    Travelspeed when using G32 & G29
    257
    • koreandi
      koreandi last edited by
      Hi there..
      I am converting my Tevo LM with a DUET 2 Wifi. I struggle a bit with the travelspeed in X/Y with G32 & G29.
      I already searched for some topics but couldn´t find something that helped me.
      Homing works fine. I can move all my axis with high speed. G30 is working with the BLtouch just fine.
      But when I use Delta Calibration (G32) and Mesh Compensation (G29) the whole axis movements are cut down to like 10%.
      Both, G32 & G29, succeed and I get the data correctly. But I would like to run it with higher X/Y-speed.
      Any clue what could be wrong?
      Here is my config.g
      config.g
      Please consider.. The Z-Output might be damaged on my board, so I mapped my Z-axis to drive 4 (E1).
      On Line:
      M665 R157 L397.1073 B175 H515
      ...value 515 is a few mm shorter than my real height. If I home all and go to Z0 I am a few mm above my bed. Is this wrong?
      Or is:
      M208 Z0 S1
      wrong?
      I hope this is just a small thing to fix. 🙂
      Thanks already.
      fcwilt JoergS5 3 Replies Last reply Reply Quote 0
      • fcwilt
        fcwilt @koreandi last edited by
        @koreandi
        I reposted you config.g file using the </> tag - it makes it easy for anyone to view the file without having to download it first.
        ; Configuration file for Duet WiFi (firmware version 3.3)
        ; generated by RepRapFirmware Configuration Tool v3.3.4 on Wed Oct 20 2021 13:10:50 GMT+0200 (Mitteleuropäische Sommerzeit)
        G90                                            ; send absolute coordinates...
        M83                                            ; ...but relative extruder moves
        M550 P"Tevo LM"                                ; set printer name
        M665 R157 L397.1073 B175 H515                  ; Set delta radius, diagonal rod length, printable radius and homed height
        M666 X0 Y0 Z0                                  ; put your endstop adjustments here, or let auto calibration find them
        M552 S1                                        ; enable network
        M586 P0 S1                                     ; enable HTTP
        M586 P1 S0                                     ; disable FTP
        M586 P2 S0                                     ; disable Telnet
        M569 P0 S1                                     ; physical drive 0 goes forwards
        M569 P1 S1                                     ; physical drive 1 goes forwards
        M569 P2 S1                                     ; physical drive 2 goes forwards
        M569 P3 S1                                     ; physical drive 3 goes forwards
        M569 P4 S1                                     ; physical drive 3 goes forwards
        M584 X0 Y1 Z4 E3                               ; set drive mapping
        M350 X32 Y32 Z32 E32 I0                    ; configure microstepping without interpolation
        M92 X160.00 Y160.00 Z160.00 E837.00            ; set steps per mm
        M566 X1200.00 Y1200.00 Z1200.00 E1200.00       ; set maximum instantaneous speed changes (mm/min)
        M203 X18000.00 Y18000.00 Z18000.00 E1200.00    ; set maximum speeds (mm/min)
        M201 X1500.00 Y1500.00 Z1500.00 E1000.00       ; set accelerations (mm/s^2)
        M906 X1000 Y1000 Z1000 E800 I30                ; set motor currents (mA) and motor idle factor in per cent
        M84 S30                                        ; Set idle timeout
        M208 Z0 S1                                     ; set minimum Z
        M574 X2 S1 P"xstop"                            ; configure switch-type (e.g. microswitch) endstop for high end on X via pin xstop
        M574 Y2 S1 P"ystop"                            ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin ystop
        M574 Z2 S1 P"zstop"                            ; configure switch-type (e.g. microswitch) endstop for high end on Z via pin zstop
        M307 H3 A-1 C-1 D-1                                                     ; reserve pin 21 for M42 or servo use
        G31 P45 X0 Y0 Z1.3                                                      ; Set Z probe trigger value, offset and trigger height (G31 P25 X0 Y0 Z1.3 )
        M950 S0 C"exp.heater3"                          ; create servo pin 0 for BLTouch
        M558 P9 C"^zprobe.in" H10 F999 T600             ; set Z probe type to bltouch and the dive height + speeds ;T120
        M557 R130 S20 ; Define mesh grid
        M950 H0 C"bedheat" T0                          ; create bed heater output on bedheat and map it to sensor 0
        M307 H0 B1 S1.00                               ; enable bang-bang mode for the bed heater and set PWM limit
        M140 H0                                        ; map heated bed to heater 0
        M143 H0 S120                                   ; set temperature limit for heater 0 to 120C
        M308 S1 P"e0temp" Y"thermistor" T100000 B4138  ; configure sensor 1 as thermistor on pin e0temp
        M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
        M307 H1 B0 S1.00                               ; disable bang-bang mode for heater  and set PWM limit
        M143 H1 S280                                   ; set temperature limit for heater 1 to 280C
        M950 F0 C"fan0" Q500                           ; create fan 0 on pin fan0 and set its frequency
        M106 P0 C"Cold-End" S0 H T50                   ; set fan 0 name and value. Thermostatic control is turned on
        M950 F1 C"fan1" Q500                           ; create fan 1 on pin fan1 and set its frequency
        M106 P1 C"Partfan_links" S0 H-1                     ; set fan 1 name and value. Thermostatic control is turned off
        M950 F2 C"fan2" Q500                           ; create fan 2 on pin fan2 and set its frequency
        M106 P2 C"Partfan_rechts" S0 H-1                     ; set fan 2 name and value. Thermostatic control is turned off
        M563 P0 D0 H1 F0                               ; define tool 0
        G10 P0 X0 Y0 Z0                                ; set tool 0 axis offsets
        G10 P0 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
        • fcwilt
          @koreandi
          I would try to adjust the H parameter so Z=0 is just touching the bed.
          I do not believe this command applies for firmware v3.3 - remove it.
          The F parameter controls the probing speed. The T parameter the travel speed. Your travel speed is slower than your probing speed.
          o_lampe 1 Reply Last reply Reply Quote 1
          • JoergS5
            JoergS5 @koreandi last edited by
            @koreandi
            G31 P45 X0 Y0 Z1.3
            If the BLtouch is not at the same position as the nozzle, X and Y will need correction, because otherwise mesh compensation will be at the wrong places. Please see https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Measuring_Probe_X_Y_Offset
            • o_lampe
              o_lampe @fcwilt last edited by o_lampe
              @fcwilt said in Travelspeed when using G32 & G29:
              Most recommendations I've seen for BLTouch set a dive speed of F100-200, F999 is a bit too fast. Travelspeed of 12000-24000 should be possible.
              When you have finished a calibration succesfully, you can store the new found values with M500. That will include the correct Z-max height.
              Recall the settings by adding M501 at the end of config.g
              • koreandi
                Thank a lot.
                I deleted the line
                and adjusted the speed.
                Now my speeds are all right.
                What could be wrong if my Nozzle is too far from the Bed?
                Even if I adjust my Z-Value to 0,7 it still kepps at the same distance.
                G31 P45 X0 Y22 Z0.95
                with a smaller Value my Z-Offset is too far from the Bed by 0,25 mm.
                I dialed my Height with 520,65 as accurate as I could.
                M665 R157 L397.1073 B175 H520.65
                This is my actual config.g
                M665 R157 L397.1073 B175 H520.65                  ; Set delta radius, diagonal rod length, printable radius and homed height
                G31 P45 X0 Y22 Z0.95 							; Set Z probe trigger value, offset and trigger height (G31 P25 X0 Y0 Z1.3 )
                M558 P9 C"^zprobe.in" H10 F250 T1000           	; set Z probe type to bltouch and the dive height + speeds
                ;M307 H0 B1 S1.00                               ; enable bang-bang mode for the bed heater and set PWM limit
                M307 H0 B0 R0.415 C518.9 D6.20 S1.00 V24.0
                ;M307 H1 B0 S1.00                               ; disable bang-bang mode for heater  and set PWM limit
                M307 H1 B0 R1.947 C255.7 D6.36 S1.00 V23.8
                M501											;Recall the settings
                And by the way...
                It is really great how fast you all helped me out here.
                Great Forum and great support.
                greetings
                Andreas
                o_lampe 2 Replies Last reply Reply Quote 0
                • o_lampe
                  o_lampe @koreandi last edited by
                  @koreandi said in Travelspeed when using G32 & G29:
                  You probably have the same line in config-override which still has the old height value? Overwrite it with M500 after calibration is right
                  koreandi 1 Reply Last reply Reply Quote 0
                  • koreandi
                    koreandi @o_lampe last edited by
                    @o_lampe
                    I don´t have a config-override...
                    Do I have to make this file manually?
                    What should be the content of this file?
                    o_lampe 1 Reply Last reply Reply Quote 0
                    • o_lampe
                      @koreandi Nevermind, if you don't have it. It mainly contains the results of heater-PID tuning and of delta calibration. You can keep these lines in config.g without problems.
                      • koreandi
                        @o_lampe
                        After overwriting my values with M500 the file was created.
                        It is still the same. My Nozzle ist too far from the Buildplate.
                        • o_lampe
                          The G31 line must come later than M558, because you can't create an offset for a tool that wasn't defined yet
