    Duet3 mini5 wifi disconnects
    Duet Web Control
    152
    • Mart1nS
      Mart1nS last edited by
      I'm having an issue with the stability of the wifi.
      My home wifi coverge is good. I have a Synology RT2600ac main router and 2 synology MR2200ac mesh repeaters. The house is a 3 floor house. Router on floor 1 directly under the Duet3 mini5 wifi. One mesh point is in the room next to the Duet, the other mesh point on the floor above.
      I have other kit in the same room as the duet which has no connectivity issues. There are 2 other printers next to the duet running Octoprint on pi's and they stay connected no problem.
      Uploading gcode to the duet is 5 times slower than sending the same models from the slicer to the pi's
      console.txt
      WiFi signal strength -46dBm
      ; ~PanelDue
      M575 P1 S1 B57600
      G90                                     ; send absolute coordinates...
      M83                                     ; ...but relative extruder moves
      M550 P"V-Core 3"                        ; set printer name
      M669 K1                                 ; CoreXY
      G29 S1                                  ; Set Units to Millimeters
      M552 S1                        ; enable network and acquire dynamic address via DHCP
      M586 P0 S1                              ; enable HTTP
      M586 P1 S0                              ; disable FTP
      M586 P2 S0                              ; disable Telnet
      M569 P0.0 S0 D3                         ; physical drive 0.0 goes backwards
      M569 P0.1 S0 D3                         ; physical drive 0.1 goes backwards
      M569 P0.2 S0 D3                         ; physical drive 0.2 goes backwards
      M569 P0.3 S1 D3                         ; physical drive 0.3 goes forwards
      M569 P0.4 S1 D3                         ; physical drive 0.4 goes forwards
      M569 P0.5 S1 D3                         ; physical drive 0.5 goes forwards
      M584 X0.4 Y0.3 Z0.0:0.1:0.2 E0.5        ; set drive mapping
      M350 X16 Y16 Z16 E16 I1                 ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z800.00             ; set steps per mm
      M906 X1000 Y1000 Z800 I30               ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                 ; Set idle timeout
      M566 X400.00 Y400.00 Z6.00 E120.00 P1          ; set maximum instantaneous speed changes (mm/min)
      M203 X10800.00 Y10800.00 Z1000.00 E3600.00     ; set maximum speeds (mm/min)
      M201 X3000.00 Y3000.00 Z100.00 E3600.00        ; set accelerations (mm/s^2)
      M208 X0 Y0 Z0 S1                               ; set axis minima
      M208 X310 Y300 Z300 S0                         ; set axis maxima
      M574 X1 S1 P"io1.in"                           ; configure active high endstops
      M574 Y2 S1 P"io0.in"                           ; configure active high endstops
      M574 Z1 S2
      M671 X-4.5:150:304.5 Y-4.52:305:-4.52 S5       ; define positions of Z leadscrews or bed levelling screws
      M557 X20:280 Y20:280 P5                        ; define 5x5 mesh grid
      M308 S0 P"temp0" Y"thermistor" T100000 B3950 A"Bed"    ; configure sensor 0 as thermistor on pin temp0
      M950 H0 C"out0" T0                                     ; create bed heater output on out5 and map it to sensor 0
      M307 H0 B0 S1.00                                       ; disable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                                ; map heated bed to heater 0
      M143 H0 S110                                           ; set temperature limit for heater 0 to 110C
      ; Bed PID Tune
       M307 H0 B0 R0.634 C663.6 D8.17 S1.00 V24.0
      M950 F0 C"out3" Q500                   ; create fan 0 on pin out3 and set its frequency
      M106 P0 C"Hotend Fan" S0 H1 T30 L255   ; set fan 0 name and value. Thermostatic control turned on for Hotend
      M950 F1 C"out4" Q500                   ; create fan 1 on pin out4 and set its frequency
      M106 P1 C"Layer Fan" S0 H-1 L255       ; set fan 1 name and value. Thermostatic control is turned off
      M563 P0 D0 H1 F1           ; define tool 0
      G10 P0 X0 Y0 Z0            ; set tool 0 axis offsets
      G10 P0 R0 S0               ; set initial tool 0 active and standby temperatures to 0C
      M950 H1 C"out1" T1         ; create nozzle heater output on out2 and map it to sensor 1
      M307 H1 B0 S1.00           ; disable bang-bang mode for heater and set PWM limit
      M143 H1 S280               ; set the maximum temperature in C for heater
      ; EVA 2 / BMG / E3D V6
      M92 E411.06          ; set extruder steps per mm, 0.9 angle/step (LDO Pancake)
      M906 E800         ; set extruder motor current (mA) and idle factor in per cent
      ;M308 S1 P"temp1" Y"pt1000" B4092 A"hotend" ; T100000 B4725 C7.06e-8
      M308 S1 P"temp1" Y"pt1000" T100000 B4725 C7.06e-8  ; from config tool - Semitec 104-GT2
      M307 H1 B0 R2.452 C223.2 D6.52 S1.00 V23.9
      ; Inductive Probe
      M558 P5 C"!io3.in" H5 F400 T5000       ; set Z probe type to unmodulated and the dive height + speeds
      G31 P500 X-30 Y-15 Z0.20               ; set Z probe trigger value, offset and trigger height, more Z means closer to the bed
      ; BLTouch
      ;M950 S0 C"io2.out"                     ; Create a servo pin on io2
      ;M558 P5 C"io2.in" H5 F240 T10800 A1    ; set Z probe type to unmodulated and the dive height + speeds
      G31 P25 X-23.00 Y-13.00 Z0.859          ; set Z probe trigger value, offset and trigger height, more Z means closer to the bed
      M404 N1.75 D0.4                                 ; Filament width and nozzle diameter
      T0
      ; Pressure Advance
      ; M572 D0 S0.10
      M501
      zapta Mart1nS 2 Replies Last reply Reply Quote 0
      • zapta
        zapta @Mart1nS last edited by
        @mart1ns said in Duet3 mini5 wifi disconnects:
        Can you quantify it in bytes/sec?
        Mart1nS 1 Reply Last reply Reply Quote 0
        • Mart1nS
          Mart1nS @zapta last edited by
          @zapta
          Actually it's far far worse than I initially thought as I'd only done small models for printer calibration.
          I've Just performed a test.
          5 uploads of the same sliced gcode in Superslicer. laptop connected via ethernet to router to eliminate laptop -> router wifi.
          I've located the Octoprint pi on the frame of the V-Core 3 right next to the duet wifi antenna.
          gcode size 30.1mb
          Average upload time.
          -> Octoprint on pi : 2.1 seconds
          -> duet : 1min 11 seconds.
          Model failed to transer to duet twice during the test.
          Surely there must be an issue with the board. The Pi isn't noted for having the best wifi, but this duet is incredibly unstable.
          I've also noticed that as I've been editing config,g setting the new printer up I'm doing a lot of software resets from the Web control. At least 50% of the time the DWC fails to reconnect to the board following a reset. I have to power cycle the printer to regain connection, often it will then drop out again and reconnect immediately.
          In addition to that often when I'm editing the config connection will be lost, meaning that the editor closes and all changes are lost. I've also experience loss of connection from DWC during a save of the config. This results in the config file being deleted from the SD and I've had to recreate it using the backup.
          The duet3 mini5 wifi experience has been infuriating to say the least.
          zapta 1 Reply Last reply Reply Quote 0
          • Mart1nS
            Mart1nS @Mart1nS last edited by
            15f2606c-6a99-4eb9-bdb5-1c36694f2206-image.png @mart1ns
            Gixxerfast gloomyandy dc42 3 Replies Last reply Reply Quote 0
            • Gixxerfast
              Gixxerfast @Mart1nS last edited by Gixxerfast
              @mart1ns Yeah, surely irritating. That doesn't seem normal at all.
              I have my antenna in the electronics bay between two alu composite panels.
              Here's a snapshot from mine:
              All I could see that was different was this: Failed messages: pending 0, notready 0, noresp 12
              What does noresp means in this case?
              Voron V2.4 (#1317) with Duet 3 Mini5+ Wifi and 1LC v1.1 Toolboard
              Voron V0.1 (#637) with Duet 3 Mini 5+ Wifi and 1LC v1.2 Toolboard
              Ender 3 Pro with BTT SKR-2 + RRF
              • gloomyandy
                gloomyandy @Mart1nS last edited by
                @mart1ns It may be worth enabling WiFi debug to see if that shows anything of interest. Enable it with:
                M111 P14 S1
                  dc42 administrators @Mart1nS last edited by
                  @mart1ns that is indeed much slower than it should be. With a good wifi connection and adequate SD card, the upload speed for the Duet 3 Mini should be in the range 400 to 800 kbytes/sec. Uploading to a Pi will be faster, because it has more RAM to use for buffer space, and it may report that the transfer is complete even though some of the file is in RAM waiting to be written to the SD card.
                  The upload speed depends on both the wifi speed and the SD card write speed. You can test these independently to see where the bottleneck is.
                  To test the SD card write speed, send M122 P104. On a Duet 3 Mini I typically get 2.9Mbytes/sec write speed using a good SD card, and a little over 1Mb/sec using a poor SD card.
                  To test the wifi speed, upload a file whose name ends in ".dummy" instead of ending in ".gcode" or similar.
                  • Mart1nS
                    Mart1nS @dc42 last edited by
                    @dc42 @dc42
                    Thanks.
                    Well the SD card speed may not be helping
                    24/10/2021, 19:42:10	SD read speed for 10.0Mbyte file was 0.62Mbytes/sec
                    24/10/2021, 19:41:53	SD write speed for 10.0Mbyte file was 0.45Mbytes/sec
                    This is with the supplied card. I'll replace it with another. I've just read the specs and I can't use one > 32gb so I'll have to order one as all mine are 64.
                    Uploading a .dummy file I'm getting 180 KiB/sec.
                    I have wifi debug on I'll leave it for a while see if anything gets logged - will it just log to console?
                    gloomyandy 1 Reply Last reply Reply Quote 0
                    • zapta
                      zapta @Mart1nS last edited by zapta
                      gcode size 30.1mb
                      Is this 30M bytes or bits?
                      EDIT: "Model failed to transer to duet twice during the test." -> If you upload from a slicer, they have timeout that abort the upload if it takes too long. For large gcode files, try to upload from DWC which is more patient.
                      • gloomyandy
                        @mart1ns I think the debug output goes to the USB console (well that's how I always look at it!).
