    M566 P1 vs pressure advance
    Beta Firmware
    1.0k
    • AlexThundefined
      AlexTh @Phaedrux
      @phaedrux
      M566 P1 vs M572 D0 S0
      • AlexThundefined
        AlexTh @AlexTh
        @alexth
        M566 P1 vs M572 D0 S0.11 - Incorrect printing occurs at these values.
        This is visible after moving to a new part.
          T3P3Tony administrators @AlexTh
          @alexth is this behaviour different in RRF3.3?
          AlexThundefined 1 Reply Last reply Reply Quote 0
          • AlexThundefined
            AlexTh @T3P3Tony
            @t3p3tony I am a new RRF user. I did not install other versions.
            T3P3Tonyundefined PCRundefined 2 Replies Last reply Reply Quote 0
              @alexth the board you had probably had an older version initially. Maybe @jay_s_uk can advise as this is a mellow board not a duet.
              • PCRundefined
                PCR @AlexTh
                @alexth you have to tune PA with the specific jerk settings and policy.
                • AlexThundefined
                  AlexTh @PCR
                  @pcr I can't find the PA value, because the perimeter prints well, and only the beginning of the line with high underextrusion.
                  PCRundefined 1 Reply Last reply Reply Quote 0
                  • PCRundefined
                    PCR @AlexTh
                    @alexth which printer? A PA value of 0,1 is quite high
                    PCRundefined AlexThundefined 2 Replies Last reply Reply Quote 0
                    • PCRundefined
                      PCR @PCR
                      @pcr for a direct drive
                      • AlexThundefined
                        AlexTh @PCR
                        @PCR
                        Flying Bear 5
                        Long direct
                        ~10 cm
                        • PCRundefined
                          PCR @AlexTh
                          @alexth start with S0 and increase?
                          • AlexThundefined
                            AlexTh @PCR
                            @pcr I've tried different values. Can't set up.
                            But I'll try again
                            • AlexThundefined
                              AlexTh @PCR
                              @pcr M572 D0 S0.07 is a more appropriate value, there is no underextrusion at the beginning of the line, but the outer corners of the model are slightly outward. For the perimeter, this value is not ideal.
                              • PCRundefined
                                PCR @AlexTh
                                @alexth please print a tuning tower from S0 to S0.1 and show the pictures
                                • AlexThundefined
                                  AlexTh @PCR
                                  @pcr Give me a link to the test
                                  • PCRundefined
                                    PCR @AlexTh
                                    @alexth https://duet3d.dozuki.com/Wiki/Pressure_advance
                                    or
                                    https://forum.duet3d.com/topic/25764/pressure-advance-tuning-with-conditional-g-code?_=1635840827943
