    H-bridge dc motor on 1XD
    • verminsupundefined
      verminsup
      I have been working on a Stratasys conversion for work. They want to use all the original hardware, this includes the Dc servo motors for the extruder. I have been using servo drives together with 1XD boards but now one of the drives is broken and they want me to use a H-bridge for the extruder. I know this isn't a good idea but it's not up to me.
      I'm using the L298N
      The pins for the stepper driver and how I have them configured right now on the L298N
      D0_STEP(-)
      D0_STEP(+)
      D0_DIR(-) pin 8
      D0_DIR(+) pin 9
      D0_EN(-) EN-
      D0_EN(+)
      On the L298N I can supply a Pwm signal for speed control on pin 7 and then set the direction with the standard dir pins. I was wondering if the other pins from the 1XD drive give out a pwm signal (and be used for an extruder)? Or is there another way of configuring this like using the fan pwm signal. I was told that the step pins have a pwm signal but I can't set the speed with those.
      This is the part of the config that matters for the drive
      M569 P0 S1 R0 T4000;
      alankilianundefined o_lampeundefined 2 Replies Last reply Reply Quote 0
      • alankilianundefined
        alankilian @verminsup
        @verminsup
        I'm not quite sure what you are trying to do, so I'll type what I think I read fro your posting:
        • You are trying to run a Stratasys extruder which has a DC motor and encoder on it.
        • You are going to ignore the encoder and run the extruder using PWM through an H-Bridge driver.
        Questions:
        • How are you going to have the Duet control the amount of extrusion?
        • How are you going to get yourself out of this situation of having other people make design decisions you have to try to implement? (That's just a joke. I feel your pain man.)
        I'm probably misunderstanding something (I hope anyway.) If not, we can get you squirting out plastic at a nonconstant rate, but I'm not sure we can get you to something that's going to make parts.
        verminsupundefined 1 Reply Last reply Reply Quote 1
        • o_lampeundefined
          o_lampe @verminsup
          @verminsup
          I've experiemnted with DC-encoder motors to act like steppers and controlled them via step, dir, enable. From my experience you can't do that without reading the encoder signals.
          BTW: I use the TB6612FNG driver which has way better performance than the dinosaur L298.
          verminsupundefined 1 Reply Last reply Reply Quote 0
            verminsup @o_lampe
            @o_lampe
            I have found this driver.
            But I'm still not sure how I'm going to let the duet extrude a specific amount.
            I'll check that driver
              verminsup @alankilian
              @alankilian
              I'm not sure how I can give a specific extrusion amount
              By having someone stubborn above me
                verminsup
                Also I got it working just fine but now all of a sudden both drives have stopped working.
                Got some very nice prints out of it
                alankilianundefined 1 Reply Last reply Reply Quote 1
                  @verminsup Yeah!
                  That Rhinomc.com driver looks perfect for your job although I can't find it on their page, so maybe they don't make it anymore.
                  It's great you've gotten your machine running again.
