    How to configure the closed-loop motor on duet 2
    570
    • Eaton Renundefined
      Eaton Ren
      Hi everyone, I am a new fan of duet. Just got a new duet 2 wifi motherboard. When I use an external closed-loop motor for X and Y axis, I ran into trouble. All my stepper settings are normal and it can move perfectly. Unfortunately, the print is slanted. I tried to use M569 to change the T parameter, but it didn't work. Does anyone know this problem?
      Thanks in advance for any helpful suggestions.
        droftarts administrators
        @eaton-ren please post more details; at the very least Duet firmware version (send M115 to Duet, post response), config.g, specification sheet of external closed loop board, how you have wired it.
        Eaton Renundefined 3 Replies Last reply Reply Quote 0
          Eaton Ren @droftarts
          @droftarts
          I completed all the information, thank you again for your reply.
          config.g
          FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.3 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2021-06-15 21:45:03
          X uses E2 (DRIVE 5), Y uses E3 (DRIVE 6)
          JSS57P integrated digital hybrid servo.pdf
            @droftarts
            I added pictures of the wiring.
            I designed an adapter board to facilitate the access of the motor signal line. The motor uses the common cathode connection method.
              @droftarts
              Today I use an oscilloscope to observe the pulse signal. It is found that there will be a pulse signal 50ms after the DIR signal. 50ms is too long, I wonder if this is the problem.
              mrehorstdmdundefined 1 Reply Last reply Reply Quote 0
              • mrehorstdmdundefined
                mrehorstdmd @Eaton Ren
                @eaton-ren You have direction hold time set to zero- that's not likely to work.
                I use iHSV servomotors in my sand table and have the timing set up like this:
                M569 P5 S1 R0 T4.0:5.0:6.0:12.0 ; drive 5 reverse, lo enable, timing parameters for servomotors
                M569 P6 S1 R0 T4.0:5.0:6.0:12.0 ; drive 6 reverse, lo enable, timing parameters for servomotors
                I'd bet they're using similar or even identical drivers in your motors and mine.
                I run these motors at 10k acceleration with speeds up to 1600 mm/sec with those timing parameters.
                Eaton Renundefined 1 Reply Last reply Reply Quote 2
                  Eaton Ren @mrehorstdmd
                  @mrehorstdmd Thanks for the help, I tried your T parameter and it didn't work. My client is very anxious, I can only use stepper motors. Today I changed them and used the default port. hope everything is fine.IMG_20211118_154416.jpg IMG_20211118_154424.jpg
                    @eaton-ren Maybe the problem is the voltage level on the step/dir/enable lines. I wired the step/dir/enable directly to the corresponding + and - step/dir/enable outputs on a Duet2 expansion board.
                    I did not use the alarm output...
                    Eaton Renundefined 1 Reply Last reply Reply Quote -1
                      @mrehorstdmd said in How to configure the closed-loop motor on duet 2:
                      After replacing the stepper motors, they worked perfectly. Soon I can deliver two printers to customers.
                      I hope the TMC2660 drive is stable, because I saw a layer shift yesterday.
                      • Shokiundefined Shoki referenced this topic
