    Duet 2 Maestro Filament sensor Bed Temp
    Firmware installation
    • ap742undefined
      ap742
      Hi everyone
      Just realized my runout sensor stopped working after upgrade to 3.3
      M591 D0
      Extruder 0 has no filament sensor
      this is what I have in custom settings
      ; Custom settings
      M591 D0 P2 C3 S1 ; Filament Run out sensor
      so I replaced that with M591 D0 P2 C"e0_stop" S1
      M591 D0
      Simple filament sensor on pin e0stop, enabled, output high when no filament, filament present: no
      M591 D0
      Simple filament sensor on pin e0stop, enabled, output high when no filament, filament present: yes
      it resolved - but temp shuts off when filament out
      how do I tell it to keep bed temp on?
      • fcwiltundefined
        fcwilt @ap742
        @ap742
        What firmware were you using before 3.3?
        Do you have a filament-error file?
          Can you share your full config.g and the results of M122?
          ap742undefined 1 Reply Last reply Reply Quote 0
          • ap742undefined
            ap742 @Phaedrux
            @fcwilt I dont have Filament-error file
            I am assuming I need to create one. - how?
            I do have pause.g
            pause.g
            ; called when a print from SD card is paused
            ; generated by RepRapFirmware Configuration Tool v3.3.10 on Mon Nov 29 2021 17:18:27 GMT-0500 (Eastern Standard Time)
            M83 ; relative extruder moves
            G1 E-10 F3600 ; retract 10mm of filament
            G91 ; relative positioning
            G1 Z5 F360 ; lift Z by 5mm
            G90 ; absolute positioning
            G1 X0 Y0 F6000 ; go to X=0 Y=0
            @phaedrux
            M122
            RepRapFirmware for Duet 2 Maestro version 3.3 (2021-06-15 21:47:01) running on Duet Maestro 1.0
            Board ID: 08DJM-956DU-LLMS4-7J1FG-3SN6Q-KAM6Q
            Used output buffers: 1 of 24 (11 max)
            Static ram: 23556
            Dynamic ram: 73216 of which 0 recycled
            Never used RAM 18724, free system stack 220 words
            Tasks: NETWORK(ready,23.4%,270) HEAT(delaying,0.1%,345) Move(notifyWait,0.1%,407) TMC(notifyWait,1.3%,117) MAIN(running,75.0%,481) IDLE(ready,0.2%,30), total 100.0%
            Owned mutexes:
            Last reset 00:01:43 ago, cause: power up
            Last software reset at 2021-12-04 10:44, reason: User, GCodes spinning, available RAM 18724, slot 0
            Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
            Error status: 0x00
            Aux0 errors 0,0,0
            Step timer max interval 938
            MCU temperature: min 31.0, current 32.9, max 33.4
            Supply voltage: min 24.1, current 24.1, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
            Driver 0: position 0, standstill, read errors 0, write errors 0, ifcnt 6, reads 17167, writes 6, timeouts 0, DMA errors 0
            Driver 1: position 0, standstill, read errors 0, write errors 0, ifcnt 6, reads 17167, writes 6, timeouts 0, DMA errors 0
            Driver 2: position 0, standstill, read errors 0, write errors 0, ifcnt 6, reads 17167, writes 6, timeouts 0, DMA errors 0
            Driver 3: position 0, standstill, read errors 0, write errors 0, ifcnt 6, reads 17167, writes 6, timeouts 0, DMA errors 0
            Driver 4: position 0, standstill, read errors 0, write errors 0, ifcnt 6, reads 17167, writes 6, timeouts 0, DMA errors 0
            Driver 5: position 0, assumed not present
            Driver 6: position 0, assumed not present
            Date/time: 2021-12-04 12:54:14
            Slowest loop: 3.50ms; fastest: 0.16ms
            === Storage ===
            Free file entries: 10
            SD card 0 detected, interface speed: 15.0MBytes/sec
            SD card longest read time 3.3ms, write time 0.0ms, max retries 0
            DMs created 83, maxWait 0ms, bed compensation in use: mesh, comp offset 0.000
            === MainDDARing ===
            === AuxDDARing ===
            Bed heaters = 0 -1, chamberHeaters = -1 -1
            Segments left: 0
            Movement lock held by null
            HTTP is idle in state(s) 0
            Telnet is idle in state(s) 0
            File is idle in state(s) 0
            USB is idle in state(s) 0
            Aux is idle in state(s) 0
            Trigger is idle in state(s) 0
            Queue is idle in state(s) 0
            LCD is idle in state(s) 0
            Daemon is idle in state(s) 0
            Code queue is empty.
            === Filament sensors ===
            Extruder 0 sensor: ok
            === Network ===
            Slowest loop: 114.07ms; fastest: 0.02ms
            HTTP sessions: 1 of 8
            Interface state active, link 100Mbps half duplex
            full config
            ; Configuration file for Duet WiFi (firmware version 3.3)
            ; generated by RepRapFirmware Configuration Tool v3.3.10 on Mon Nov 29 2021 17:18:26 GMT-0500 (Eastern Standard Time)
            M550 P"E5Maestro" ; set printer name
            M552 P192.168.2.212 S1 ; enable network and set IP address
            M553 P255.255.255.0 ; set netmask
            M554 P192.168.1.1 ; set gateway
            M586 P0 S1 ; enable HTTP
            M586 P1 S0 ; disable FTP
            M586 P2 S0 ; disable Telnet
            M569 P3 S0 ; physical drive 3 goes backwards
            M92 X80.00 Y80.00 Z1600.00 E936.675 ; set steps per mm
            M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
            M203 X6000.00 Y6000.00 Z300.00 E1200.00 ; set maximum speeds (mm/min)
            M906 X800 Y800 Z800 E900 I30 ; set motor currents (mA) and motor idle factor in per cent
            M84 S30 ; Set idle timeout
            M208 X325 Y320 Z400 S0 ; set axis maxima
            M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
            M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
            M574 Z1 S2 ; configure Z-probe endstop for low end on Z
            M950 S0 C"zprobe.mod";M950 S0 C"exp.heater7" ; create servo pin 0 for BLTouch
            M558 P9 C"^zprobe.in" H2.5 F180 T6000 ; set Z probe type to bltouch and the dive height + speeds
            G31 P500 X44 Y2 Z2 ; set Z probe trigger value, offset and trigger height
            M557 X0:310 Y0:285 S50 ;M557 X10:320 Y10:320 S50 ;M557 X0:305 Y0:315 S50 ; define mesh grid
            M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
            ;M950 F0 C"!fan1" Q500 ; create fan 0 on pin !fan1 and set its frequency
            ;M106 P0 S1 H-1
            M950 F0 C"fan1" Q500 ; create fan 0 on pin fan1 and set its frequency
            M106 P0 S1 H-1
            ;M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency
            ;M106 P0 S1 H-1 ; set fan 0 value. Thermostatic control is turned off
            ; Custom settings
            M591 D0 P2 C"e0_stop" S1 ;M591 D0 P2 C3 S1 ; Filament Run out sensor
            G29 S1 ; Load mesh bed
            M564 H0 ; Process config overrides
            M918 P1 E-4 ; Activate LCD12864
              filament-error is optional. Pause.g would be run if it's not present.
