    Dumbfounded ! Firmware bug in 3.4 beta 6?
    Beta Firmware
    1.3k
    • GeneRisiundefined
      GeneRisi @Phaedrux
      @phaedrux "G1 R2 ..." did not fix the problem. Maybe a firmware issue...
      I also tried starting with T3 and then using T0 and that worked correctly, so two sequences worked T0, T1 and T3,T0. T1,T0 does not work as expected.
      A Former User? T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
        A Former User @GeneRisi
        @generisi
        I have something similar but till now no idea what's wrong.
        How about changing tool outside the print?
        GeneRisiundefined 1 Reply Last reply Reply Quote 0
        • GeneRisiundefined
          GeneRisi @A Former User
          @gruna-studio It takes a fair amount of gcode to change the tools. Each tool has its own unique set of offsets from the system coordinates which the firmware manages.
            T3P3Tony administrators @GeneRisi
            @generisi said in Dumbfounded ! Firmware bug in 3.4 beta 6?:
            what are the differences between those free, pre and post files?
            • GeneRisiundefined
              GeneRisi @T3P3Tony
              @t3p3tony Hi Tony - I have included those files in the post previously. I can't see a difference that would explain it.
                G29 Q1
                G29 Q2
                These are wrong - Should be G29 S1/S2 - although i don't think that's the cause of the issue.
                I assume you now have :
                G1 R2 X0 Y0 Z2
                G1 R2 Z0
                at the end of all the tpost#.g files?
                can i check T0 -> T1 works but T1 -> T0 does not work? What if you just command the tool changes through the console sending:
                T-1
                T0
                G1 X100 Y100 Z0
                T1
                G1 X100 Y100 Z0
                T0
                G1 X100 Y100 Z0
                ..etc
                repeatedly does the pickup point or the position X100 Y100 Z0 differ between the tools?
                • GeneRisiundefined
                  GeneRisi @T3P3Tony
                  @t3p3tony Hi Tony - I have my own "mesh.g" macro that allows me to also use "Q1" and "Q2" as inputs. I use the macro to check that the bed mesh in use has been created after the most recent system reset and is not being used if it was created some time before the most recent reset.
                  ; mesh.g
                  ; Redefining G29 behavior
                  ; New parameter Q is used as a substitute for S so that this macro is called
                  ; 	no parms or Q0 means probe mesh, save it but don't load it now
                  ; 	Q1 means use mesh compensation if is fresh
                  ; 	Q2 means disable mesh compensation
                  ;       global.freshMesh set to false in config.g
                  var qVal = 0
                  if exists(param.Q)
                  	set var.qVal = param.Q
                  if var.qVal = 0
                  	if !move.axes[0].homed | !move.axes[1].homed | !move.axes[2].homed
                  		abort "Home all axes before running mesh probes"
                  	else
                  		G91;
                  		G1 Z5 F500
                  		G90;
                  		G29 S2 ; make sure mesh compensations is off
                  		G1 X150 Y100 F3000
                  		G30 ;  get fresh Z=0 for current conditions
                  		set global.freshMesh = true
                  elif var.qVal = 1 & global.freshMesh = false
                  	abort "Trying to use old height map, that's not ok right now"
                  echo "G29 S", {var.qVal}
                  G29 S{var.qVal}
                  if var.qVal = 0
                  	G29 S2					; disable mesh compensation for now if no parms or mesh probed and saved
                  ; finis
                  Also, is there a reason why you did not combine the two "G1 R2 ..." commands into a single command?
                  I will try your suggestion. Thanks!
                  T3P3Tonyundefined GeneRisiundefined 2 Replies Last reply Reply Quote 0
                    ok i did not realise that - nice use case!
                    restoring it in the way I showed, with some Z lift first, is what we recommend for most use cases as it means the last axis to move into position will be Z, so there is less change of the tool dragging across the top of the print as the position is restored.
                    • GeneRisiundefined
                      GeneRisi @GeneRisi
                      @generisi There are either 2 or 3 contact spots checked very unscientifically with double stick tape on the bed when alternating T1, T0, T1, T0, ...
                      • GeneRisiundefined
                        GeneRisi
                        @t3p3tony Here is a simple print file that demonstrates T1,T0,T1,T0:
                        G90
                        M83
                        M117 Preheat & Level
                        G28
                        G10 P0 S242 R200; set extruder 0 active and standby temps
                        G10 P1 S242 R200; set extruder 1 active and standby temps
                        M190 S85 ; wait for bed temperature
                        ;mesh gcode
                        G29 Q0
                        T1
                        G1 E-0.8000 F3000
                        ; feature skirt
                        ; tool H0.200 W0.400
                        G1 Z0.200 F360
                        G1 X145.575 Y112.700 F9000
                        G1 E0.8000 F3000
                        G1 X139.600 Y106.725 E0.2810 F90
                        G1 X137.300 Y104.425 E0.1082
                        G1 X137.300 Y95.575 E0.2944
                        G1 X145.575 Y87.300 E0.3892
                        G1 X154.425 Y87.300 E0.2944
                        G1 X156.725 Y89.600 E0.1082
                        G1 X162.700 Y95.575 E0.2810
                        G1 X162.700 Y104.425 E0.2944
                        G1 X154.425 Y112.700 E0.3892
                        G1 X145.575 Y112.700 E0.2944
                        G1 E-0.8000 F3000
                        ; feature cross - external single extrusion
                        G1 Z0.400 F360
                        G1 X147.738 Y100.000 F9000
                        G1 Z0.200 F360
                        G1 E0.8000 F3000
                        G1 X149.641 Y100.000 E0.0633 F45
                        G1 X150.000 Y99.641 F9000
                        G1 X150.000 Y97.738 E0.0633 F45
                        G1 E-0.8000 F3000
                        G1 Z0.400 F360
                        G1 X152.262 Y100.000 F9000
                        G1 Z0.200 F360
                        G1 E0.8000 F3000
                        G1 X150.279 Y100.000 E0.0659 F45
                        G1 X150.200 Y100.000 E0.0026
                        ; tool H0.200 W0.416
                        G1 X150.117 Y100.000 E0.0029
                        ; tool H0.200 W0.499
                        G1 X150.000 Y100.000 E0.0049
                        G1 X150.000 Y100.117 E0.0049
                        G1 X150.000 Y100.200 E0.0029
                        G1 X150.000 Y100.279 E0.0026
                        G1 X150.000 Y102.262 E0.0659
                        G1 E-0.8000 F3000
                        ; layer end
                        T0;
                        G1 E-0.8000 F3000
                        ; feature skirt
                        G1 Z0.200 F360
                        G1 E0.8000 F3000
                        G1 E-0.8000 F3000
                        G1 Z0.400 F360
                        G1 Z0.200 F360
                        G1 E0.8000 F3000
                        G1 E-0.8000 F3000
                        G1 Z0.400 F360
                        G1 Z0.200 F360
                        G1 E0.8000 F3000
                        G1 E-0.8000 F3000
                        ; layer end
                        ; pass 2
                        T1
                        G1 E-0.8000 F3000
                        ; feature skirt
                        G1 Z0.200 F360
                        G1 E0.8000 F3000
                        G1 E-0.8000 F3000
                        G1 Z0.400 F360
                        G1 Z0.200 F360
                        G1 E0.8000 F3000
                        G1 E-0.8000 F3000
                        G1 Z0.400 F360
                        G1 Z0.200 F360
                        G1 E0.8000 F3000
                        G1 E-0.8000 F3000
                        ; layer end
                        T0;
                        G1 E-0.8000 F3000
                        ; feature skirt
                        G1 Z0.200 F360
                        G1 E0.8000 F3000
                        G1 E-0.8000 F3000
                        G1 Z0.400 F360
                        G1 Z0.200 F360
                        G1 E0.8000 F3000
                        G1 E-0.8000 F3000
                        G1 Z0.400 F360
                        G1 Z0.200 F360
                        G1 E0.8000 F3000
                        G1 E-0.8000 F3000
                        ; layer end
                        M117 Print Complete !
                        T-1
                        M999
                          dc42 administrators @GeneRisi
                          @generisi please post your tool change files again, because you have changed them since you posted them.
                          • GeneRisiundefined
                            GeneRisi @dc42
                            @dc42 OK, I will now
                            ; tpost0.g
                            ; called after tool 0 has been selected
                            ;heatup
                            M116 P0
                            ;prime nozzle
                            ;M98 Pprime.g
                            ;mesh levelling on
                            G29 Q1
                            ;PCF fan on
                            ;M106 P2 S255
                            G1 R2 X0 Y0 Z2
                            G1 R2 Z0 F360
                            ; tpost1.g
                            ; called after tool 1 has been selected
                            ;heatup
                            M116 P1
                            ;prime nozzle
                            ;M98 Pprime.g
                            ;mesh levelling on
                            G29 Q1
                            ;PCF fan on
                            ;M106 P4 S255
                            G1 R2 X0 Y0 Z2
                            G1 R2 Z0 F360
                            The Free and pre files have not changed.
                              @generisi with the image with the two cross prints you showed. Do you mean that T0 and T1 printed one of the crosses perfectly aligned and then the next time T1 was used it printed the miss aligned cross?
                              • GeneRisiundefined
                                GeneRisi @T3P3Tony
                                @t3p3tony Hi Tony, T1 printed the cross in one location and T0 printed the cross in the other location. Even when repeating the sequence a second time, T1 prints in one location and T0 in the other location.
                                If the order is switched, so that T0 is used first, then T1, the crosses align as expected. This is also true if the sequence is T0, T1, T0, T1.
                                FWIW, many years ago, I used to be a programmer and when I think about this, uninitialized values that are referenced comes to mind... FWIW
                                @dc42 , is there some level of debugging I can turn on that might provide you some helpful information?
                                  @generisi I have a theory about what us happening. Tool offsets are usually ignored in system macro files. So I think the G1 R2 X0 Y0 Z0 command at the end of config.g is ignoring the tool offsets. This obviously isn't wanted in this case.
                                  I will do some tests to confirm or refute this theory.
                                  • GeneRisiundefined
                                    GeneRisi @dc42
                                    @dc42 I only added this line after the exchange with @T3P3Tony above; I did, however, use G1 R2 Z0 before communicating with Tony. As an alternative, I can remove the G1 R2 command and use Simplify3d's internal state variables to restore the X, Y and Z locations. Let me know whether this would be a helpful test.
                                    Gene
                                    I removed the G1 R2 commands from the tpostx macros. It didn't change the outcome.
                                    Gene
                                    Why would the tool offsets matter for a move that simply gets the new tool head near the area where it will be used? The printing doesn't occur until a few gcode commands after this move. Aren't the tool offsets applied to every gcode move command?
                                    Gene
                                    • GeneRisiundefined
                                      GeneRisi @dc42
                                      @dc42 Is there something I can do t help debugging this?
                                      • GeneRisiundefined
                                        GeneRisi
                                        @dc42 I found the problem.
                                        When tool T1 was being returned, the Y "parking" coordinate was off by 1 mm. The tool parking location didn't budge but the firmware thought that the tool location was 1mm beyond where it actually was. The machine is a corexy (E3D), so even though only the Y coordinate was off, I suspect it affected both the x and y location from the the firmware's perspective.
                                        • GeneRisiundefined GeneRisi has marked this topic as solved
