    Connecting RGBW 24V LED strip to Duet 2 WIFi board
    523
    • csosa
      csosa last edited by
      Hello I am new to the duet board and am having trouble connecting a 24v LED Strip to my duet 2 wifi board. I found a video on youtube where he powers the LEDs from the PSU and then connects the RGBW wires to different heaters on the duet expansion board.
      Video : https://www.youtube.com/watch?v=RNxyfYwVHN4
      I am trying to do the same thing but using the expansion heaters pin. I power the LEDs with the 24v psu, connect the red LEDs to heater4, green to heater5, blue to heater6, and white to heater7. In my Config.g file I added the following code at the end:
      ; Lights
      M950 P13 C"exp.heater4" Q500 ; Assigns red to P13
      M950 P18 C"exp.heater5" Q500 ; Assigns green to P18
      M950 P23 C"exp.heater6" Q500 ; Assigns blue to P23
      M950 P31 C"exp.heater7" Q500 ; Assigns white to P31
      M42 P13 S0 ; Turn red LED on
      M42 P18 S0 ; Turn green LED off
      M42 P23 S0 ; Turn blue LED off
      M42 P31 S0 ; Turn white LED off
      When I turn on the board the LEDs light up white but my boards wifi disconnects, my Extruder fan (Fan1) turns on and the diag LED lights up. I disconnect the LEDs and reset the board but the same thing keeps happening. This is my second attempt at connecting the LEDs strip, during my first attempt I tried powering the LEDs through the PWM fan2 but the same thing happened. I was able to get my board working again by erasing the firmware and reinstalling it.
      Can someone please explain to me what I am doing wrong and what I can do to be able to get the LEDs to work and be programable through the congif.g file.
      PCR o_lampe 2 Replies Last reply Reply Quote 0
      • PCR
        PCR @csosa last edited by
        @csosa which Firmware Version are you running?
        Best
        csosa91 1 Reply Last reply Reply Quote 0
        • csosa91
          csosa91 @PCR last edited by
          @pcr
          Firmware Version 3.3
          • o_lampe
            o_lampe @csosa last edited by
            @csosa Does the LED strip have any driver chips or a controller onboard? If not, you need some small FET drivers ( 1 Amp should do) between RGB-pins and expansion header. I have good experience with a 2$ quad driver board TB6612. (was 1$ before supply shortage)
            csosa 1 Reply Last reply Reply Quote 0
            • csosa
              csosa @o_lampe last edited by
              @o_lampe
              Thanks for the advice. The LEDs do not have a driver chips or a controller onboard. Could you please send me a link to the FET driver you recommended, cant seem to find it on Amazon. Would I need a divers for each color, RGBW?
              o_lampe 1 Reply Last reply Reply Quote 0
              • o_lampe
                o_lampe @csosa last edited by o_lampe
                @csosa search for TB6612FNG
                You only need one for RGB
                • csosa
                  @o_lampe
                  Thank you for your help. I have never used a driver before so I am not sure how to wire it to the Duet and LEDs. The driver I got has the following pin descriptions:
                  AIN1/AIN2: Control Signal input terminal
                  BIN1/BIN2: Control Signal input terminal
                  PWMA/PWMB: Control Signal input terminal
                  A01/A02: Motor control output
                  B01/B02: Motor control output
                  STBY: normal working/standby state control pin
                  VM: motor drive voltage
                  VCC: logic level input terminal
                  GND: ground
                  Would the following wiring connections be correct?
                  Left side of driver
                  Empty----------->PWMA
                  Heater pin 4-->AIN2
                  Heater pin 5-->AIN1
                  Empty----------->STBY
                  Heater pin 6-->BIN1
                  Heater pin 7-->BIN2
                  Empty----------->PWMB
                  Empty----------->GND
                  Right Side of driver
                  VM<-------- PSU 24v+
                  VCC<------- LED 24V
                  GND<------ PSU GND
                  A01<--------LED R
                  A02<--------LED G
                  B02<--------LED B
                  B01<--------LED W
                  GND<-------Empty
                  Thanks again for all your help.
                  • o_lampe
                    @csosa I must apologize, the fact you are using a 24V LED strip slipped my brain. The driver I proposed is good for only 12V 😞
                    If you still can use it, you'd have to add at least one GND signal from Duet to driver if they don't use the same powersupply
                    • csosa
                      @o_lampe
                      According to the datasheet the TB6612FNG driver can handle an Input voltage between 2.7 V – 10.8 V. Could I instead use something like the Hilitand MOS FET PWM 3-20V to 3.7-27VDC 10A 4-Channel Driver Module PLC Amplifier Circuit Board ?
                      • o_lampe
                        @csosa Yes, this one looks better suited.
                        • csosa
                          @o_lampe
                          Great! So based on the inputs/outputs of the driver would the wiring diagram below be the correct?
                          csosa 1 Reply Last reply Reply Quote 1
                          • csosa
                            csosa @csosa last edited by csosa
                            @o_lampe
                            So the board arrived and I wired it just like in the image from my last post but the LEDs still don't work. I checked the voltage from each of the heater pins and they are all different.
                            Heater pin 4 -> 2.29v
                            Heater pin 5 -> 3.25v
                            Heater pin 6 -> 0.13v
                            Heater pin 7 -> 0.23v
                            To check if the board was working right I checked the voltage from pin 43 which is suppose to be 3.3v and it is working just fine.
                            Next I tried turning on and off the pin using the M42 P# S1 or M42 P# S0 and nothing happens, all the voltages stay the same.
                            I am at a lost and have no idea what I am doing wrong. Below is the section of my config.g code that controls the lights. I tried changing the Q value of the M950 command but that doesn't change anything.
                            ; Lights
                            M950 P5 C"exp.heater4" Q250 ; Assigns red to Pin 13
                            M950 P6 C"exp.heater5" Q250 ; Assigns green to Pin 18
                            M950 P7 C"exp.heater6" Q250 ; Assigns blue to Pin 23
                            M950 P8 C"exp.heater7" Q250 ; Assigns white to Pin 31
                            M42 P5 S0 ; Turn red LED off
                            M42 P6 S0 ; Turn green LED off
                            M42 P7 S0 ; Turn blue LED off
                            M42 P8 S0 ; Turn blue LED off
                            • o_lampe
                              @csosa said in Connecting RGBW 24V LED strip to Duet 2 WIFi board:
                              ; Lights
                              You can try and activate the internal pullup for the heater pins with '^' :
                              M950 P5 C"^exp.heater4" Q250
                              • csosa
                                @o_lampe
                                I tried added '^' to all four heater pins and nothing changed.
                                I decided to test my board by enabling the pull up resistor '^' and inverting the input '!' to see how it affects the voltage. The results I got are shown below, as you can see the voltages are all over the place.
                                I also tried added MT3608 DC boosters to the pins in hope that that might boost the voltage to 3.3v but every time I connect it, the voltage coming from the pins just drops.
                                • o_lampe
                                  @csosa
                                  That's confusing...are you sure about the GND pin you measured voltages against? Try using #pin2 from the expansion header.
                                  Did you try to run M98 P"config.g" to see if any errors pop up?
                                  Maybe there's an issue with using a heater output without defining a temp-sensor?
                                  Anyone who can chime in here?
                                  • o_lampe
                                    o_lampe @o_lampe last edited by
                                    @o_lampe said in Connecting RGBW 24V LED strip to Duet 2 WIFi board:
                                    Something like
                                    M950 H4 C"nil"   ;  undefine heater4 pin
                                    M950 P4 C"exp.heater4" Q250
                                    • csosa
                                      csosa @o_lampe last edited by csosa
                                      @o_lampe
                                      I ran the M98 P"config.g" and got back the following
                                      I am not sure is FTP and TELNET are suppose to be enabled but other than that it doesn't look like there are any errors in config.g
                                      I also switched the GND to pin 2 (which is normally connected to my BL Touch). I checked the voltage from all four wires and got the following.
                                      As you can see the voltage is all over the place expect for exp.heater7 which is working as it should. For heater pins 4 ,5 and 6 the voltage didn't change when I ran M42 P# S1.
                                      While I was testing the last two wires (going to exp.heater6 and exp.heater7) my cooling fan started to turn on, the WIFI would disconnect and the diag. light would briefly flash. It did this a few time randomly so I unplugged all the wires going to the expansion pins. Now every time I turn it on it connects to WIFI but after a few minutes it disconnects and the diag. LED starts flashing.
                                      Looks like I might have to erase the firmware and reinstall it before being able to test the "nil" function to undefine the heater pins.
                                      • o_lampe
                                        @csosa
                                        Maybe the fan went on, because you've used the same P# in a fan declaration?
                                        I've tested all 5 heaters without "nil", mentioning that was just a last straw. In my case, they were real heaters, which can make a difference.
                                        • o_lampe
                                          @csosa
                                          From the Wiki:
                                          M42 switches a general purpose I/O pin. Use M42 Px Sy to set pin x to value y. The S field may be in the range 0..1 or 0..255.
                                          How does M42 know that S1 isn't meant as 1 of 255 ?
                                          Answer: use S1.0 to tell it to switch on 100%
                                          • csosa
                                            @o_lampe
                                            Since my board kept disconnecting from the wifi and the diag light start flashing. I erased the firmware and tried reinstall it again using Fallback procedure #2. I am not sure why but the firmware doesn't seem to install on the board, the diag light wont turn off. I'm using Bossa to write and verify the firmware, but afterwards the diag light wont turn off. Usually I'm able to just erase the board and reinstall the firmware using Bossa and later YAT to setup the WIFI and make updates but this time it doesn't look like Bossa is installing anything. I also tried installing the firmware using SAM-BA version 2.17 but it wouldn't connect either.
                                            • o_lampe
                                              @csosa
                                              A last straw is to remove all wires, steppers, probes from the board and try Bossa again, but I'm afraid your controller is partially dead.
                                              It's probably time to put a new Duet board on your x-mas wishlist?
                                              • csosa
                                                @o_lampe
                                                Sadly I think you are right 😭
                                                I did some research and I am thinking of ordering the Duet 3 mini 5+. Since it has a connector for the LED, hopefully it will be easier to set up.
                                                However according to duet guide the LEDs have to be NeoPixel in order to work. Do you think it is possible to get away with using another led strip that used the same WS2812 LED used by NeoPixel. I'm asking because BTF-LIGHTING have basically the same set up but are cheaper.
                                                • o_lampe
                                                  @csosa
                                                  I'm afraid the NeoPixel LED strip comes with a special interface, You'd still need 4 GPIO pins and the external driver board.
                                                  The BTF strip uses the same it seems (but not tested)
                                                  BTW: It's probably not a good time to buy LED strips....better wait until X-mas is over 😉
                                                  • csosa
                                                    @o_lampe
                                                    You're probably right, but I want to finish this project as soon as possible lol. Thanks you for all your help, I will let you know if I can get the BTF-Lighting LEDs to work.
