    G29.g? Somehow?
    • Chrissundefined
      Chriss
      Hi *,
      I have the problem that I have some dependencies before I can execute G29 itself. So I wrote a macro and placed in in 0:/macros/30_blabla.g which I can execute easily. No problems so far. It happened a couple of times now that I have forgotten that (to many printer problems) and executed the G29 directly from the DWC menu at the top. That ended all the time in a nice hole in the PEI because at this time is the wrong endstop active. 😞
      It would be very nice if there would be the possibility to have something like a G29.g which will be executed if it is present or something like that.
      Cheers, Chriss
        jay_s_uk @Chriss
        @chriss create a file called mesh.g
        That's ran when G29 is ran.
        You can put your dependencies in there followed by G29 S0
        • Chrissundefined
          Chriss
          @jay_s_uk Thanks, I will test that and I will play a bit with that.
          Is there a list of all files RRF is using/possible?
          I search that list almost every time I configure a new printer.
          Cheers, Chriss
            jay_s_uk @Chriss
            @chriss here you go
            https://duet3d.dozuki.com/Wiki/Macros
            Chrissundefined 1 Reply Last reply Reply Quote 1
            • Chrissundefined
              Chriss @jay_s_uk
              @jay_s_uk
              Thanks.... bookmarked it. 🙂
