 22:39:47 GMT+0200 (czas środkowoeuropejski letni)
      G91 ; relative positioning
      G1 H2 Z5 F12000 ; lift Z relative to current position
      G1 H1 X-505 Y-505 F1800 ; move quickly to X or Y endstop and stop there (first pass)
      G1 H1 X-505 ; home X axis
      G1 H1 Y-505 ; home Y axis
      G1 X5 Y5 F12000 ; go back a few mm
      G1 H1 X-505 F360 ; move slowly to X axis endstop once more (second pass)
      G1 H1 Y-505 ; then move slowly to Y axis endstop
      G1 H1 Z605 F360 ; move Z up stopping at the endstop
      G90 ; absolute positioning
      G92 Z600 ; set Z position to axis maximum (you may want to adjust this)
      ;G91 ; relative positioning
      ;G1 Z5 F200 ; lift Z relative to current position
      ;G90 ; absolute positioning
      ; homez.g
      ; called to home the Z axis
      G1 H1 Z605 F1800 ; move Z up until the endstop is triggered
      jay_s_uk 1 Reply Last reply Reply Quote 0
      • jay_s_uk
        jay_s_uk @bartekp last edited by
        @bartekp where is your endstop situated? your config says at minimum (i.e. 0) but your homing file for z sends the axis to the maximum.
        I don;t have z endstops on any of my machines and just use a probe to home the z axis
        bartekp 1 Reply Last reply Reply Quote 0
        • bartekp
          bartekp @jay_s_uk last edited by
          @jay_s_uk THe Z endstop is at the top and to homing Z the table is liftet to top
          • jay_s_uk
            @bartekp then your homing file needs changing
            e.g.
            ; homez.g
            G1 H1 Z-605 F1800 ; move Z up until the endstop is triggered
            G92 Z0 ; set Z position to axis maximum (you may want to adjust this)
            bartekp 2 Replies Last reply Reply Quote 0
            • bartekp
              @jay_s_uk In exosted with this config , can you tell me wah to do start printing I try to understatnd but this manual iw writen by enginer who maded this and I mnot so smart like he . And I fight with this almost 3 weeks .If you can please tel me what to change
              Bart
              • bartekp
                bartekp @bartekp last edited by
                @bartekp I try to change Z1 to Z2 or S1 to 0 or 2 and the sama results
                • bartekp
                  @jay_s_uk I changed the home z and nothing changed
                  • jay_s_uk
                    @bartekp it should change the direction it homes in when using just G28 Z or Home z on the DWC screen.
                    Otherwise ditch the endstop and move the head to the middle of the bed and probe using G30
                    • bartekp
                      @jay_s_uk G28 table go up but whit G28 Z table goes down and when I pusch Z endstops the table stops
                      • bartekp
                        @jay_s_uk im not sure if my Z probe is good code in config g
                        • jay_s_uk
                          @bartekp sounds like your z motor need inverting then. As Z0 should be when the bed is in its highest position. Change the S value on the M569 line in your config to either S1 or S0.
                          Then reboot and home x, y and z independently and see if it's in the right position. DWC should show 0 for z once homed
                          • bartekp
                            @jay_s_uk OK I inverted the Z motors works bether!
                            What I meand that when I pusch X home or Y home table move down and home this axis and back to position , and after this i must homing Z what work also perfect
                            but If i Puch home all axis table go down and down and down and I must restatr the maschine
                            • jay_s_uk
                              @bartekp edit the home z portion of homeall to match the same as in homez.
                              If you're not sure, post your homeall here and I'll edit it for you
                              • bartekp
                                @jay_s_uk ; homeall.g
                                • bartekp
                                  @bartekp ; homeall.g
                                  • jay_s_uk
                                    ; homeall.g
                                    G1 H1 Z-605 F360 ; move Z up stopping at the endstop
                                    ;G92 Z600 ; set Z position to axis maximum (you may want to adjust this)
                                    There you go
                                    • bartekp
                                      @jay_s_uk HI You mean G92 adjust for z 100 like this ??
                                      bartekp jay_s_uk 2 Replies Last reply Reply Quote 0
                                      • bartekp
                                        @bartekp said in Z homing issu whit endstop please help:
                                        Can you look at Z probe if is good generated ?
                                        • jay_s_uk
                                          i'm not sure what you mean here
                                          what type of probe is it?
                                          you can check the status of the probe on this window
                                          If its red, its triggered, if its not red, its not
                                          • bartekp
                                            @jay_s_uk Bltouch sorry for that
                                            • jay_s_uk
                                              @bartekp no as you appear to be missing the servo configuration https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_Software_setup_RepRapFirmware_Num_3
                                              What board are you using and where is the bltouch connected?
                                              You should also have deployprobe.g and retractprobe.g in your sys folder
                                              • bartekp
                                                @jay_s_uk https://d17kynu4zpq5hy.cloudfront.net/igi/duet3d/KUDxTZSs3rnd3JVH.full
                                                • bartekp
                                                  @bartekp deployprobe.g and retractprobe.g duet 2 wifi
                                                  • jay_s_uk
                                                    @bartekp then you should have this line in your config
                                                    M950 S0 C"exp.heater3"
                                                    if you add that, does the probe react to M401 and M402?
                                                    What's the contents of those deploy and retract files?
                                                    • bartekp
                                                      @jay_s_uk sory i forgot i dont have this files I working on reach them please wait
