3.4.0-b6 – Delta – print leaning/moving on Y+ and Z+
I haven't found any post reporting this issue on the Beta6; hopefully I'm not making a duplicate if that's the case, please, point me to the other thread.
I discovered this issue today; I did a few prints before with no problem.
I start the print, the skirt and the few first wall lines for the holes are fine but it as soon as it starts to print the wall lines for the part itself the effector starts to move up (Z+) and on back (Y+).
On the screenshot below the issue only start when printing the line around the red arrows.
I rolled back the firmware to 3.3 and it prints perfectly.Pictures taken facing the printer
Printing taken from the left of the printer - it shows the offset on Y+
M122 before print
=== Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.0beta6 (2021-11-06 11:37:41) running on Duet WiFi 1.02 or later Board ID: 08DGM-9T6BU-FG3SJ-6JKDA-3S46N-1VWZD Used output buffers: 3 of 24 (24 max) === RTOS === Static ram: 23772 Dynamic ram: 76760 of which 16 recycled Never used RAM 11436, free system stack 118 words Tasks: NETWORK(ready,13.7%,222) ACCEL(notifyWait,0.0%,350) HEAT(notifyWait,0.0%,326) Move(notifyWait,0.0%,305) MAIN(running,86.2%,440) IDLE(ready,0.0%,30), total 100.0% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 01:12:38 ago, cause: software Last software reset at 2021-11-20 13:08, reason: User, GCodes spinning, available RAM 7412, slot 1 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x0c Aux0 errors 0,0,0 Step timer max interval 0 MCU temperature: min 32.3, current 33.5, max 36.0 Supply voltage: min 23.8, current 24.0, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 0/0, heap memory allocated/used/recyclable 0/0/0, gc cycles 0 Driver 0: pos 123399, standstill, SG min 0 Driver 1: pos 123399, standstill, SG min 0 Driver 2: pos 123399, standstill, SG min 0 Driver 3: pos 0, standstill, SG min n/a Driver 4: pos 0, standstill, SG min n/a Driver 5: pos 0 Driver 6: pos 0 Driver 7: pos 0 Driver 8: pos 0 Driver 9: pos 0 Driver 10: pos 0 Driver 11: pos 0 Date/time: 2021-11-20 14:20:44 Cache data hit count 4294967295 Slowest loop: 10.74ms; fastest: 0.17ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 10 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 3.0ms, write time 3.9ms, max retries 0 === Move === DMs created 83, segments created 4, maxWait 4145314ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 5, completed 5, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 0 is on, I-accum = 0.2 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty === Network === Slowest loop: 25.55ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions HTTP sessions: 1 of 8 - WiFi - Network state is active WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 0 WiFi firmware version 1.26 WiFi MAC address 60:01:94:2e:1b:d6 WiFi Vcc 3.39, reset reason Turned on by main processor WiFi flash size 4194304, free heap 25272 WiFi IP address 192.168.50.100 WiFi signal strength -54dBm, mode 802.11n, reconnections 0, sleep mode modem Clock register 00002002 Socket states: 0 0 0 0 0 0 0 0
M122 during the print when it starts to be off
=== Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.0beta6 (2021-11-06 11:37:41) running on Duet WiFi 1.02 or later Board ID: 08DGM-9T6BU-FG3SJ-6JKDA-3S46N-1VWZD Used output buffers: 3 of 24 (24 max) === RTOS === Static ram: 23772 Dynamic ram: 76760 of which 16 recycled Never used RAM 8076, free system stack 108 words Tasks: NETWORK(ready,14.4%,222) ACCEL(notifyWait,0.0%,350) HEAT(notifyWait,0.0%,326) Move(notifyWait,0.8%,283) MAIN(running,84.6%,127) IDLE(ready,0.1%,30), total 100.0% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 01:18:27 ago, cause: software Last software reset at 2021-11-20 13:08, reason: User, GCodes spinning, available RAM 7412, slot 1 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x0c Aux0 errors 0,0,0 Step timer max interval 0 MCU temperature: min 33.1, current 34.7, max 34.9 Supply voltage: min 23.7, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 99/1, heap memory allocated/used/recyclable 2048/20/0, gc cycles 0 Driver 0: pos 61182, ok, SG min 0 Driver 1: pos 51624, ok, SG min 0 Driver 2: pos 61399, ok, SG min 0 Driver 3: pos 0, not present Driver 4: pos 0, standstill, SG min n/a Driver 5: pos 0 Driver 6: pos 0 Driver 7: pos 0 Driver 8: pos 0 Driver 9: pos 0 Driver 10: pos 0 Driver 11: pos 0 Date/time: 2021-11-20 14:26:34 Cache data hit count 4294967295 Slowest loop: 138.75ms; fastest: 0.12ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 9 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 3.3ms, write time 0.0ms, max retries 0 === Move === DMs created 83, segments created 25, maxWait 344843ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 1317, completed 1277, hiccups 71, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3 === AuxDDARing === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 0 is on, I-accum = 0.3 Heater 1 is on, I-accum = 0.5 === GCodes === Segments left: 1 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is doing "G1 X-49.746 Y29.495 E1.19542" in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty === Network === Slowest loop: 199.52ms; fastest: 0.08ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions HTTP sessions: 1 of 8 - WiFi - Network state is active WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 1 WiFi firmware version 1.26 WiFi MAC address 60:01:94:2e:1b:d6 WiFi Vcc 3.39, reset reason Turned on by main processor WiFi flash size 4194304, free heap 26736 WiFi IP address 192.168.50.100 WiFi signal strength -54dBm, mode 802.11n, reconnections 0, sleep mode modem Clock register 00002002 Socket states: 0 0 0 0 0 0 0 0
gcode File printed
SR - Adapter Duet 5 Mini.gcodeConfig.g file
config (7).gPlease, let me know if you would like additional information or if you have a pre-version to test.
Edit - Added a missing screenshot
@fred-y thanks for the report. I assume when switching back and forward from 3.3 to 3.4b6 you are keeping the config files the same and using the same gcode file to test with?
@fred-y your print is printing OK on my delta, running 3.4.0beta6+2. There were no changes to the motion system code between beta6 and beta6+2.
Please try switching to 3.4.0beta6 and (if necessary) back once more, to check whether the issue was related to the firmware upgrade.
@dc42 I changed the firmware back and forward many time and also tried different 3.4 beta versions, there the results:
3.3 -> ok
3.4.0beta3 -> ok
3.4.0beta4 -> fail
3.4.0beta5 -> fail
3.4.0beta6 -> failDisabling Input Shaping on beta6 doesn't change anything.
Let me know if there are additional tests you would like me to do.
@fred-y thanks for that info. After the error has appeared, when you next run M122 (without rebooting), are there any step errors shown in the Move diagnostics? The M122 report you posted originally didn't show any, but I don't know when you ran that. Note, after running M122 the step error count is cleared AFAIR.
Shutdown the printer, power it back, ran M122 for reference11/22/2021, 10:42:49 AM M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.0beta6 (2021-11-06 11:37:41) running on Duet WiFi 1.02 or later Board ID: 08DGM-9T6BU-FG3SJ-6JKDA-3S46N-1VWZD Used output buffers: 3 of 24 (20 max) === RTOS === Static ram: 23772 Dynamic ram: 76760 of which 16 recycled Never used RAM 11532, free system stack 184 words Tasks: NETWORK(ready,12.6%,228) ACCEL(notifyWait,0.0%,350) HEAT(notifyWait,0.0%,326) Move(notifyWait,0.0%,364) MAIN(running,85.5%,440) IDLE(ready,1.9%,30), total 100.0% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 00:00:49 ago, cause: power up Last software reset time unknown, reason: User, GCodes spinning, available RAM 8100, slot 0 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 Step timer max interval 0 MCU temperature: min 32.6, current 34.9, max 35.2 Supply voltage: min 23.9, current 24.0, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 0/0, heap memory allocated/used/recyclable 0/0/0, gc cycles 0 Driver 0: pos 120457, standstill, SG min n/a Driver 1: pos 120457, standstill, SG min n/a Driver 2: pos 120457, standstill, SG min n/a Driver 3: pos 0, standstill, SG min n/a Driver 4: pos 0, standstill, SG min n/a Driver 5: pos 0 Driver 6: pos 0 Driver 7: pos 0 Driver 8: pos 0 Driver 9: pos 0 Driver 10: pos 0 Driver 11: pos 0 Date/time: 2021-11-22 10:42:48 Cache data hit count 1765768262 Slowest loop: 7.46ms; fastest: 0.17ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 10 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 2.6ms, write time 0.0ms, max retries 0 === Move === DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty === Network === Slowest loop: 15.80ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions HTTP sessions: 1 of 8 - WiFi - Network state is active WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 0 WiFi firmware version 1.26 WiFi MAC address 60:01:94:2e:1b:d6 WiFi Vcc 3.39, reset reason Turned on by main processor WiFi flash size 4194304, free heap 22368 WiFi IP address 192.168.50.254 WiFi signal strength -55dBm, mode 802.11n, reconnections 0, sleep mode modem Clock register 00002002 Socket states: 0 0 0 0 0 0 0 0
Started the print, waited for the first layer to start failing and then ran again an M122 while still printing (not paused)
11/22/2021, 10:50:03 AM M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.0beta6 (2021-11-06 11:37:41) running on Duet WiFi 1.02 or later Board ID: 08DGM-9T6BU-FG3SJ-6JKDA-3S46N-1VWZD Used output buffers: 3 of 24 (24 max) === RTOS === Static ram: 23772 Dynamic ram: 76760 of which 16 recycled Never used RAM 8076, free system stack 110 words Tasks: NETWORK(ready,12.3%,228) ACCEL(notifyWait,0.0%,350) HEAT(notifyWait,0.0%,326) Move(notifyWait,0.5%,283) MAIN(running,87.1%,127) IDLE(ready,0.0%,30), total 100.0% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 00:08:03 ago, cause: power up Last software reset time unknown, reason: User, GCodes spinning, available RAM 8100, slot 0 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 Step timer max interval 0 MCU temperature: min 34.3, current 35.5, max 35.8 Supply voltage: min 23.7, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 99/1, heap memory allocated/used/recyclable 2048/20/0, gc cycles 0 Driver 0: pos 64325, ok, SG min 0 Driver 1: pos 55894, ok, SG min 0 Driver 2: pos 53751, ok, SG min 0 Driver 3: pos 0, ok, SG min 0 Driver 4: pos 0, standstill, SG min n/a Driver 5: pos 0 Driver 6: pos 0 Driver 7: pos 0 Driver 8: pos 0 Driver 9: pos 0 Driver 10: pos 0 Driver 11: pos 0 Date/time: 2021-11-22 10:50:02 Cache data hit count 4294967295 Slowest loop: 138.76ms; fastest: 0.11ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 9 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 2.5ms, write time 0.0ms, max retries 0 === Move === DMs created 83, segments created 25, maxWait 234750ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 902, completed 865, hiccups 46, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3 === AuxDDARing === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 0 is on, I-accum = 0.3 Heater 1 is on, I-accum = 0.5 === GCodes === Segments left: 1 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is doing "G1 F1200" in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty === Network === Slowest loop: 200.12ms; fastest: 0.08ms Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions HTTP sessions: 1 of 8 - WiFi - Network state is active WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 1 WiFi firmware version 1.26 WiFi MAC address 60:01:94:2e:1b:d6 WiFi Vcc 3.39, reset reason Turned on by main processor WiFi flash size 4194304, free heap 25520 WiFi IP address 192.168.50.254 WiFi signal strength -53dBm, mode 802.11n, reconnections 0, sleep mode modem Clock register 00002002 Socket states: 0 0 0 0 0 0 0 0
@fred-y can you post your config?
46 hiccups for 900 moves is quite high -
@jay_s_uk I was wondering about that number!
My config is at the bottom of the original post, it's a Predator with a Duet 2 wifi, Smart Effector, Magball and .9 steppers.
@fred-y nothing out of the ordinary in your config that I can see that would explain those hiccups
@jay_s_uk Thanks for checking it!
I'm finding odd that the issue only start to happen when the long walls are getting printed, the skirt and round walls looks to be properly printed at the correct height.
Everything before the red arrows are ok - I forgot to post this screenshot on my initial post.
@fred-y you had a high hiccup count in both M122s you posted so which could be an indication of a cause of the problem. I assume you are printing the skirt at a different speed than the perimeter of the first layer where you see the issue? as a test can you set the first layer to the same speed as the skirt, or vice versa?
@t3p3tony By looking at the gcode and also the gcode preview, the skirt and perimeters appear to be at the same speed 20mm/s (F1200).
Only the solid infill is at 30mm/s.
Is there a way to log when (line #) the hiccups happen?
Just wanted to check if there is any updates here, I did get another file had the same issue but this time immediately when the print start.
On the first gcode file it was after having printed the skirt and a few small features but still on the first layer.SR - Effector Spring-2-fail.gcode
M122 from beta6
11/29/2021, 9:29:25 PM M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.0beta6 (2021-11-06 11:37:41) running on Duet WiFi 1.02 or later Board ID: 08DGM-9T6BU-FG3SJ-6JKDA-3S46N-1VWZD Used output buffers: 4 of 24 (21 max) === RTOS === Static ram: 23772 Dynamic ram: 76760 of which 16 recycled Never used RAM 10956, free system stack 122 words Tasks: NETWORK(ready,14.8%,220) ACCEL(notifyWait,0.0%,350) HEAT(notifyWait,0.0%,310) Move(notifyWait,0.3%,283) MAIN(running,84.4%,127) IDLE(ready,0.5%,30), total 100.0% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 00:04:15 ago, cause: software Last software reset at 2021-11-27 18:55, reason: User, GCodes spinning, available RAM 11120, slot 1 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 Step timer max interval 0 MCU temperature: min 29.6, current 31.4, max 31.6 Supply voltage: min 23.7, current 23.9, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 0/0, heap memory allocated/used/recyclable 0/0/0, gc cycles 0 Driver 0: pos 65151, ok, SG min 0 Driver 1: pos 51461, ok, SG min 0 Driver 2: pos 55683, ok, SG min 0 Driver 3: pos 0, ok, SG min 0 Driver 4: pos 0, standstill, SG min n/a Driver 5: pos 0 Driver 6: pos 0 Driver 7: pos 0 Driver 8: pos 0 Driver 9: pos 0 Driver 10: pos 0 Driver 11: pos 0 Date/time: 2021-11-29 21:29:24 Cache data hit count 4294967295 Slowest loop: 216.29ms; fastest: 0.12ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 9 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 4.6ms, write time 3.0ms, max retries 0 === Move === DMs created 83, segments created 24, maxWait 122805ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 201, completed 195, hiccups 72, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3 === AuxDDARing === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 0 is on, I-accum = 0.3 Heater 1 is on, I-accum = 0.5 === GCodes === Segments left: 1 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is doing "G1 X107.193 Y-7.073 E66.50864" in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty === Network === Slowest loop: 213.13ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions HTTP sessions: 1 of 8 - WiFi - Network state is active WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 0 WiFi firmware version 1.26 WiFi MAC address 60:01:94:2e:1b:d6 WiFi Vcc 3.39, reset reason Turned on by main processor WiFi flash size 4194304, free heap 26736 WiFi IP address 192.168.50.254 WiFi signal strength -54dBm, mode 802.11n, reconnections 0, sleep mode modem Clock register 00002002 Socket states: 0 0 0 0 0 0 0 0
The fill prints well after rolling back to RRF3.3
M12211/29/2021, 9:39:21 PM M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later Board ID: 08DGM-9T6BU-FG3SJ-6JKDA-3S46N-1VWZD Used output buffers: 3 of 24 (19 max) === RTOS === Static ram: 23876 Dynamic ram: 76488 of which 12 recycled Never used RAM 11184, free system stack 112 words Tasks: NETWORK(ready,13.4%,252) ACCEL(notifyWait,0.0%,334) HEAT(delaying,0.0%,314) Move(notifyWait,0.2%,311) MAIN(running,85.9%,128) IDLE(ready,0.5%,29), total 100.0% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 00:03:48 ago, cause: software Last software reset at 2021-11-27 18:55, reason: User, GCodes spinning, available RAM 11120, slot 1 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 Step timer max interval 0 MCU temperature: min 32.0, current 33.2, max 33.6 Supply voltage: min 23.7, current 23.9, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 99/1, heap memory allocated/used/recyclable 2048/36/0, gc cycles 0 Driver 0: position 51925, ok, SG min/max 0/196 Driver 1: position 63275, ok, SG min/max 0/191 Driver 2: position 58898, ok, SG min/max 0/906 Driver 3: position 0, ok, SG min/max 0/66 Driver 4: position 0, standstill, SG min/max not available Driver 5: position 0 Driver 6: position 0 Driver 7: position 0 Driver 8: position 0 Driver 9: position 0 Driver 10: position 0 Driver 11: position 0 Date/time: 2021-11-29 21:39:20 Cache data hit count 4294967295 Slowest loop: 212.15ms; fastest: 0.11ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 9 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 3.0ms, write time 0.0ms, max retries 0 === Move === DMs created 83, maxWait 35546ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 1076, completed moves 1037, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 Heater 0 is on, I-accum = 0.1 Heater 1 is on, I-accum = 0.5 === GCodes === Segments left: 1 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is doing "G1 X43.263 Y-8.009 E29.37223" in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 187.35ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions HTTP sessions: 1 of 8 - WiFi - Network state is active WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 0 WiFi firmware version 1.26 WiFi MAC address 60:01:94:2e:1b:d6 WiFi Vcc 3.39, reset reason Turned on by main processor WiFi flash size 4194304, free heap 25520 WiFi IP address 192.168.50.254 WiFi signal strength -63dBm, mode 802.11n, reconnections 0, sleep mode modem Clock register 00002002 Socket states: 0 0 0 0 0 0 0 0
Please, let me know if I can do anything to help.
@fred-y
What if you reduce microstepping? (from 16 to 8). Isn't the hiccup count an indication of too many step pulses? -
@o_lampe Unfortunately, the same issue happen.
I changed
M350 X16 Y16 Z16 E16 I1
M92 X160.00 Y160.00 Z160.00 U400 E726
to
M350 X8 Y8 Z8 E16 I1
M92 X80.00 Y80.00 Z80.00 U400 E72611/30/2021, 8:11:36 AM M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.0beta6 (2021-11-06 11:37:41) running on Duet WiFi 1.02 or later Board ID: 08DGM-9T6BU-FG3SJ-6JKDA-3S46N-1VWZD Used output buffers: 10 of 24 (21 max) === RTOS === Static ram: 23772 Dynamic ram: 76760 of which 16 recycled Never used RAM 8100, free system stack 110 words Tasks: NETWORK(ready,12.6%,232) ACCEL(notifyWait,0.0%,350) HEAT(notifyWait,0.0%,307) Move(notifyWait,0.6%,283) MAIN(running,86.5%,127) IDLE(ready,0.3%,30), total 100.0% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 00:07:36 ago, cause: software Last software reset at 2021-11-30 08:03, reason: User, GCodes spinning, available RAM 11004, slot 1 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00417000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 Step timer max interval 0 MCU temperature: min 31.2, current 32.5, max 32.8 Supply voltage: min 23.7, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 99/1, heap memory allocated/used/recyclable 2048/36/0, gc cycles 0 Driver 0: pos 30667, ok, SG min 0 Driver 1: pos 27794, ok, SG min 0 Driver 2: pos 29655, ok, SG min 0 Driver 3: pos 0, ok, SG min 0 Driver 4: pos 0, standstill, SG min n/a Driver 5: pos 0 Driver 6: pos 0 Driver 7: pos 0 Driver 8: pos 0 Driver 9: pos 0 Driver 10: pos 0 Driver 11: pos 0 Date/time: 2021-11-30 08:11:35 Cache data hit count 4294967295 Slowest loop: 218.08ms; fastest: 0.12ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 9 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 3.5ms, write time 0.0ms, max retries 0 === Move === DMs created 83, segments created 24, maxWait 264309ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 1305, completed 1265, hiccups 37, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3 === AuxDDARing === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 0 is on, I-accum = 0.1 Heater 1 is on, I-accum = 0.5 === GCodes === Segments left: 1 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is doing "G1 X-49.368 Y9.851 E40.15928" in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty === Network === Slowest loop: 174.42ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions HTTP sessions: 1 of 8 - WiFi - Network state is active WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 0 WiFi firmware version 1.26 WiFi MAC address 60:01:94:2e:1b:d6 WiFi Vcc 3.39, reset reason Turned on by main processor WiFi flash size 4194304, free heap 26904 WiFi IP address 192.168.50.254 WiFi signal strength -55dBm, mode 802.11n, reconnections 0, sleep mode modem Clock register 00002002 Socket states: 0 0 0 0 0 0 0 0
@fred-y thanks for the additional example.
Can you post a photo or video of what happens when you print that one?EDIT: looks like I may not need that. -
@fred-y I have found and fixed the bug that was causing this. The fix will be in 3.4.0beta7. The hiccups were the clue.
@dc42 Thank you for the update, I started to be concerned that my board might be defective as I was the only one reporting this issue - I was close to test one from another printer or just buy another one.
Let me know if you have a pre-beta version you want to be validated, I can do it fairly quickly.
undefined Fred-Y referenced this topic
