    Duet 6HC Dispaly Options
    • MacNiteundefined
      MacNite
      Hey guys,
      at the moment I am using a PanelDue 7i on my Voron Trident in combination with a Duet 6 HC. Is there any way to make the SD-Card Slot working or add an USB-Stick for file transfer?
      Thank you for your help!
      Max
      CorEssentials on GitHub | Instructables Profile | Thingiverse Profile
      • T3P3Tonyundefined
        T3P3Tony administrators @MacNite
        @macnite if you connect the PanelDue to the Duet using the 10 way ribbon cable then you can use the external SD card on the display. Note the cable should be no longer than ~300mm.
        USB sticks are not supported on stand alone Duets.
        www.duet3d.com
        MacNiteundefined 1 Reply Last reply Reply Quote 0
        • MacNiteundefined
          MacNite @T3P3Tony
          Refering to the documentation that will not work with the Duet 6HC.
          Greets
          Max
          T3P3Tonyundefined 1 Reply Last reply Reply Quote 1
            The 6HC has the option of using a SBC like the raspberry pi which expands on the IO options available.
            • MacNiteundefined
              MacNite @Phaedrux
              @phaedrux yes. That is a possibility as well. But I think that would be to much effort / hardware just to get an Interface and USB-Connectivity.
              Greets
              Max
              • T3P3Tonyundefined
                @macnite thanks I somehow missed the 6HC in your original post!
                www.duet3d.com
