    The height map is not created correctly
    IR Height Sensor
    1.9k
    • kotuoundefined
      kotuo @Phaedrux
      @phaedrux  Thank you for your reply.
      I now understand the relationship between X and Y. Thank you.
      • kotuoundefined
        kotuo
        @droftarts @phaedrux Thank you for your kind remarks to my ignorance.
        I finished setting up the M671 today. The result on Bed.g looks like this.
        Bed image:スクリーンショット 2021-12-07 192441.png
        G32Results:G32
        Manual corrections required: 0.00 turn up (0.00mm) 0.19 turn down (0.09mm) 0.13 turn down (0.07mm) 0.19 turn down (0.10mm)
        Thank you for telling us.
        I don't think I could have done so much with my knowledge.
        • kotuoundefined kotuo has marked this topic as solved
