    Duet 3 6HC com port doesn't appear (Windows)
    Using Duet Controllers
    332
    • Coen_lundefined
      Coen_l
      Hi all,
      My name is Coen and last Wednesday I recieved my first Duet3D hardware.
      • PanelDue met 7"
      • Delta Smart Effector v2.0
      • Duet 3 Mainboard 6HC v1.01
      I'm really curious how my Delta will preform with his new brain.
      Unfortunately I'm running into a problem. I hope someone can point me in the right direction. I wanted to go through the steps via "Getting Started" but can't get past step 1
      My New Duet 3 6HC is not recognized by my laptop. I have tried different USB cables and laptops. With the same result, no COM-port response and no confirmation sound when a USB is plugged into the laptop.
      Who has advice.
      Kind regards,
      Coen
      jay_s_ukundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @Coen_l
        @coen_l you can probably get away without plugging the 6HC into your laptop.
        Just load up a config on the SD card making sure it has M552 S1 and you should be able to connect to it over a network.
        From there, it can be managed through DWC
        Coen_lundefined 1 Reply Last reply Reply Quote 0
        • Coen_lundefined
          Coen_l @jay_s_uk
          @jay_s_uk Sorry, I can't reach the board.
            jay_s_uk @Coen_l
            @coen_l is it too far away? 😁
            can you give a bit more info?
            whats on the sd card?
            how are you powering the board?
            whats in your config file?
            • Coen_lundefined
              Coen_l @jay_s_uk
              @jay_s_uk I guess 😉 It's all very new to me. Sorry
              • SD card: all original files on SD card supplied with the Duet 3. Date of files 15-2-2021 + my delta config
              • Connected to a 12v HP server power supply.
              ; Configuration file for Duet 3 (firmware version 3.3)
              ; generated by RepRapFirmware Configuration Tool v3.3.10 on Sat Nov 27 2021 22:45:11 GMT+0100 (Midden-Europese standaardtijd)
              M550 P"Opiliones" ; set printer name
              M665 R267 L525 B175 H700 ; Set delta radius, diagonal rod length, printable radius and homed height
              M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
              M551 P"DraadLoos" ; set password
              M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP
              M586 P0 S1 ; enable HTTP
              M586 P1 S0 ; disable FTP
              M586 P2 S0 ; disable Telnet
              M569 P0.1 S1 ; physical drive 0.1 goes forwards
              M569 P0.2 S1 ; physical drive 0.2 goes forwards
              M569 P0.3 S1 ; physical drive 0.3 goes forwards
              M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping
              M92 X80.00 Y80.00 Z80.00 E663.00 ; set steps per mm
              M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
              M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
              M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
              M906 X1500 Y1500 Z1500 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
              M84 S30 ; Set idle timeout
              M208 Z0 S1 ; set minimum Z
              M574 X2 S1 P"io0.in" ; configure switch-type (e.g. microswitch) endstop for high end on X via pin io0.in
              M574 Y2 S1 P"io1.in" ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin io1.in
              M574 Z2 S1 P"io2.in" ; configure switch-type (e.g. microswitch) endstop for high end on Z via pin io2.in
              M558 P5 R0.4 C"io3.in+io3.out" H5 F1200 T6000 ; set Z probe type to effector and the dive height + speeds
              G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
              M557 R85 S20 ; define mesh grid
              M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
              M143 H0 S100 ; set temperature limit for heater 0 to 100C
              M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
              M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1
              M143 H1 S250 ; set temperature limit for heater 1 to 250C
              M950 F0 C"out4" Q500 ; create fan 0 on pin out4 and set its frequency
              M950 F1 C"out5" Q500 ; create fan 1 on pin out5 and set its frequency
                Phaedrux Moderator @Coen_l
                @coen_l said in Duet 3 6HC com port doesn't appear (Windows):
                Do any of the LEDs on the board light up when you connect it to USB?
                It can be very picky about USB cables and ports.
                • Coen_lundefined
                  Coen_l @Phaedrux
                  @phaedrux same LEDs light up when the board is connected to 12v
                    Can you try working through this guide?
                    https://duet3d.dozuki.com/Wiki/What_to_do_if_your_Duet_won't_respond
                    • Coen_lundefined
                      Coen_l @Phaedrux
                      @phaedrux
                      Step: "If no port appears, or you get a Windows error message several seconds after you connect the Duet via USB, try connecting it to a different USB port, and try using a different USB cable, making sure that the USB cable is a data cable (some USB cables provide power only)."
                      No restult.
                      Step: "If the port still doesn't appear on the PC
                      If neither port is shown, then the Duet may be faulty or it may not have valid firmware installed. With USB power applied, erase the firmware. Only erase the firmware if your board is completely unresponsive, or if instructed to do so by Duet3D."
                      If I'm seeing correctly, I'll have to clear the Firmware then. Spooky! what happens to the warranty?
                        I don't understand the question. Reflashing the firmware and warranty are not related. If we can't get it up and running your warranty would then take over. Fear not.
                        To try clearing the firmware and getting it to show up as a firmware flashing port in windows follow this: https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_To_update_via_USB_using_a_Windows_host
                        • Coen_lundefined
                          Coen_l @Phaedrux
                          @phaedrux
                          It's good to hear that firmware and warranty are not related. Then I can go through the steps with a calmer feeling. I'm going to give it a try in a minute. Gather some courage first 🙂
                          Thank you for your help.
                            There's little to worry about. It's basically impossible to brick a Duet with a firmware update. Even a failed one.
                            The trick will be getting it to show up in windows as a USB device.
                            Do you happen to have a powered USB hub?
                            • Coen_lundefined
                              Coen_l @Phaedrux
                              @phaedrux said in Duet 3 6HC com port doesn't appear (Windows):
                              My laptop has ss usb ports.
                              Just completed the firmware flash successfully thanks to your help. The Duet is now also visible in device manager.
                              It is correct that the "Status" LED is blinking right?
                              Thank you very very much for your help!
                                dc42 administrators @Coen_l
                                @coen_l I'm glad you got it working. It's normal for Duet 3 boards to blink that red LED at 1Hz. The reason they do is so that when you connect expansion boards via CAN bus, you can see when they are communicating because the red LEDs all blink in sync.
                                • Coen_lundefined
                                  Coen_l @dc42
                                  @dc42 Thanks for the info.
                                  Just signed up with DWC, very nice interface. Now I can continue with the next step, installing the electronics and connecting.
                                  It's amazing how quickly help is provided. I really appreciate it.
