    Duet3 HC with 24V and Toolboard 1.1 with 12V Fans ?
    176
    • joeko
      joeko last edited by
      hallo,
      sorry for this question but i am not sure and english isnt my homelanguage.
      i have a duet3 6hc with 24v running. the fans are on 12v. all fine.
      now i own also a tootlboard 1.1 and i am not sure about the fans. can i connect the 12v fans to out_1 / out_2 on the toolboard if i set the 12v jumper and connect 24v to the toolboard ?
      i connect the toolboard 1.1 direct to the duet3 6hc. i soldered the jumper to terminate the can. but i dont have to connect the 120r because the 120r is already on the board and the jumper only avtivate the 120r ?
      jay_s_uk 1 Reply Last reply Reply Quote 0
      • jay_s_uk
        jay_s_uk @joeko last edited by
        @joeko said in Duet3 HC with 24V and Toolboard 1.1 with 12V Fans ?:
        yes
        • joeko
          thx, and the 120r is onboard and i have to set the solder jumper?
          • T3P3Tony
            T3P3Tony administrators @joeko last edited by
            yes
            www.duet3d.com
            • joeko
              thx for the answer.
              my last question is about the power connecting of the toolboard.
              it should be possible to connect the power of the toolboard to the out1/2/3 of the duet6 right ? configured as fan.
              they are fused with 5a and should be enough
                dc42 administrators @joeko last edited by
                thx for the answer.
                No, do not try to switch the power to the tool board from an OUT port.
                • joeko
                  hallo,
                  i have searched in forum here and will buy an fuse holder with a 5a fuse.
                  thank you for the answer
                    dc42 administrators @joeko last edited by dc42
                    @joeko you can buy an in-line fuse holder if that is most convenient. Here's an example https://www.ebay.co.uk/itm/262131520883.
                    • joeko
                      hallo,
                      yes i bought one and the toolboard is connected and updated with the board to 3.3.
                      but now i have problems with the x endstop (a switch) conntect to
                      M574 X1 S1 P"121.io2.in"
                      but the endstop wont be triggered. no reaction and checked with m115. on the duet 6 hc i have connected the endstop between in and ground. on the toolboard also. on the toolboard wiki i found this
                      "Input only with +5V power, for endstops or tool pickup detection switch. Input is 30V-tolerant"
                      i dont want destroy my hardware but am i right that i have to connect the switch between +5v and io2.in on the jst conector ?
                      • T3P3Tony
                        @joeko it would be normal to connect the switch between io2.in and ground.
                        www.duet3d.com
                        joeko 1 Reply Last reply Reply Quote 0
                        • joeko
                          on the duet3 i have this on this way but on the toolboard it doesnt work. connecting vcc, ground and signal is working
                          • joeko
                            joeko @T3P3Tony last edited by
                            @t3p3tony said in Duet3 HC with 24V and Toolboard 1.1 with 12V Fans ?:
                            after one crimpcheck more (and not the first one) i made an new cable and what happen ? all fine between io2.in and ground 😞
                            faulty crimp was the problem...
                            • T3P3Tony
                              @joeko glad you found the problem!
                              www.duet3d.com
