    Method to read Trig. Height returned from G30 S-1?
    Gcode meta commands
    426
    • JayTundefined
      JayT
      Does anyone know how to save trigger height returned by "G30 S-1" in a variable ? or does it get saved in some object model parameter that can be read in a variable ?
      PCRundefined OwenDundefined 2 Replies Last reply Reply Quote 0
      • PCRundefined
        PCR @JayT
        @jayt you can save it via M500 i think
          Using G30 S-3 and M500 P31 would measure the trigger height and then save it to config-override.g
          https://duet3d.dozuki.com/Wiki/G30
          https://duet3d.dozuki.com/Wiki/M500
          • OwenDundefined
            OwenD @JayT
            @jayt
            You probably want to read sensors.probes[].lastStopHeight if you want to use it in a macro or something
            Or you might want trigger height depending on your use case
            The full list is here
            https://github.com/Duet3D/RepRapFirmware/wiki/Object-Model-Documentation
            JayTundefined 1 Reply Last reply Reply Quote 2
            • JayTundefined
              JayT @OwenD
              @owend :
              @Phaedrux :
              thank you for quick responses.
              with G30 S-3 and M500 P31 would measure, save and is perfect.
              If not, then I can try taking 4-5 points , save in variables, take average and set that avg value as trigger height to minimize the error?
              How to save object-model data into a variable?
              Phaedruxundefined OwenDundefined 2 Replies Last reply Reply Quote 0
                Phaedrux Moderator @JayT
                @jayt said in Method to read Trig. Height returned from G30 S-1?:
                https://duet3d.dozuki.com/Wiki/GCode_Meta_Commands#Section_Variables
                have you seen this?
                • OwenDundefined
                  OwenD @JayT
                  @jayt
                  Sounds like you're trying to do something like this
                  https://forum.duet3d.com/topic/22139/macro-for-automatic-calibration-of-bl-touch
                  You may have to modify to suit your machine and requirements
                  JayTundefined 1 Reply Last reply Reply Quote 1
                  • JayTundefined
                    JayT @OwenD
                    @owend :
                    Thank you for the reference. looks like a good base for me.
                    @Phaedrux : thanks, I missed the global var example earlier. Now I see how its read.
                    You can close the thread as solved, As I understand how to read object model variables and where to look for the available variables.
