    M566 P1 vs pressure advance
    Beta Firmware
    938
    • AlexThundefined
      AlexTh
      Hello. M566 P1 (jerk policy 1) does not work together with M572 D0 S0.11 (pressure advance). If pressure advance is turned off, then it prints normally.
      Board: fly_e3_pro (STMWiFi)
      Firmware: RepRapFirmware for STM32F4 based Boards 3.4.0beta6_1 (2021-11-06)
      Duet WiFi Server Version: 1.26-08S-D
        How does it not work? Can you be more specific?
        AlexThundefined 1 Reply Last reply Reply Quote 0
        • AlexThundefined
          AlexTh @Phaedrux
          @phaedrux Re-extrusion during the printing of the filling at the "Line" in Cura. Underextrusion after retraction and transition to printing the next model on the table.
            Are you also using input shaping?
            Can you post a photo of what you're seeing?
            AlexThundefined 6 Replies Last reply Reply Quote 0
            • AlexThundefined
              AlexTh @Phaedrux
              @phaedrux The printer is currently in operation. I'll take a photo tomorrow. I didn't understand how to insert photos here.
              • AlexThundefined
                AlexTh @Phaedrux
                @phaedrux Input shaping is not used.
                • AlexThundefined
                  AlexTh @Phaedrux
                  @phaedrux I understood how to insert photos. I didn't see on the phone that the chat functionality doesn't fit on the screen
                  • AlexThundefined
                    AlexTh @Phaedrux
                    @phaedrux Screenshot_20211123-115612_Samsung Internet.jpg 20211123_120015.jpg 20211123_115949.jpg
                    M566 P1 vs M572 D0 S0.11
                    • AlexThundefined
                      AlexTh @Phaedrux
                      @phaedrux
                      M566 P0 vs M572 D0 S0.11
                      • AlexThundefined
                        AlexTh @Phaedrux
                        @phaedrux
                        • AlexThundefined
                          AlexTh @AlexTh
                          @alexth
                          M566 P1 vs M572 D0 S0.11 - Incorrect printing occurs at these values.
                          This is visible after moving to a new part.
                          • T3P3Tonyundefined
                            T3P3Tony administrators @AlexTh
                            @alexth is this behaviour different in RRF3.3?
                            www.duet3d.com
                            • AlexThundefined
                              AlexTh @T3P3Tony
                              @t3p3tony I am a new RRF user. I did not install other versions.
                              T3P3Tonyundefined PCRundefined 2 Replies Last reply Reply Quote 0
                              • T3P3Tonyundefined
                                @alexth the board you had probably had an older version initially. Maybe @jay_s_uk can advise as this is a mellow board not a duet.
                                www.duet3d.com
                                • PCRundefined
                                  PCR @AlexTh
                                  @alexth you have to tune PA with the specific jerk settings and policy.
                                  • AlexThundefined
                                    AlexTh @PCR
                                    @pcr I can't find the PA value, because the perimeter prints well, and only the beginning of the line with high underextrusion.
                                    PCRundefined 1 Reply Last reply Reply Quote 0
                                    • PCRundefined
                                      PCR @AlexTh
                                      @alexth which printer? A PA value of 0,1 is quite high
                                      PCRundefined AlexThundefined 2 Replies Last reply Reply Quote 0
                                      • PCRundefined
                                        PCR @PCR
                                        @pcr for a direct drive
                                        • AlexThundefined
                                          AlexTh @PCR
                                          @PCR
                                          Flying Bear 5
                                          Long direct
                                          ~10 cm
                                          • PCRundefined
                                            PCR @AlexTh
                                            @alexth start with S0 and increase?
