    sensor ir
    3.8k
    • jumpedwithbothfeetundefined
      jumpedwithbothfeet @A Former User
      @sgk @oliof, I maybe off base but would it be worth trying the probe in mode 8? this is the way my IR sensor is configured, then use the paper with the bed well out of the way to trigger a response?
      6HC Voron Trident based, 6XD CNC, Mini 5 polar printer
      • A Former User?
        A Former User
        I will try
        • A Former User?
          A Former User
          M558 P1 C"!zprobe.in" H5 F120 T6000
          to
          M558 P8 C"!zprobe.in" H5 F120 T6000
          • A Former User?
            A Former User
            the bed does not stop
            • A Former User?
              A Former User
              in fact the probe does not trigger because when I raise the bed I put the finger and the bed does not stop it continues to rise
              jumpedwithbothfeetundefined 1 Reply Last reply Reply Quote 0
                @sgk are you getting any lights on the ir board when the printer turns on, Red light when you trigger it?
                • A Former User?
                  A Former User @jumpedwithbothfeet
                  @jumpedwithbothfeet yes 4x
                    @sgk have you read through this?
                    https://miscsolutions.wordpress.com/mini-height-sensor-board/
                    • A Former User?
                      SIamundefined 1 Reply Last reply Reply Quote 0
                      • SIamundefined
                        SIam @A Former User
                        @sgk
                        what happens if you replace this line
                        M558 P1 C"^zprobe.in" H5 F200 T9000 I0 R0.5		        ; Set Z probe type mini ir sensor
                        with this
                        M558 P1 C"zprobe.in" H5 F120 T6000             ; set Z probe type to unmodulated and the dive height + speeds
                        Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
                        Duet WiFi 1.02 or later + DueX5
                        RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
                        Duet WiFi Server: 1.26
                        Duet Web Control 3.4.0beta4 (2021-09-27)
                        • A Former User?
                          A Former User @SIam
                          @siam thank you for helping me
                          • A Former User?
                            A Former User
                            • A Former User?
                              A Former User
                              likewise the bed does not stop
                              • fcwiltundefined
                                fcwilt @A Former User
                                @sgk said in sensor ir:
                                If you can see LEDs on the IR probe turning on/off as you put something in front of the IR sensors BUT the bed does not stop moving I would suspect that the signal out from the IR probe is not getting to the Duet board.
                                Can you post a picture showing the connector from the IR probe as it is connected to the Duet board?
                                Thanks.
                                A Former User? tecnoundefined 2 Replies Last reply Reply Quote 0
                                • A Former User?
                                  A Former User @fcwilt
                                  • fcwiltundefined
                                    @sgk
                                    Thanks.
                                    According to the IR sensor documentation when the unit is connected and working you should be able to see the Z probe reading on the DWC change as you try to activate the sensor with something placed in front of the sensor to simulate the IR sensor sensing the bed.
                                    Are you seeing any change in the Z probe reading when you do that?
                                    • A Former User?
                                      • A Former User?
                                        A Former User @A Former User
                                        @sgk i have this
                                        fcwiltundefined 2 Replies Last reply Reply Quote 0
                                        • fcwiltundefined
                                          @sgk i have this
                                          And the number doesn't change if you put something near the sensor or take that something away?
                                          • fcwiltundefined
                                            @sgk
                                            And what does your current M558 command look like?
                                            Thanks.
