    Dumbfounded ! Firmware bug in 3.4 beta 6?
    Beta Firmware
    2.4k
    • GeneRisiundefined
      GeneRisi
      I am using Simplify3d and firmware 3.4 beta 6. I have set the perimeter tool as Tool 1 and the infill tool as Tool 0. The infill does not line up with the perimeter. The tools have different offsets in config.g (and it's as if the offset is not applied when the tool is switched).
      When I use Tool 0 as the perimeter and Tool 1 as the infill, it works! I edit the gcode by hand to switch the T0 and T1 lines and that's the only difference. Is this a firmware bug? I could fill this post with config.g, the Tpre, Tpost and Tfree for both tools and the gcode but I don't know if it will suggest anything since the order of the tools makes the difference.
      Please advise... thanks!
      • GeneRisiundefined
        GeneRisi
        @dc42 I found the problem.
        When tool T1 was being returned, the Y "parking" coordinate was off by 1 mm. The tool parking location didn't budge but the firmware thought that the tool location was 1mm beyond where it actually was. The machine is a corexy (E3D), so even though only the Y coordinate was off, I suspect it affected both the x and y location from the the firmware's perspective.
          It might not hurt to share the config files to let us better try and reproduce.
          You could also try reverting versions and seeing when the behaviour started happening.
          GeneRisiundefined 1 Reply Last reply Reply Quote 0
            I think you may be affected by this change in B6
            Upgrade notes:
            Important! After changing tool, RRF no longer moves the new tool head to the coordinates at which the old tool head was at when the Tn command was actioned. In most situations this should not matter, because GCode generators usually generate commands to move to the correct XYZ position after generating a Tn command. Usually, they restore XY before Z. However, Cura does it the other way round, which risks dragging the tool head across the print. Therefore when using Cura, or in any other situations in which you want to restore the old behaviour, we suggest you add command G1 R2 X0 Y0 Z2 Fxxx followed by G1 R2 Z0 Fxxx to the end of your tpost#.g files, if you don't already use those or similar commands.
            • GeneRisiundefined
              GeneRisi @Phaedrux
              @phaedrux OK !
              config.g
              ; Configuration file for Duet WiFi / Ethernet
              ; *** General preferences ***
              M111 S0 						; Debugging off
              M550 P"ToolChanger" 			; Set machine name
              G21 							; Work in millimetres
              G90 							; Send absolute coordinates...
              M83 							; ...but relative extruder moves
              M555 P2 						; Set firmware compatibility to look like Marlin
              ; *** Network ***
              M552 S1							; Enable Networking
              M586 P0 S1 						; Enable HTTP
              M586 P1 S1 						; Enable FTP
              M586 P2 S0 						; Disable Telnet
              ; *** Kinematics ***
              M667 S1 					; Select CoreXY mode
              ; *** Endstops ***
              M574 X1 P"xstop" S1              					; Set X endstop as active high switch
              M574 Y1 P"ystop" S1                  				; Set Y endstop as active high switch
              M574 Z1 S2 											; Set Z endstop probe
              ;	note that M574 not used here for A or C
              M915 C S5 F0 H200									; Coupler end stop is stall
              M915 A S10 F0 H200									; Wiper "A" end stop is stall
              M558 P8 C"zstop" X0 Y0 Z2 H3 F360:180 I0 T20000 	; Set Z probe type to switch, the axes for which it is used and the dive height + speeds
              G31 P200 X0 Y0 Z0	 								; Set Z probe trigger value, offset and trigger height
              ; *** Bed Leveling ***
              M557 X10:290 Y20:180 S40 			; Define mesh grid
              M376 H15							; bed compensation taper
              if !exists(global.freshMesh)
              	global freshMesh = false
              else
              	set global.freshMesh = false
              G29 Q2								; turn off bed mesh compensation (shouldn't be on, but ...)
              ; *** Drive direction ***
              M569 P0 S0 					; Drive 0 X
              M569 P1 S0 					; Drive 1 Y
              M569 P2 S1 					; Drive 2 Z
              M569 P3 S1 					; Drive 3 E0 - something strange here
              M569 P4 S1 					; Drive 4 E1
              M569 P5 S1 					; Drive 5 E2
              M569 P6 S1 					; Drive 6 E3
              M569 P7 S0 					; Drive 7 COUPLER
              M569 P8 S1 					; Drive 8 Wiper "A"
              M569 P9 S0 					; Drive 9 UNUSED
              ; *** Drive Mapping ***
              M584 X0 Y1 Z2 A8 C7 E3:4:5:6 		; Apply custom drive mapping
              ; *** AXES min and max ***
              M208 X-27:330 Y-49:243 Z0:300 A0:43 C0:500 S0 	; Set axis maxima & minima
              ; *** Stepping ***
              M92 X100 Y100 Z1600					; Set steps per mm at default 1/16 microstepping
              M350 X16 Y16 Z16 I1					; Configure microstepping with interpolation
              M350 E16:16:8:16 A16 C8 I1 			; Configure microstepping without interpolation except for Extruder 3
              M92 C100 A400 E655:655:417:409		; Set steps per mm at just defined microstepping
              ; *** Motion Settings ***
              M566 X400 Y400 Z8 A8 C2 E300:300:300:300					; Set maximum instantaneous speed changes (mm/min)
              M203 X35000 Y35000 Z1200 A1200 C5000 E3600:3600:3600:3600	; Set maximum speeds (mm/min)
              M201 X6000 Y6000 Z400 A400 C400 E600:800:600:5000			; Set accelerations (mm/s^2)
              ;M593 F48													; cancel ringing at 50Hz (https://forum.e3d-online.com/threads/accelerometer-and-resonance-measurements-of-the-motion-system.3445/)
              ; *** Drive Currents ***
              ;M906 X2000 Y2000 Z1330 C400 E1000:1680:1680:1380 I30 	; motor currents (mA) maxes
              M906 X1400 Y1400 I30
              M906 E1200:650:500:1380 I10
              M906 A700 C400 I10
              M906 Z1250 I70
              M84 S120 												; Set idle timeout
              ; *** PanelDue 5i ***
              M575 P1 S1  B57600										; set baud rate to PanelDue 5
              ; *** Define Tools ***
              ; *** *** > Bed <
              M308 S0 P"bedtemp" Y"thermistor" A"bed" T100000 B4138 C0	; Thermistor
              M950 H0 C"bedheat" T0										; Heater
              M140 H0														; define the bed heater
              M143 H0 S225 												; Set temperature limit to 225C (bed)
              M307 H0 R1.001 C428.841:428.841 D10.89 S1.00 V24.4 B0 I0	; set PID parameters
              ; *** *** > Tool 0 <
              M308 S1 P"spi.cs1" Y"rtd-max31865" A"T0" F60 				; PT100
              M950 H1 C"e0heat" T1										; Heater
              M143 H1 S390												; Set temperature limit to 390C
              M307 H1 R1.631 C239.974:239.974 D4.07 S1.00 V24.3 B0 I0		; set PID parameters
              M950 F1 C"fan1"												; HE fan
              M106 P1 S255 H1 T70
              M950 F2 C"fan2"												; PCF fan
              M106 P2 S0
              M569 P3 S1 													; Extruder Stepper
              M563 P0 D0 H1 F2 											; Define tool
              M568 P0 R0 S0 												; Reset initial tool active and standby temperatures to 0C
              G10 P0 X-9 Y39 Z-5.04										; Define Tool Offset; homed and leveled cold, measured at bed=85c, nozzle=230c
              M572 D0 S0.02												; pressure advance for Orbiter
              ; *** *** > Tool 1 <
              M308 S2 P"spi.cs2" Y"rtd-max31865" A"T1" F60				; PT100
              M950 H2 C"e1heat" T2										; Heater
              M143 H2 S390 												; Set temperature limit to 390C
              M307 H2 R1.940 C222.050:222.050 D5.17 S1.00 V24.3 B0 I0		; set PID parameters
              M950 F3 C"duex.fan3"										; HE fan
              M106 P3 S255 H2 T70
              M950 F4 C"duex.fan4"										; PCF fan
              M106 P4 S0
              M569 P4 S1 													; Extruder Stepper
              M563 P1 D1 H2 F4 							    			; Define tool
              M568 P1 R0 S0 												; Reset initial tool active and standby temperatures to 0C
              ;G10 P1 X-10.3 Y38.2 Z-4.94									; Define Tool Offset
              G10 P1 X-10.45 Y37.9 Z-4.94									; Define Tool Offset
              ;G10 P1 x-9 Y39 z-4.94
              M572 D1 S0.02												; pressure advance for Orbiter
              ; *** *** > Tool 2 (unpopulated) <
              ;M308 S3 P"spi.cs3" Y"rtd-max31865" A"T2" F60				; PT100
              ;M950 H3 C"duex.e2heat" T3									; Heater
              ;M143 H3 S390												; Set temperature limit to 390C
              ;M950 F5 C"duex.fan5"										; HE fan
              ;M106 P5 S255 H3 T70
              ;M950 F6 C"duex.fan6"										; PCF fan
              ;M106 P6 S0
              ;M569 P5 S1 												; Extruder Stepper
              ;M563 P2 D2 H3 F6 											; Define tool
              ;G10 P2 X0 Y0 Z0 											; Reset tool axis offsets
              ;G10 P2 R0 S0 												; Reset initial tool active and standby temperatures to 0C
              ;G10 P2 X-9 Y39 Z-5											; Define Tool Offset
              ; *** *** > Tool 3 (Hemera) <
              M308 S4 P"spi.cs4" Y"rtd-max31865" A"T3" F60				; PT100
              M950 H4 C"duex.e3heat" T4									; Heater
              M143 H4 S390 												; Set temperature limit to 390C
              ;M307 H4 ...												; Set PID values
              M950 F7 C"duex.fan7"										; HE fan
              M106 P7 S255 H4 T70
              M950 F8 C"duex.fan8"										; PCF fan
              M106 P8 S0
              M569 P6 S1 													; Extruder Stepper
              M563 P3 D3 H4 F8 											; Define tool
              M568 P3 R0 S0 												; Reset initial tool active and standby temperatures to 0C
              ;G10 P3 X20.3 Y44.1 Z-6.00									; z was -6.06
              G10 P3 X19.65 Y43.65 Z-6.00									; z was -6.06
              ;M572 D3 S0.07												; ? Pressure advance ???
              ; *** Accelerometer ***
              M955 P0 C"duex.cs5+duex.cs6"
              ; *** Define Servos ***
              ;  > Wiper A
              M950 P0 C"duex.pwm4" Q50
              ; *** Stepper noise tuning
              ;M569 P0 F1 Y10:00
              ;M569 P1 F12 Y10:00
              ;M569 P2 F6 Y05:03
              ; M501
              ; *** Actions ***
              T-1									;de-select all tools
              ; finis
              T0 free, pre and post files
              ; tfree0.g
              ; called when tool 0 is freed
              ;Drop the bed
              G91
              G1 Z5 F1000
              G90
              ;Move In
              G53 G1 X-4.2 Y150 F50000
              G53 G1 Y200 F50000
              G53 G1 Y220 F50000
              G53 G1 Y241.5 F2000
              ;Open Coupler
              M98 P/macros/Coupler - Unlock
              ;Move Out
              G53 G1 Y175 F2000
              G29 Q2				; disable bed mesh compensation
              ; finis
              ; tpost0.g
              ; called after tool 0 has been selected
              ;heatup
              M116 P0
              ;prime nozzle
              ;M98 Pprime.g
              ;mesh levelling on
              G29 Q1
              ;PCF fan on
              ;M106 P2 S255
              ; tpre0.g
              ; called before tool 0 is selected
              if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed
                M99
              ;Ensure no tool is selected
              if state.currentTool > -1
                T-1
              ;  M98 P{"tfree"^state.currentTool^".g"}
              G90
              if !move.axes[3].homed
                M98 P"homec.g"						; Home the coupler if not already homes
              M98 P"/macros/Coupler - Unlock"			;Unlock Coupler
              ;Move to location
              G53 G1 X-4.2 Y200 F50000
              ;Move in
              G53 G1 Y230 F50000
              ;Collect
              G53 G1 Y241.5 F2500
              ;Close Coupler
              M98 P"/macros/Coupler - Lock"
              ;WARNING! WARNING! WARNING! WARNING! WARNING! WARNING! WARNING! WARNING! WARNING! WARNING! WARNING! WARNING!
              ;if you are using non-standard length hotends ensure the bed is lowered enough BEFORE undocking the tool!
              G91
              G1 Z10 F1000
              G90
              ;Move Out
              G53 G1 Y175 F2000
              Same files for T1:
              ; tfree1.g
              ; called when tool 1 is freed
              ;Drop the bed
              G91
              G1 Z5 F1000
              G90
              ;Move In
              G53 G1 X85.3 Y150 F50000
              G53 G1 Y200 F50000
              G53 G1 Y220 F50000
              G53 G1 Y241 F5000
              ;Open Coupler
              ;fan off
              M106 P4 S0
              ;Move Out
              G53 G1 Y175 F5000
              ; finis
              ; tpre1.g
              ; called before tool 1 is selected
                T-1
              ;Unlock Coupler
              ;Move to location
              G53 G1 X85.3 Y200 F50000
              ;Move in
              G53 G1 Y230 F50000
              ;Collect
              G53 G1 Y242.5 F2500
              ;Close Coupler
              M98 P/macros/Coupler - Lock
              G91
              G1 Z10 F1000
              G90
              ;Move Out
              G53 G1 Y150 F4000
              ; tpost1.g
              ; called after tool 1 has been selected
              ;heatup
              M116 P1
              ;prime nozzle
              ;M98 Pprime.g
              ;mesh levelling on
              G29 Q1
              ;PCF fan on
              ;M106 P4 S255
              test.gcode
              • GeneRisiundefined
                GeneRisi @Phaedrux
                @phaedrux I was restoring Z but not X and Y because the next G1 command would change the position of the tool anyway, so 1 line might not get drawn properly but the following lines should be ok as long as the G1 command included x and Y coordinates. Right?
                  I'm not sure, but Putting G1 R1 X0 Y0 Z0 at the end of the tpost#.g file would fix that if it is the issue you're having.
                  GeneRisiundefined 3 Replies Last reply Reply Quote 0
                  • GeneRisiundefined
                    GeneRisi @Phaedrux
                    @phaedrux I'll try it
                    • GeneRisiundefined
                      GeneRisi @Phaedrux
                      @phaedrux I think you meant to say R2 and not R1, correct?
                        dc42 administrators @GeneRisi
                        @generisi said in Dumbfounded ! Firmware bug in 3.4 beta 6?:
                        Correct, it should be R2. The mistake is actually mine, not the fault of @Phaedrux !
                        • GeneRisiundefined
                          GeneRisi @Phaedrux
                          @phaedrux "G1 R2 ..." did not fix the problem. Maybe a firmware issue...
                          I also tried starting with T3 and then using T0 and that worked correctly, so two sequences worked T0, T1 and T3,T0. T1,T0 does not work as expected.
                          A Former User? T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
                          • A Former User?
                            A Former User @GeneRisi
                            @generisi
                            I have something similar but till now no idea what's wrong.
                            How about changing tool outside the print?
                            • GeneRisiundefined
                              GeneRisi @A Former User
                              @gruna-studio It takes a fair amount of gcode to change the tools. Each tool has its own unique set of offsets from the system coordinates which the firmware manages.
                              • T3P3Tonyundefined
                                T3P3Tony administrators @GeneRisi
                                what are the differences between those free, pre and post files?
                                www.duet3d.com
                                • GeneRisiundefined
                                  GeneRisi @T3P3Tony
                                  @t3p3tony Hi Tony - I have included those files in the post previously. I can't see a difference that would explain it.
                                  • T3P3Tonyundefined
                                    G29 Q1
                                    G29 Q2
                                    These are wrong - Should be G29 S1/S2 - although i don't think that's the cause of the issue.
                                    I assume you now have :
                                    G1 R2 X0 Y0 Z2
                                    G1 R2 Z0
                                    at the end of all the tpost#.g files?
                                    can i check T0 -> T1 works but T1 -> T0 does not work? What if you just command the tool changes through the console sending:
                                    T-1
                                    T0
                                    G1 X100 Y100 Z0
                                    T1
                                    G1 X100 Y100 Z0
                                    T0
                                    G1 X100 Y100 Z0
                                    ..etc
                                    repeatedly does the pickup point or the position X100 Y100 Z0 differ between the tools?
                                    www.duet3d.com
                                    • GeneRisiundefined
                                      GeneRisi @T3P3Tony
                                      @t3p3tony Hi Tony - I have my own "mesh.g" macro that allows me to also use "Q1" and "Q2" as inputs. I use the macro to check that the bed mesh in use has been created after the most recent system reset and is not being used if it was created some time before the most recent reset.
                                      ; mesh.g
                                      ; Redefining G29 behavior
                                      ; New parameter Q is used as a substitute for S so that this macro is called
                                      ; 	no parms or Q0 means probe mesh, save it but don't load it now
                                      ; 	Q1 means use mesh compensation if is fresh
                                      ; 	Q2 means disable mesh compensation
                                      ;       global.freshMesh set to false in config.g
                                      var qVal = 0
                                      if exists(param.Q)
                                      	set var.qVal = param.Q
                                      if var.qVal = 0
                                      	if !move.axes[0].homed | !move.axes[1].homed | !move.axes[2].homed
                                      		abort "Home all axes before running mesh probes"
                                      	else
                                      		G91;
                                      		G1 Z5 F500
                                      		G90;
                                      		G29 S2 ; make sure mesh compensations is off
                                      		G1 X150 Y100 F3000
                                      		G30 ;  get fresh Z=0 for current conditions
                                      		set global.freshMesh = true
                                      elif var.qVal = 1 & global.freshMesh = false
                                      	abort "Trying to use old height map, that's not ok right now"
                                      echo "G29 S", {var.qVal}
                                      G29 S{var.qVal}
                                      if var.qVal = 0
                                      	G29 S2					; disable mesh compensation for now if no parms or mesh probed and saved
                                      ; finis
                                      Also, is there a reason why you did not combine the two "G1 R2 ..." commands into a single command?
                                      I will try your suggestion. Thanks!
                                      T3P3Tonyundefined GeneRisiundefined 2 Replies Last reply Reply Quote 0
                                      • T3P3Tonyundefined
                                        ok i did not realise that - nice use case!
                                        restoring it in the way I showed, with some Z lift first, is what we recommend for most use cases as it means the last axis to move into position will be Z, so there is less change of the tool dragging across the top of the print as the position is restored.
                                        www.duet3d.com
                                        • GeneRisiundefined
                                          GeneRisi @GeneRisi
                                          @generisi There are either 2 or 3 contact spots checked very unscientifically with double stick tape on the bed when alternating T1, T0, T1, T0, ...
                                          • GeneRisiundefined
                                            GeneRisi
                                            @t3p3tony Here is a simple print file that demonstrates T1,T0,T1,T0:
                                            G90
                                            M83
                                            M117 Preheat & Level
                                            G28
                                            G10 P0 S242 R200; set extruder 0 active and standby temps
                                            G10 P1 S242 R200; set extruder 1 active and standby temps
                                            M190 S85 ; wait for bed temperature
                                            ;mesh gcode
                                            G29 Q0
                                            T1
                                            G1 E-0.8000 F3000
                                            ; feature skirt
                                            ; tool H0.200 W0.400
                                            G1 Z0.200 F360
                                            G1 X145.575 Y112.700 F9000
                                            G1 E0.8000 F3000
                                            G1 X139.600 Y106.725 E0.2810 F90
                                            G1 X137.300 Y104.425 E0.1082
                                            G1 X137.300 Y95.575 E0.2944
                                            G1 X145.575 Y87.300 E0.3892
                                            G1 X154.425 Y87.300 E0.2944
                                            G1 X156.725 Y89.600 E0.1082
                                            G1 X162.700 Y95.575 E0.2810
                                            G1 X162.700 Y104.425 E0.2944
                                            G1 X154.425 Y112.700 E0.3892
                                            G1 X145.575 Y112.700 E0.2944
                                            G1 E-0.8000 F3000
                                            ; feature cross - external single extrusion
                                            G1 Z0.400 F360
                                            G1 X147.738 Y100.000 F9000
                                            G1 Z0.200 F360
                                            G1 E0.8000 F3000
                                            G1 X149.641 Y100.000 E0.0633 F45
                                            G1 X150.000 Y99.641 F9000
                                            G1 X150.000 Y97.738 E0.0633 F45
                                            G1 E-0.8000 F3000
                                            G1 Z0.400 F360
                                            G1 X152.262 Y100.000 F9000
                                            G1 Z0.200 F360
                                            G1 E0.8000 F3000
                                            G1 X150.279 Y100.000 E0.0659 F45
                                            G1 X150.200 Y100.000 E0.0026
                                            ; tool H0.200 W0.416
                                            G1 X150.117 Y100.000 E0.0029
                                            ; tool H0.200 W0.499
                                            G1 X150.000 Y100.000 E0.0049
                                            G1 X150.000 Y100.117 E0.0049
                                            G1 X150.000 Y100.200 E0.0029
                                            G1 X150.000 Y100.279 E0.0026
                                            G1 X150.000 Y102.262 E0.0659
                                            G1 E-0.8000 F3000
                                            ; layer end
                                            T0;
                                            G1 E-0.8000 F3000
                                            ; feature skirt
                                            G1 Z0.200 F360
                                            G1 E0.8000 F3000
                                            G1 E-0.8000 F3000
                                            G1 Z0.400 F360
                                            G1 Z0.200 F360
                                            G1 E0.8000 F3000
                                            G1 E-0.8000 F3000
                                            G1 Z0.400 F360
                                            G1 Z0.200 F360
                                            G1 E0.8000 F3000
                                            G1 E-0.8000 F3000
                                            ; layer end
                                            ; pass 2
                                            T1
                                            G1 E-0.8000 F3000
                                            ; feature skirt
                                            G1 Z0.200 F360
                                            G1 E0.8000 F3000
                                            G1 E-0.8000 F3000
                                            G1 Z0.400 F360
                                            G1 Z0.200 F360
                                            G1 E0.8000 F3000
                                            G1 E-0.8000 F3000
                                            G1 Z0.400 F360
                                            G1 Z0.200 F360
                                            G1 E0.8000 F3000
                                            G1 E-0.8000 F3000
                                            ; layer end
                                            T0;
                                            G1 E-0.8000 F3000
                                            ; feature skirt
                                            G1 Z0.200 F360
                                            G1 E0.8000 F3000
                                            G1 E-0.8000 F3000
                                            G1 Z0.400 F360
                                            G1 Z0.200 F360
                                            G1 E0.8000 F3000
                                            G1 E-0.8000 F3000
                                            G1 Z0.400 F360
                                            G1 Z0.200 F360
                                            G1 E0.8000 F3000
                                            G1 E-0.8000 F3000
                                            ; layer end
                                            M117 Print Complete !
                                            T-1
                                            M999
                                            dc42undefined 1 Reply Last reply Reply Quote 1
                                              @generisi please post your tool change files again, because you have changed them since you posted them.
