    [3.4.0beta6] M32 Response too long error check console
    Beta Firmware
    • supernovaeundefined
      supernovae
      Click True Bed Leveling (m32)
      Starts and runs to completion - throws error notification "response to long check Console" but there is nothing in console other than showing lead screw adjustments.
      bed.g
      ; bed.g
      if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed
      	G28
      T-1
      while true
      	G30 P0 X25.0 Y155.0 Z-9999 ; probe near a leadscrew - left
      	G30 P1 X285.0 Y150.0 Z-9999 S2  ; probe near a leadscrew - right
      	if move.calibration.initial.deviation <= 0.01
      		echo "Leveling successful. Deviation: " ^ move.calibration.initial.deviation ^ "mm"
      		break
      	if iterations >= 10
      		break
      	echo "Repeating leveling because deviation is too high (" ^ move.calibration.initial.deviation ^ "mm)"
      G28
      M98 P"config.g"
      HTTP is enabled on port 80
      FTP is enabled on port 21
      TELNET is disabled
      m122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.0beta6 (2021-11-06 11:37:41) running on Duet WiFi 1.02 or later
      Board ID: 08DGM-917DA-G4MSJ-6JTD6-3SN6L-1TRR9
      Used output buffers: 3 of 24 (13 max)
      Static ram: 23772
      Dynamic ram: 75760 of which 56 recycled
      Never used RAM 9564, free system stack 124 words
      Tasks: NETWORK(ready,14.0%,245) HEAT(notifyWait,0.0%,310) Move(notifyWait,0.0%,297) MAIN(running,85.5%,440) IDLE(ready,0.5%,30), total 100.0%
      Owned mutexes: WiFi(NETWORK)
      Last reset 00:04:22 ago, cause: power up
      Last software reset time unknown, reason: User, GCodes spinning, available RAM 15236, slot 1
      Error status: 0x00
      Aux0 errors 0,0,0
      Step timer max interval 0
      MCU temperature: min 23.4, current 32.6, max 32.7
      Supply voltage: min 24.0, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
      Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/484/484, gc cycles 0
      Driver 0: pos 54400, standstill, SG min 0
      Driver 1: pos 1600, standstill, SG min 0
      Driver 2: pos 2967, standstill, SG min 0
      Driver 3: pos 0, standstill, SG min n/a
      Driver 4: pos 0, standstill, SG min 0
      Driver 5: pos 0
      Driver 6: pos 0
      Driver 7: pos 0
      Driver 8: pos 0
      Driver 9: pos 0
      Driver 10: pos 0
      Driver 11: pos 0
      Date/time: 2021-11-10 10:36:08
      Slowest loop: 7.56ms; fastest: 0.14ms
      === Storage ===
      Free file entries: 10
      SD card longest read time 1.5ms, write time 0.0ms, max retries 0
      DMs created 83, segments created 3, maxWait 27327ms, bed compensation in use: none, comp offset 0.000
      === MainDDARing ===
      Scheduled moves 62, completed 62, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
      === AuxDDARing ===
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      Daemon is idle in state(s) 0
      Code queue is empty
      === Network ===
      Slowest loop: 171.70ms; fastest: 0.00ms
      Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
      HTTP sessions: 1 of 8
      - WiFi -
      Network state is active
      WiFi firmware version 1.26
      WiFi MAC address 80:7d:3a:3f:f3:25
      WiFi Vcc 3.41, reset reason Turned on by main processor
      WiFi flash size 4194304, free heap 23328
      WiFi IP address 192.168.1.116
      WiFi signal strength -70dBm, mode 802.11n, reconnections 0, sleep mode modem
      Clock register 00002002
      Socket states: 4 0 0 0 0 0 0 0
      jay_s_ukundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @supernovae
        @supernovae that's pretty normal.
        The popups can only be so many characters so when they're longer than a set number, they're pushed to the console
        supernovaeundefined 1 Reply Last reply Reply Quote 0
          supernovae @jay_s_uk
          @jay_s_uk nothing shows up in console
          Just looks like it finished but the popup says something and my re-try logic re-tries and eventually gets it (so it seems)
          • T3P3Tonyundefined
            T3P3Tony administrators @supernovae
            @supernovae which version of DWC are you running?
            www.duet3d.com
              Phaedrux Moderator @supernovae
              @supernovae said in [3.4.0beta6] M32 Response too long error check console:
              The "response too long" message is trying to tell you that the lead screw adjustments results are too long to show as a popup and to see them in the console.
                supernovae @T3P3Tony
                @t3p3tony said in [3.4.0beta6] M32 Response too long error check console:
                I'm running Duet Web Control 3.4.0-b6
                  supernovae @Phaedrux
                  @phaedrux said in [3.4.0beta6] M32 Response too long error check console:
                  oh hahaha.. it took a bit for my brain to digest that. I was thinking there should be another error in the console not that the leadscrew adjustment warning was too big to show.
                  I think DWC used to show it in a green box but now it just throws that error popup
