    sensor ir
    3.9k
    • tecnoundefined
      tecno @fcwilt
      @sgk
      show photo of IR probe connector/cable
      • A Former User?
        A Former User @tecno
        @tecno IMG_20211026_143529.jpg M558 P1 C"!^zprobe.in" H5 F200 T9000 I0 R0.5
        • A Former User?
          A Former User @A Former User
          o_lampeundefined jumpedwithbothfeetundefined fcwiltundefined 3 Replies Last reply Reply Quote 0
          • o_lampeundefined
            o_lampe @A Former User
            @sgk here's mine for reference: ( the probe pin has a different name, ignore it)
            Did you try P8 as sensor type?
            M558 P8 C"probe" H3.5 F1200 T24000
            • A Former User?
              A Former User @o_lampe
              • jumpedwithbothfeetundefined
                jumpedwithbothfeet @A Former User
                @sgk Just to clarify as I have gone over the post and I cant see your answer... when you turn on the printer and do nothing else, if you place something under the IR sensor does the red LED on the board light up when you get close to the bottom of the board?
                6HC Voron Trident based, 6XD CNC, Mini 5 polar printer
                • fcwiltundefined
                  fcwilt @A Former User
                  @sgk said in sensor ir:
                  That appears to be correct except, perhaps, for the exclamation point.
                  • fcwiltundefined
                    @sgk
                    Where is the M558 command located?
                    In your config.g file?
                    If so please execute, from the DWC Console, M98 P"config.g" and see if any errors are reported.
                    • A Former User?
                      A Former User @jumpedwithbothfeet
                      • A Former User?
                        A Former User
                        @fcwilt said in sensor ir:
                        M98 P"config.g"
                        • fcwiltundefined
                          @sgk
                          Thank you.
                          It seems that the IR sensor is working based on the LEDs on it responding to the presence of the bed.
                          The M558 configuration seems to be correct and if it is in your config.g file it appears to be executing without any problems.
                          So that really seems to leave only the connection from the IR Sensor output to the Duet Z Probe input.
                          Do you have a meter of any sort that can verify continuity of the wire from the connector for the IR Sensor all the way to the connector for the Duet Z Probe input?
                          • A Former User?
                            A Former User @fcwilt
                            @fcwilt yes I tested with a multimeter the continuity
                            fcwiltundefined jumpedwithbothfeetundefined 2 Replies Last reply Reply Quote 0
                            • fcwiltundefined
                              OK can you do this:
                              • Disconnect the connector from the IR Sensor
                              • Using a small piece of wire or equivalent connect the signal and ground pins of that connector and check the DWC Z probe reading
                              • Then do the same but connecting the signal and power pins
                                @sgk I just looked at your config.g what firmware version are you using version 1? it might be an idea to update it!
                                • A Former User?
                                  @fcwilt
                                  you can tell me what they are
                                  • A Former User?
                                    SIamundefined 1 Reply Last reply Reply Quote 0
                                    • fcwiltundefined
                                      @fcwilt
                                      Sorry but I don't understand what you mean.
                                      • A Former User?
                                        @fcwilt sorry which thread
                                        • fcwiltundefined
                                          You said "you can tell me what they are".
                                          I don't know what you mean by that.
                                          • A Former User?
                                            @fcwilt sorry my translator is kidding
