    BLTouch Probe Won't Deploy
    5.3k
    • Charlieundefined
      Charlie
      I'm having issues with the BLTouch probe not deploying (it is genuine) during my Z homing. I have verified that the wiring is running correctly (to my knowledge, based on Connecting Z Probe and BLTouch Troubleshooting). The probe goes through its normal deploy/retract cycle upon startup.
      Here's the weird part: both the m401 and the m402 commands deploy and retract the probe respectively.
      Furthermore, when I put the M280 code within the "deployprobe0.g"
      ; Voron
      ; 0:/sys/deployprobe0.g
      ; Deploy probe file for Duet 3 (firmware version 3.3).
      ; Called to deploy BLTouch probe via M401.
      ; 2021/06/30/16:14
      M280 P"0.io4.out" S10  ; Set servo position.
                             ; P (Servo index): 0.io4.out (Mainboard, io4.out).
                             ; S (Servo angle): 10.
      and "retractprobe0.g"
      ; Voron
      ; 0:/sys/retractprobe0.g
      ; Retract probe file for Duet 3 (firmware version 3.3).
      ; Called to retract BLTouch probe via M402.
      ; 2021/06/30/16:14
      M280 P"0.io4.out" S90  ; Set servo position.
                             ; S (Servo angle): 90
      files, they successfully deploy and retract. Any help would be greatly appreciated!
      • Charlieundefined
        Charlie
        config file part 1 of 2
        ; Voron
        ; 0:/sys/config.g
        ; Configuration file for Duet 3 (firmware version 3.3).
        ; Executed by the firmware on start-up.
        ; 2021/06/30/12:59
        ; General Preferences
        G90            ; Set all axes (not extruders) to absolute positioning.
        M83            ; Set all extruders (not axes) to relative positioning.
        M550 P"Voron"  ; Set machine name.
                       ; P (Machine name): Voron.
        M669 K1        ; Set kinematics type and parameters.
                       ; K (Kinematics type): 1 (CoreXY).
        ; Drive Map
        ; XY Drives
        ; | A | B |
        ; Z Drives
        ; | 3 | 0 |
        ; | 2 | 1 |
        ;   Front
        M569 P0.0 S1                                   ; Set motor driver direction.
                                                       ; P (Motor drive number): 0.0 (Mainboard driver 0 board label, XY, A, top left motor).
                                                       ; S (Direction of movement): 1 (Forward).
        M569 P0.1 S1                                   ; Set motor driver direction.
                                                       ; P (Motor drive number): 0.1 (Mainboard driver 1 board label, XY, B, top right motor).
        M569 P0.2 S0                                   ; Set motor driver direction.
                                                       ; P (Motor drive number): 0.2 (Mainboard driver 2 board label, Z0, far right motor).
                                                       ; S (Direction of movement): 0 (Backwards).
        M569 P0.3 S1                                   ; Set motor driver direction.
                                                       ; P (Motor drive number): 0.3 (Mainboard driver 3 board label, Z1, close right motor).
        M569 P0.4 S0                                   ; Set motor driver direction.
                                                       ; P (Motor drive number): 0.4 (Mainboard driver 4 board label, Z2, close left motor).
        M569 P0.5 S1                                   ; Set motor driver direction.
                                                       ; P (Motor drive number): 0.5 (Mainboard driver 5 board label, Z3, far left motor).
        M569 P1.0 S1                                   ; Set motor driver direction.
                                                       ; P (Motor drive number): 1.0 (Expansion driver 0 board label, E1, Extruder 1).
        M584 X0.0 Y0.1 Z0.2:0.3:0.4:0.5 R0 S0 E1.0     ; Set drive mapping.
                                                       ; X (Driver number for X motor): 0.0 (Mainboard driver, 0 board label).
                                                       ; Y (Driver number for Y motor): 0.1 (Mainboard driver, 1 board label).
                                                       ; Z (Driver number for Z motors): 0.2:0.3:0.4:0.5 (Mainboard driver, 2, 3, 4, & 5 motor labels).
                                                       ; R (Axes created in command are...): 0 (linear).
                                                       ; S (Axes created in command are treated in feedrate calculations as...): 0 (linear).
                                                       ; E (Driver number for E motor): 1.0 (Expansion driver, 0 motor label).
        M671 X410:410:-60:-60 Y422:-8:-8:422 S20 F1.0  ; Set positions of z belts (60mm X, 72mm Y offsets in back. 60mm X, 8mm Y offsets in front.) 0 (410,422), 1 (410, -8), 2(-60, -8), 3(-60, 422).
                                                       ; X (X coordinates of Z screws): ...
                                                       ; Y (Y coordinates of Z screws): ...
                                                       ; S (Maximum correction to apply to each Z screw [mm]): 20.
                                                       ; F (Fudge factor): 1.0.
        M350 X16 Y16 Z16 E16 I1                        ; Set microstepping and interpolation.
                                                       ; X (Stepping mode for the X axis): 16 (1/16 step).
                                                       ; Y (Stepping mode for the Y axis): 16 (1/16 step).
                                                       ; Z (Stepping mode for the Z axis): 16 (1/16 step).
                                                       ; E (Stepping mode for the extruder): 16 (1/16 step).
                                                       ; I (Microstepping interpolation mode): 1 (Enable).
        M92 X80.00 Y80.00 Z400.00 E413.00              ; Set axis steps per unit.
                                                       ; X (Steps/mm for X axis): 80.00.
                                                       ; Y (Steps/mm for Y axis): 80.00.
                                                       ; Z (Steps/mm for Z axis): 400.00.
                                                       ; E (Steps/mm for extruder): 413.00.
        M566 X300.00 Y300.00 Z12.00 E120.00            ; Set maximum instantaneous speed change (jerk).
                                                       ; X (Maximum instantaneous speed change for X axis [mm/min]): 300.00.
                                                       ; Y (Maximum instantaneous speed change for Y axis [mm/min]): 300.00.
                                                       ; Z (Maximum instantaneous speed change for Z axis [mm/min]): 12.00.
                                                       ; E (Maximum instantaneous speed change for extruder [mm/min]): 120.00.
        M203 S1 X300.00 Y300.00 Z15.00 E20.00          ; Set maximum feedrate (speed).
                                                       ; S (Units): 1 (mm/sec [default is mm/min]).
                                                       ; X (Maximum feedrate for X axis [mm/sec]): 300.00.
                                                       ; Y (Maximum feedrate for Y axis [mm/sec]): 300.00.
                                                       ; Z (Maximum feedrate for Z axis [mm/sec]): 15.00.
                                                       ; E (Maximum feedrate for extruder [mm/sec]): 20.00.
        M201 X3000.00 Y3000.00 Z350.00 E250.00         ; Set maximum print move accelerations.
                                                       ; X (Maximum acceleration for X axis [mm/sec^2]): 3,000.00.
                                                       ; Y (Maximum acceleration for Y axis [mm/sec^2]): 3,000.00.
                                                       ; Z (Maximum acceleration for Z axis [mm/sec^2]): 350.00.
                                                       ; E (Maximum acceleration for extruder [mm/sec^2]): 250.00.
        M906 X1500 Y1500 Z1400 E700 I30                ; Set maximum motor currents.
                                                       ; X (X drive maximum motor current [mA]): 1,500 (75% of max rated motor current of 2,000 mA).
                                                       ; Y (Y drive maximum motor current [mA]): 1,500 (75% of max rated motor current of 2,000 mA).
                                                       ; Z (Z drive maximum motor current [mA]): 1,400 (70% of max rated motor current of 2,000 mA).
                                                       ; E (Extruder maximum motor current [mA]): 700 (70% of max rated motor current of 1,000 mA).
                                                       ; I (Motor current idle factor): 30.
        M84 S30                                        ; Stop idle hold.
                                                       ; S (Idle time out[seconds]): 30.
        M208 S1 X0 Y0 Z0        ; Set axis maximum travel.
                                ; S (Set axis): 1 (Minimum).
                                ; X (X axis limit): 0.
                                ; Y (Y axis limit): 0.
                                ; Z (Z axis limit): 0.
        M208 S0 X350 Y350 Z310  ; Set axis maximum travel.
                                ; S (Set axis): 0 (Maximum).
                                ; X (X axis limit): 350.
                                ; Y (Y axis limit): 350.
                                ; Z (Z axis limit): 310.
        M574 X2 P"0.io0.in" S1  ; Set endstop configuration.
                                ; X (Position of X endstop): 2 (High end).
                                ; P (Pin name): 0. (Mainboard) io0.in.
                                ; S (Endstop type): 1 (Switch type).
        M574 Y2 P"0.io1.in" S1  ; Set endstop configuration.
                                ; Y (Position of Y endstop): 2 (High end).
                                ; P (Pin name): 0. (Mainboard) io1.in.
        M574 Z0                 ; Set endstop configuration.
                                ; Z (Position of Z endstop): 0 (None).
        • Charlieundefined
          Charlie
          config file part 2 of 2
          ; Z Probe
          M558 K0 P9 F120 H3 R0 T6000 A1 B0 C"0.io4.in"  ; Set Z probe type.
                                                         ; K (Z probe number): 0 (1).
                                                         ; P (Z Probe type): 9 (BLTouch probe).
                                                         ; F (Feed rate. Probing speed [mm/min]): 120.
                                                         ; H (Dive height [mm]): 3.
                                                         ; R (Recovery time [seconds]): 0.
                                                         ; T (Travel speed [mm/min]): 6,000.
                                                         ; A (Max number of times to probe each point): 1.
                                                         ; B (Heaters): 0 (Leave all heaters on while probing).
                                                         ; C (Endstop input): 0. (Mainboard) io4.in.
          M950 S0 C"0.io4.out"                           ; Create GPIO/servo pin.
                                                         ; S (Output/servo pin number): 0.
                                                         ; C (Pin name): 0. (Mainboard) io4.out.
          G31 P500 X0 Y22.0 Z3.105 K0                    ; Set Z probe.
                                                         ; P (Trigger value): 500.
                                                         ; X (Probe X offset [mm]): 0.
                                                         ; Y (Probe Y offset [mm]): 22.000.
                                                         ; Z (Probe Z offset [mm]): 3.105 (This is modified for Z probe calibration. A higher offset number moves the nozzle closer to the bed.).
                                                         ; K (Z probe number): 0.
          M557 X25:325 Y25:313.5 P3                      ; Define Z probe mesh grid (This is probe grid, not nozzle grid).
                                                         ; X (Min:Max X coordinates to probe): 35 (Min) : 325 (Max).
                                                         ; Y (Min:Max Y coordinates to probe): 25 (Min) : 313.5 (Max).
                                                         ; P (Points to probe in each direction): 3.
          ; Heater, Bed
          M308 S0 P"0.temp0" Y"thermistor" A"Bed Temp" T100000 B3950 C0 R2200  ; Set (Bed) temperature sensor parameters.
        ; S (Sensor number): 0.
        ; P (Pin name): 0. (Mainboard) temp0.
        ; Y (Sensor type): thermistor.
        ; A (Sensor name): Bed Temp.
        ; T (Thermistor resistance at 25 deg C): 100,000.
        ; B (Beta value): 3950.
        ; C (Coefficient): 0.
        ; R (Series resistor value): 2200 (Default for Duet3).
          M950 H0 C"0.out0" Q10 T0                                             ; Create heater (Bed).
        ; H (Heater number): 0.
        ; C (Pin name): 0. (Mainboard) out0.
        ; Q (PWM frequency [Hz]): 10 (Due to solid state relay).
        ; T (Temperature sensor number): 0 (bed).
          M307 H0 R0.660 C320.2 D1.62 I0 B0 S1.0 V0                            ; Set heating process parameters.
        ; H (Heater number): 0 (Bed).
        ; R (Heating rate): 0.660.
        ; C (Dominant time constant of heating process [seconds]): 320.2.
        ; D (Dead time [seconds]): 1.62.
        ; I (Invert PWM signal): 0 (Not inverted).
        ; B (Bang bang control): 0 (Disabled).
        ; S (Maximum PWM frequency to use): 1.00.
        ; V (Vin calibration supply voltage): 0 (Mains heater).
          M140 H0                                                              ; Configure bed heater.
          M143 H0 S160                                                         ; Set maximum heater temperature.
        ; H (Heater number to monitor): 0 (Bed).
        ; S (Maximum permitted temperature [deg C]): 160.
          ; Heater, Extruder 1
          M308 S1 P"0.temp1" Y"thermistor" A"Extr. 1 Temp" T100000 B4725 C7.06e-8  ; Set (Extruder 1) temperature sensor parameters.
        ; S (Sensor number): 1 (Extruder 1).
        ; P (Pin name): 0. (Mainboard) temp1.
        ; Y (sensor type): thermistor.
        ; A (Sensor name): Extr 1. Temp.
        ; B (Beta value): 4725.
        ; C (Coefficient): 7.06e-8.
          M950 H1 C"0.out1" Q500 T1                                                ; Create heater (Extruder 1).
        ; H (Heater number): 1.
        ; C (Pin name): 0. (Mainboard) out1.
        ; Q (PWM frequency [Hz]): 500 (Default).
        ; T (Temperature sensor number): 1.
          M307 H1 R2.500 C378.6:159.6 D4.08 I0 B0 S1.00 V24.0                      ; Set heating process parameters (auto tune  performed at 240 C).
        ; R (Heating rate): 2.700 (decrease this by 30% if a heater temperature error shows up).
        ; C (Dominant cooling time constant of heating process [seconds]): 400.6 (print fans off) : 158.6 (print fans fully on).
        ; D (Dead time [seconds]): 4.15.
        ; V (Vin calibration supply voltage): 24.0.
          M143 H1 S285                                                             ; Set maximum heater temperature.
        ; H (Heater number to monitor): 1 (Extruder 1).
        ; S (Maximum permitted temperature [deg C]): 285 (Due to max thermistor temperature).
          ; Fan, Print Cooling
          M950 F0 C"0.out4" Q100                      ; Create fan.
                                                      ; F (Fan number): 0.
                                                      ; C (Pin name): 0. (Mainboard) out4.
                                                      ; Q (PWM frequency [Hz]): 100 (60 is too low, 800 is too high).
          M106 P0 L0.2 X1.0 B0.3 H-1 R1 C"Print Fan"  ; Set fan.
                                                      ; P (Fan number): 0 (Print/part cooling).
                                                      ; L (Minimum fan speed): 0.2.
                                                      ; X (Maximum fan speed): 1.0.
                                                      ; B (Blip time [seconds]): 0.3.
                                                      ; H (Thermostatic control): -1 (Disabled).
                                                      ; R (Restore fan speed): 1 (To the value it has when the print was paused).
                                                      ; C (Name): Print Fan.
          ; Fan, Heat Break
          M950 F1 C"0.out5" Q25000                              ; Create fan.
        ; F (Fan number): 1.
        ; C (Pin name): 0. (Mainboard) out5.
        ; Q (PWM frequency [Hz]): 25,000.
          M106 P1 S1.0 L0.5 X1.0 B0.3 H1 T45 C"Heat Break Fan"  ; Set fan.
        ; P (Fan number): 1 (Heat break).
        ; S (Fan speed): 1.0.
        ; L (Minimum fan speed): 0.5.
        ; H (Thermostatic control): 1 (Enabled).
        ; T (Thermostatic mode trigger temperature [C]): 45.
        ; C (Name): Heat Break Fan.
          ; Fans, Case
          M308 S2 Y"drivers" A"Driver Temp"                ; Set (stepper drivers) temperature sensor.
                                                           ; S (Sensor number): 2.
                                                           ; Y (Sensor type): drivers (Mainboard stepper drivers).
                                                           ; A (Sensor name): Driver Temp.
          M308 S3 Y"mcu_temp" A"CPU Temp"                  ; Set (CPU/MCU) temperature sensor.
                                                           ; S (Sensor number): 3.
                                                           ; Y (Sensor type): mcu_temp (CPU/MCU).
                                                           ; A (Sensor name): CPU Temp.
          M950 F2 C"0.out6" Q25000                         ; Create fan.
                                                           ; F (Fan number): 2 (Case fan).
                                                           ; C (Pin name): 0. (Mainboard) out6.
          M106 P2 L0.8 X1.0 B0.1 H2:3 T40:65 C"Case Fans"  ; Set fan.
                                                           ; P (Fan number): 2 (Electronics).
                                                           ; L (Minimum fan speed): 0.8.
                                                           ; B (Blip time [seconds]): 0.1.
                                                           ; H (Thermostatic control): 2 (stepper drivers) : 3 (CPU/MCU).
                                                           ; T (Thermostatic trigger temperature [C]: 40-65 (Proportional range).
                                                           ; C (Name); Case Fans.
          M563 P0 S"Extr. 1 Tool" D0 H1 F0  ; Define tool.
                                            ; P (Tool number): 0 (Extruder 1).
                                            ; S (Tool name): Extr. 1 Tool.
                                            ; D (Extruder drive): 0 (defined in M584 as E1.0).
                                            ; H (Heater): 1 (Extruder 1, defined in M950 H1).
                                            ; F (Fan mapped): 0 (Print/part cooling fan).
          G10 P0 X0 Y0 Z0 R0 S0             ; Set tool offset and temperature.
                                            ; P (Tool number): 0.
                                            ; X (X offset): 0.
                                            ; Y (Y offset): 0.
                                            ; Z (Z offset): 0.
                                            ; R (Standby temperature): 0.
                                            ; S (Active temperature: 0.
          ; Display
          M575 P1 S1 B57600 S1  ; Set serial communications parameters.
                                ; P (Serial channel number): 1 (Auxiliary serial port).
                                ; B (Baud rate): 57,600 (PanelDue default).
                                ; S (Mode): 1 (PanelDue, checksum required).
          ; Automatic Power Saving
          M911 S21.0 R22.0 P"M913 X0 Y0 G91 M83 G1 Z3 E-2 F1000"  ; Set auto save on power loss.
        ; S (Auto save threshold [V]): 21.0.
        ; R (Resume threshold [V]): 22.0.
        ; P (Commands on power loss): ...
          ; CPU Temperature Compensation
          M912 P0 S00.0  ; Set electronics temperature monitor adjustment.
                         ; P (Temperature monitor channel): 0 (Default).
                         ; S (Value to be added to temperature reading [C]): 00.0 (Lower number decreases displayed cpu temperature. =[(temperature_actual)-(temperature_indicated)]).
          ; Pressure Advance
          M572 D0 S0.05  ; Set extruder pressure advance (Linear advance).
                         ; D (Extruder number): 0 (Extruder 1).
                         ; S (Pressure advance amount [seconds]): 0.05.
          ; Select Tool
          T0  ; Select first tool.
          JoergS5undefined 1 Reply Last reply Reply Quote 0
          • Charlieundefined
            Charlie
            My "homez.g" file
            ; Voron.
            ; 0:/sys/homez.g
            ; Called to home the Z axis via G28 Z.
            ; 2020/10/24/20:02
            G91                   ; Set axes (not extruders) to relative positioning mode.
            G1 H2 Z5 F6000        ; Lift Z relative to current position.
            G90                   ; Set axes (not extruders) to absolute positioning mode.
            G1 X175 Y151.5 F6000  ; Move X and Y axes so the Z probe is at the center of the bed.
            M558 F600 H2 A1       ; Set Z probe. Feed rate: 600 mm/min. Dive height: 2 mm. Times to probe: 1.
            G30                   ; Z probe quickly (1 of 2 passes).
            M558 F120 H5 A1       ; Set Z probe. Feed rate: 120 mm/min. Dive height: 5 mm. Times to probe: 1.
            G30                   ; Home Z by probing the bed slowly (2 of 2 passes).
            • Charlieundefined
              Charlie
              My M122 response.
              m122
              RepRapFirmware for Duet 3 MB6HC version 3.3 (2021-06-15 21:45:47) running on Duet 3 MB6HC v1.01 or later (SBC mode)
              Board ID: 08DJM-956L2-G43S8-6J9DG-3S46T-KV2LF
              Used output buffers: 1 of 40 (10 max)
              Static ram: 150904
              Dynamic ram: 62124 of which 132 recycled
              Never used RAM 141032, free system stack 202 words
              Tasks: SBC(ready,4.9%,318) HEAT(delaying,0.0%,325) Move(notifyWait,0.0%,302) CanReceiv(notifyWait,0.0%,908) CanSender(notifyWait,0.0%,374) CanClock(delaying,0.0%,339) TMC(notifyWait,7.1%,93) MAIN(running,87.9%,922) IDLE(ready,0.0%,29), total 100.0%
              Owned mutexes: HTTP(MAIN)
              Last reset 00:09:33 ago, cause: power up
              Last software reset at 2021-12-07 00:27, reason: User, GCodes spinning, available RAM 141032, slot 0
              Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a
              Error status: 0x00
              Aux0 errors 0,0,1
              Step timer max interval 131
              MCU temperature: min 31.6, current 44.8, max 45.0
              Supply voltage: min 24.0, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
              12V rail voltage: min 12.0, current 12.1, max 12.1, under voltage events: 0
              Driver 0: position 0, standstill, reads 1389, writes 14 timeouts 0, SG min/max 0/0
              Driver 1: position 0, standstill, reads 1389, writes 14 timeouts 0, SG min/max 0/0
              Driver 2: position 0, standstill, reads 1389, writes 14 timeouts 0, SG min/max 0/0
              Driver 3: position 0, standstill, reads 1389, writes 14 timeouts 0, SG min/max 0/0
              Driver 4: position 0, standstill, reads 1389, writes 14 timeouts 0, SG min/max 0/0
              Driver 5: position 0, standstill, reads 1389, writes 14 timeouts 0, SG min/max 0/0
              Date/time: 2021-12-09 03:42:41
              Slowest loop: 0.46ms; fastest: 0.04ms
              === Storage ===
              Free file entries: 10
              === MainDDARing ===
              === AuxDDARing ===
              Heater 1 is on, I-accum = 0.0
              Segments left: 0
              Movement lock held by null
              Telnet is idle in state(s) 0
              File is idle in state(s) 0
              USB is idle in state(s) 0
              Aux is assembling a command in state(s) 0
              Queue is idle in state(s) 0
              LCD is idle in state(s) 0
              SBC is idle in state(s) 0
              Daemon is idle in state(s) 0
              Aux2 is idle in state(s) 0
              Code queue is empty.
              === CAN ===
              Messages queued 5073, received 7, lost 0, longest wait 1ms for reply type 6042, peak Tx sync delay 2403, free buffers 49 (min 48), ts 2870/2865/0
              Tx timeouts 0,0,4,0,0,0 last cancelled message type 30 dest 127
              === SBC interface ===
              State: 4, failed transfers: 1, checksum errors: 0
              Last transfer: 1ms ago
              RX/TX seq numbers: 19609/19609
              SPI underruns 0, overruns 0
              Disconnects: 0, timeouts: 0, IAP RAM available 0x2c83c
              Buffer RX/TX: 0/0-0
              === Duet Control Server ===
              Duet Control Server v3.3.0
              Code buffer space: 4096
              Configured SPI speed: 8000000Hz
              Full transfers per second: 21.15, max wait times: 18.5ms/0.0ms
              Codes per second: 0.06
              Maximum length of RX/TX data transfers: 2948/332
              • fcwiltundefined
                fcwilt @Charlie
                @charlie
                Your M280 statements are incorrect. The P parameter is the servo index, not the pin name.
                M280
                Also the M401 and M402 commands simply invoke the deploy/retract macros.
                Charlieundefined 1 Reply Last reply Reply Quote 1
                • Charlieundefined
                  Charlie @fcwilt
                  @fcwilt
                  Thank you very much for the reply!
                  That seems to contradict the statement made in the M280 GCode Dictionary
                  "RRF3: Before you can use M280 you must create a GPIO port using M950. Then in the M280 command, the P parameter is the GPIO port number, not the logical pin number. Duet 2 supports up to 10 GPIO ports, numbers 0 to 9. No GPIO ports are allocated by default."
                  Am I looking at this the wrong way?
                  Furthermore, when I put M280 P"0.io4.out" S10 in the Console, the probe deploys.
                  Is there something that I am not considering?
                  JoergS5undefined fcwiltundefined Phaedruxundefined 3 Replies Last reply Reply Quote 0
                  • JoergS5undefined
                    JoergS5 @Charlie
                    @charlie said in BLTouch Probe Won't Deploy:
                    I checked the source, the P parameter reads the expression after P as integer, so P0 is read. The part after 0 is ignored.
                    • fcwiltundefined
                      fcwilt @Charlie
                      No, the docs are simply confusing things by using two different terms (servo index, port number) for the same thing.
                      It not unusual to find the docs are a bit wonky in certain regards.
                      As to the other question regards the M280 working it as been explained by another poster.
                      Charlieundefined 1 Reply Last reply Reply Quote 0
                        Phaedrux Moderator @Charlie
                        Is that confusing? You must create a port number with M950 and then M280 uses that port number. What do you suggest to make it more clear?
                        It even shows examples
                        https://duet3d.dozuki.com/Wiki/M280
                        • Charlieundefined
                          Charlie @JoergS5
                          @joergs5
                          Thank you for your response. That's good to know. I changed the deployprobe0.g file to
                          M280 P0 S10  ; Set servo position.
                          anyway, to avoid making the same mistake that I made between the GPIO port number and logical pin number.
                          The issue persists with this modification.
                          • Charlieundefined
                            Charlie @fcwilt
                            @fcwilt
                            Okay, that explains why the M280 command worked even though I messed up the P value.
                            With that said, Im still having issues deploying the BLTouch probe when homing the Z axis. The M280 P0 S10 and M401 commands successfully deploy the probe.
                            • JoergS5undefined
                              JoergS5 @Charlie
                              @charlie one issue in your config.g is, that the speeds are very low:
                              S1 does not exist for M203, so the speeds are mm/min, so e.g. Z is only 0.25 mm/s. So your probing might run into a timeout. Please use higher values. I would take the values of the documentation of M203: https://duet3d.dozuki.com/Wiki/M203
                              BUT: does Voron has a specific firmware, where S1 is valid? Then the firmware could be a reason for your problem, but I don't know how to help then. Which tool did you use to create the config file? Marlin and Slic3rPR use mm/s, but RRF use mm/min.
                              • Charlieundefined
                                Charlie @JoergS5
                                @joergs5
                                I assumed based on Duet3D Changelog: RepRapFirmware 3.3
                                "The M203 command now supports an optional S1 parameter which changes the units to mm/sec. The default is still mm/min."
                                The X, Y, and Z homing speeds appear to be the same speed as I had before the change to S1. The probe just doesnt deploy during the Z homing step.
                                JoergS5undefined fcwiltundefined 4 Replies Last reply Reply Quote 0
                                • JoergS5undefined
                                  JoergS5 @Charlie
                                  @charlie then sorry, it is not in the documentation yet.
                                  I proceed searching for a possible reason...
                                  • JoergS5undefined
                                    JoergS5 @Charlie
                                    @charlie homing is often made by homeall.g, can you please post it, and homex.g and homey.g also?
                                    How do you home Z: individually X, Y, Z or together in one step?
                                    Charlieundefined 2 Replies Last reply Reply Quote 1
                                    • fcwiltundefined
                                      fcwilt @Charlie
                                      There are parameters to M558 to control probing speeds (travel and probing) including the ability to specify two probing speeds.
                                      As another poster has mentioned you didn't post homeall.g which may well be why we didn't spot the problem.
                                      • Charlieundefined
                                        Charlie @JoergS5
                                        @joergs5
                                        No worries. I greatly appreciate your willingness to help!
                                        In this case, I am homing X, then Y, then Z. With that said, the issue also occurs using the "Home All" button in DWC.
                                        • fcwiltundefined
                                          fcwilt @Charlie
                                          @joergs5
                                          So homing just Z with the DWC Home Z button does not work? Just want to be sure I understand what is happening.
                                          • Charlieundefined
                                            Charlie @JoergS5
                                            @joergs5
                                            homex.g
                                            ; Voron.
                                            ; 0:/sys/homex.g
                                            ; Called to home the X axis via G28 X.
                                            ; 2020/10/24/20:00
                                            G1 H1 X355 F6000  ; Move quickly to X endstop (1 of 2 passes).
                                            G1 H0 X-3 F6000   ; Move away from X endstop.
                                            G1 H1 X10 F360    ; Move slowly to X axis endstop once more (2 of 2 passes).
                                            G1 H2 Z-5 F6000   ; Lower Z relative to current position.
                                            homey.g
                                            ; Voron
                                            ; 0:/sys/homey.g
                                            ; Called to home the Y axis via G28 Y.
                                            ; 2020/10/24/20:01
                                            G1 H1 Y360 F6000  ; Move quickly to Y endstop (1 of 2 passes).
                                            G1 H0 Y-3 F6000   ; Move away from Y endstop.
                                            G1 H1 Y10 F360    ; Move slowly to X axis endstop once more (2 of 2 passes).
                                            homeall.g
                                            ; Voron.
                                            ; 0:/sys/homeall.g
                                            ; Called to home all axes via G28.
                                            ; 2020/10/24/21:00
                                            G1 H1 X355 Y360 F6000  ; Move quickly to X or Y axis endstop and stop there.
                                            G1 H1 X355 F6000       ; Move quickly to X endstop and stop there.
                                            G1 H1 Y360 F6000       ; Move quickly to Y endstop and stop there.
                                            G1 H0 X-3 Y-3 F6000    ; Move away from X and Y endstops.
                                            G1 H1 X10 F360         ; Move slowly to X endstop once more.
                                            G1 H1 Y10 F360         ; Move slowly to Y endstop once more.
