    Problem when turning on printer
    Using Duet Controllers
    260
    • Piet
      Piet last edited by Piet
      Dear users,
      When I start my printer after cutting the power completely it starts of without any tools or heaters.
      When I reset the board with M999 they all load in correctly.
      I'm using 3.4.0b5 but already had this issue in b4.
      Any idea how to fix this?
      jay_s_uk SIam 2 Replies Last reply Reply Quote 0
      • jay_s_uk
        jay_s_uk @Piet last edited by
        @piet whats your setup? duet 3 and toolboards?
        Piet 1 Reply Last reply Reply Quote 0
        • SIam
          SIam @Piet last edited by
          @piet please post the result of M98 P"config.g" and your config.g file
          Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
          Duet WiFi 1.02 or later + DueX5
          RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
          Duet WiFi Server: 1.26
          Duet Web Control 3.4.0beta4 (2021-09-27)
          Piet T3P3Tony 2 Replies Last reply Reply Quote 0
          • Piet
            Piet @jay_s_uk last edited by
            @jay_s_uk I'm using a duet + RPi and using a single toolboard for my extruder.
            • Piet
              Piet @SIam last edited by
              @siam If I execute M98 P"config.g" it will load everything so it seems at first startup it just doesn't load the config file.
              M80
              G90                                                      ; send absolute coordinates...
              M550 P"1500HC"
              M83                                                      ; ...but relative extruder moves
              M669 K1                                                  ; select CoreXY mode
              G4 S1   												 ;wait for expansion boards to start
              M569 P0.0 S1                                           	 ; physical drive 0.0 goes forwards				X
              M569 P0.1 S0                                        	 ; physical drive 0.1 goes forwards				Y
              M569 P0.3 S1                                             ; physical drive 0.3 goes backwards			Z1
              M569 P0.4 S1											 ; physical drive 0.4 goes backwards			Z2
              M569 P0.5 S1											 ; physical drive 0.5 goes backwards			Z3
              M569 P20.0 S1                                            ; physical drive 20.0 goes backwards			E0
              M584 X0.1 Y0.0 Z0.3:0.4:0.5 E20.0                        ; set drive mapping
              M671 X-196:476:1148 Y55.25:631.25:55.25 S5				 ; Z belts are at (-196, 55.25), (476, 631.25) and (1148, 55.25)
              M350 X16 Y16 Z16 E16 I1                                  ; configure microstepping with interpolation
              M92 X53.333 Y53.333 Z1643.95 E348.00                      ;Z1643.95 ; set steps per mm
              M566 X400.00 Y400.00 Z60.00 E120.00                      ; set maximum instantaneous speed changes (mm/min)
              M203 X9000.00 Y9000.00 Z360.00 E1000.00                ; set maximum speeds (mm/min)
              M201 X2100.00 Y2100.00 Z10.00 E250.00                      ; set accelerations (mm/s^2)
              M906 X1300 Y1300 Z1300 E1000 I30                             ; set motor currents (mA) and motor idle factor in per cent
              M84 S30                                                  ; Set idle timeout
              M208 X0 Y0 Z0 S1                                         ; set axis minima
              M208 X1095 Y500 Z820 S0                                  ; set axis maxima
              M574 X1 S1 P"!io0.in"                                    ; configure active-high endstop for low end on X via pin !io0.in
              M574 Y1 S1 P"!20.io2.in"                                 ; configure active-high endstop for low end on Y via pin !io1.in
              M574 Z1 S1 P"!io1.in"                                    ; configure active-high endstop for low end on Z via pin !io2.in
              M558 P1 C"!^io3.in" H5 F60 T6000 A2
              G31 P0 X0 Y0 Z-0.3                                        	 ; set Z probe trigger value, offset and trigger height
              M557 X50:1050 Y50:450 S100                               ; define mesh grid
              M308 S0 P"temp0" Y"thermistor" T100000 B4596 C8.65111e-8 A"Bed" ; configure sensor 0 as thermistor on pin temp0
              M950 H0 C"out1" T0                                       ; create bed heater output on out0 and map it to sensor 0
              M307 H0 B0 R0.162 C304.6 D10.03 S1.00 V23.5              ; disable bang-bang mode for the bed heater and set PWM limit
              M140 H0                                                  ; map heated bed to heater 0
              M143 H0 S180                                             ; set temperature limit for heater 0 to 180C
              M308 S1 P"20.temp0" Y"pt1000" A"Extruder"				 ; configure sensor 1 as thermistor on pin 20.temp0
              M950 H1 C"20.out0" T1                                    ; create nozzle heater output on 20.out0 and map it to sensor 1
              M307 H1 B0 R1.821 C159.8:143.3 D6.60 S1.00 V21.8		 ; disable bang-bang mode for heater  and set PWM limit
              M143 H1 S300                                             ; set temperature limit for heater 1 to 300C
              M308 S2 A"Chamber" P"20.temp1" Y"thermistor" T100000 B4596 C8.65111e-8 A"Chamber" ; configure sensor 2 as thermistor on pin temp1
              M308 S3 A"Right heater (frontview)" P"temp1" Y"thermistor" T100000 B4596 C8.65111e-8
              M308 S4 A"Left heater (frontview)" P"temp2" Y"thermistor" T100000 B4596 C8.65111e-8
              M950 H2 C"out2" T2                                       ; create chamber heater output on out1 and map it to sensor 2
              M307 H2 B0 S1.00                                         ; disable bang-bang mode for the chamber heater and set PWM limit
              M141 H2                                                  ; map chamber to heater 2
              M143 H2 S70 A2                                              ; set temperature limit for heater 2 to 80C
              M143 H2 S80 T3 A2
              M143 H2 S80 T4 A2
              M950 F0 C"20.out1" Q10                                  ; create fan 0 on pin 121.out1 and set its frequency
              M106 P0 C"Part Cooling Fan" S0 H-1 L0.25 X0.7           ; set fan 0 name and value. Thermostatic control is turned off
              M950 P0 C"out4" Q0										; create chamber circulation fan
              M563 P0 S"Extruder" D0 H1 F0                             ; define tool 0
              G10 P0 X0 Y0 Z0                                          ; set tool 0 axis offsets
              G10 P0 R0 S0                                             ; set initial tool 0 active and standby temperatures to 0C
              M591 D0 P7 C"20.io1.in" L0.013 R80:120 E1 S0			 ; set up pulse generating filament monitor
              M42 P1 S1												 ; make turn off signal high (to stay on)
              M955 P20.0 I46											 ; define accelerometer
              M593 P"zvdd" F43.4										 ; define input shaping
              M572 D0 S0.064											 ; define pressure advance
              M501                                                     ; load saved parameters from non-volatile memory
              M80														 ; turn on ATX power
              ;M911 S21 R23 P"M98 P"powerFail.g""
              M911 S21 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"       ; set voltage thresholds and actions to run on power loss
              ; Load variables
              M98 P"startup.g"
              • T3P3Tony
                T3P3Tony administrators @SIam last edited by T3P3Tony
                @Piet
                @siam said in Problem when turning on printer:
                what does M98 P"config.g" report in the console when you run it? Also what does DWC report for DSF version?
                www.duet3d.com
                • Piet
                  @t3p3tony
                  I ran it twice, initally it just loaded the config, the second time it threw some errors because it tried to redefine some variables.
                  In DWC it also says DSF Version: 3.4-b5.
                  • T3P3Tony
                    T3P3Tony administrators @Piet last edited by
                    @piet ok to config.g is not running on start-up.
                    I don't think that will be the problem but if the name you are asking for with M550 is not the same as the hostname on the SBC it will cause an error.
                    I will ask @chrishamm for some input on what to check on the SBC if config.g is not being loaded.
                    www.duet3d.com
                    • T3P3Tony
                      @piet this is potentially due to a known issue with DSF launch script that @chrishamm is looking into once we have confirmed the fix we will let you know.
                      www.duet3d.com
                      • Piet
                        Piet @T3P3Tony last edited by
                        @t3p3tony alright thank you. I guess as a workaround for now I'll check with daemon.g if the config is run and otherwise I'll run it again
                        • T3P3Tony
                          @piet btw flagging reports a post to moderators - its not like a book mark!
                          www.duet3d.com
                          • Piet
                            Piet @T3P3Tony last edited by Piet
                            @t3p3tony Excuse me, i saw a bookmark next to my message and wondered what it was and clicked it and it disappeared. I accidentally reported myself after... Woops 🙂
                            • chrishamm
                              chrishamm administrators last edited by
                              @piet Please check out this post for further information: https://forum.duet3d.com/post/254985
                              Duet software engineer
                              • Piet
                                Piet @chrishamm last edited by
                                @chrishamm Thanks for reporting back! I actually also had the problem of another chromium window opening over DWC, that is fixed. Will check if the config loading is fixed too.
