    Delta Z triggered height
    522
    • Gaouundefined
      Gaou
      Guys i need some help for tweaking my deltas.
      First of all i was wondering about the procedure to measure triggered heights by smart effector. So my question is a mathematics one sort of.
      On the documentation is says that i need to specify the triggered height for the center of the bed and then every point on my bed config.
      So the H parameter says it is triggered height at a point minus the triggered height on the center of the table .
      That means that if i have a triggered height -0.10 on the X0Y0 and -0.30 at a specific point X0Y128 the nnn is -0.40 ? Am i doing it right or i am on a wrong path ?
      Delta Printer || Duet 0.85 || firmware 1.23
      Laser K40 || Duet 0.85 || Firmware 1.26.1 || Web 1.22
      Phaedruxundefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
        Phaedrux Moderator @Gaou
        @gaou said in Delta Z triggered height:
        Can you point me to the page you're seeing this please?
        Gaouundefined 1 Reply Last reply Reply Quote 0
        • T3P3Tonyundefined
          T3P3Tony administrators @Gaou
          part of the benefit of using a smart effector is that the nozzle is the probe so you should not need to set individual trigger height offsets for each probe point.
          www.duet3d.com
          • Gaouundefined
            Gaou @Phaedrux
            @phaedrux said in Delta Z triggered height:
            https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer
            • Gaouundefined
              Gaou @T3P3Tony
              @t3p3tony said in Delta Z triggered height:
              i am trying to fine tune my deltas and as far as i know i have to go trough the process that documentation says. i am printing alright but i want to go after for that perfect thing.
                Have you actually measured a variance in trigger height based on XY location?
                • Gaouundefined
                  Gaou @Phaedrux
                  i am not sure i got what you asked. in every bed point of my 10's i got a different triggered height.. even in one spot ( let's say the center i got a different triggered height every time . on the X0Y0 there is a variation of one thousand of a milimeter no matter what i do ...!
                    Do this test at multiple points on the bed. Test each point multiple times.
                    https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Calibrate_the_Z_probe_trigger_height
                    Do you have variance over multiple probings at the same spot?
                    Do you have variance between different XY points on the bed?
                    • Gaouundefined
                      Gaou @Phaedrux
                      This is the procedure i follow. done this hundered times on each of my printers.
                      Yeap....
                      Yes
                      achrnundefined 1 Reply Last reply Reply Quote 0
                        Can you share your config, homedelta, bed.g, M122, etc?
                        • achrnundefined
                          achrn @Gaou
                          Yeap....
                          Is it meaningful variance? You've previously referred to it being "a variation of one thousand of a milimeter no matter what i do"
                          If it's a conventional delta, 20 tooth drives, 2mm pitch belt, 400 step motor, 16x microstepping, one microstep is six thousandths of a millimetre, so getting one thousandth repeatability is remarkably good, and I doubt can be improved.
                          • Gaouundefined
                            Gaou @Phaedrux
                            config.g bed.g
                              What do you have in config-override.g?
