    sensor ir
    3.8k
    • fcwiltundefined
      fcwilt @A Former User
      @sgk said in sensor ir:
      @fcwilt sorry my translator is kidding
      OK I will post again my question again:
      OK can you do this:
      - Disconnect the connector from the IR Sensor
      - Using a small piece of wire or equivalent connect the signal and ground pins of that connector and check the DWC Z probe reading
      - Then do the same but connecting the signal and power pins
      • A Former User?
        A Former User
        the probe works but when I do g30 s-1 the bed stays at a great distance from the nozzle as in the photoIMG_20211026_152856_edit_485625590903498.jpg
        • A Former User?
          A Former User
          • fcwiltundefined
            @sgk
            If you move the bed away from the probe, say to Z=5, does then doing a G30 or a G30 S-1 result in the bed moving and triggering the probe?
            A Former User? 2 Replies Last reply Reply Quote 0
            • A Former User?
              A Former User @fcwilt
              @fcwilt yes
              • A Former User?
                • A Former User?
                  A Former User
                  the bed remains loing of the nozzle
                  • A Former User?
                    A Former User
                    This post is deleted!
                    • fcwiltundefined
                      @fcwilt yes
                      OK so the probe IS working.
                      After doing a G30 or a G30 S-1 it is normal for the probe to end up a small distance away from the bed.
                      That distance is the dive height (the H parameter of M558) plus the Z Trigger Height (the Z parameter of G31).
                      Does that appear to be what is happening when you do a G30 or G30 S-1?
                      • A Former User?
                        @fcwilt yes
                        • fcwiltundefined
                          @fcwilt yes
                          OK do this:
                          • Move to Z=5
                          • Execute a G30
                          • Carefully using the Z "jog" buttons on the DWC move to Z=0
                          • Check to see if the nozzle is just touching the surface of the bed
                          • A Former User?
                            • fcwiltundefined
                              I see the Z reading is -1.00 - is that with the nozzle just touching the bed?
                              • A Former User?
                                @fcwilt yes
                                • fcwiltundefined
                                  @fcwilt yes
                                  OK that indicates the Z Trigger Height parameter of the G31 is wrong.
                                  If after doing a G30 and then moving to Z=0 if the nozzle is not just touching the bed you need to increase the Z Trigger Height parameter of the G31.
                                  If the nozzle touches the bed before you get to Z=0 then you need to decrease the Z Trigger Height parameter of the G31.
                                  Of course when you make a change to the G31 command it needs to be executed for that change to take effect.
                                  When you have found the correct value for the Z Trigger Height parameter of the G31 then when moving to Z=0 after doing a G30 the nozzle should just touch the surface of the bed.
                                  • A Former User?
                                    A Former User
                                    Capture d’écran 2021-10-26 155129.png now i'm at the top of the leaf
                                    • A Former User?
                                      A Former User
                                      it's good everything works thanks to everyone for your invaluable help
                                      A Former User? fcwiltundefined 2 Replies Last reply Reply Quote 1
                                      • A Former User?
                                        A Former User @A Former User
                                        @sgk 👍 👏 😊
                                        • fcwiltundefined
                                          Glad to hear it.
                                          • A Former User?
                                            @fcwilt thank you again thank you🙂
