Solved Duet 2 Wifi doesn't turn on when connected to 24v psu
@phaedrux Yes
Can you measure the VIN terminals at the board with a multimeter to ensure there's correct voltage there?
Can you share the results of M122?
@phaedrux I received 24v when I measured the vin
Absolutely!
M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later
Board ID: 0JD0M-9P61A-J8PSD-6JTD2-3S86J-9UT6T
Used output buffers: 3 of 24 (10 max)
Static ram: 23876
Dynamic ram: 75204 of which 168 recycled
Never used RAM 12312, free system stack 134 words
Tasks: NETWORK(ready,13.6%,257) HEAT(delaying,0.0%,330) Move(notifyWait,0.1%,329) MAIN(running,85.8%,442) IDLE(ready,0.5%,29), total 100.0%
Owned mutexes: WiFi(NETWORK)
Last reset 00:03:06 ago, cause: power up
Last software reset time unknown, reason: User, GCodes spinning, available RAM 12456, slot 2
Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
Error status: 0x00
Aux0 errors 0,0,0
Step timer max interval 0
MCU temperature: min 24.0, current 25.5, max 25.8
Supply voltage: min 1.5, current 1.8, max 1.8, under voltage events: 0, over voltage events: 0, power good: no
Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/4/4, gc cycles 0
Driver 0: position -141000, ok, SG min/max not available
Driver 1: position -141000, ok, SG min/max not available
Driver 2: position 0, ok, SG min/max not available
Driver 3: position 0, ok, SG min/max not available
Driver 4: position 0, ok, SG min/max not available
Driver 5: position 0
Driver 6: position 0
Driver 7: position 0
Driver 8: position 0
Driver 9: position 0
Driver 10: position 0
Driver 11: position 0
Date/time: 2021-12-04 12:53:50
Slowest loop: 10.89ms; fastest: 0.11ms
=== Storage ===
Free file entries: 10
SD card longest read time 1.1ms, write time 0.0ms, max retries 0
DMs created 83, maxWait 43326ms, bed compensation in use: none, comp offset 0.000
=== MainDDARing ===
Scheduled moves 5, completed moves 5, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
=== AuxDDARing ===
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 14.28ms; fastest: 0.00ms
Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
HTTP sessions: 1 of 8- WiFi -
Network state is active
WiFi firmware version 1.21
WiFi MAC address e8:68:e7:79:5f:c5
WiFi Vcc 3.35, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 15528
WiFi IP address 192.168.0.232
WiFi signal strength -37dBm, mode none, reconnections 0, sleep mode modem
Clock register ffffffff
- WiFi -
Can you pull the blade fuses and test them for continuity?
The Duet power supply voltage sensing is not working properly:
Can you check the voltage between ground and L5/C64?
You should read 3.3 Volts on each side of L5.
This is the reference voltage for the Analog converters.
Also the voltage at the connection of R80/R81 and R16/R15 (Shown in the schematic above)
You should read..... (Math.....) (4.7/(4.7+47))*24 About 2.2 Volts
@phaedrux The 7.5 fuse is blown. The other 2 are fine
@phaedrux Replaced the fuse and now it’s working!!! Thank you!!
@braeden said in Duet 2 Wifi doesn't turn on when connected to 24v psu:
NICE!
@alankilian To confirm I was able to replace the fuse and switch from the external 5v back to jumping the pins for using the internal 5v converter without getting any errors. Thanks to everyone that helped!!
undefined Phaedrux marked this topic as a question
undefined Phaedrux has marked this topic as solved
