    BLTouch Probe Won't Deploy
    4.9k
    • JoergS5undefined
      JoergS5 @Charlie
      @charlie you may need to exchange the order or M950 and M558:
      in the M950 documentation https://duet3d.dozuki.com/Wiki/M950 :
      "M950 must come before any commands that refer to the device being created."
      So M950, then M558 which uses the servo part of BLTouch.
      I am not sure about this. In the examples I know, M950 is first, M558 next, but the two commands don't have a reference to each other. But it's worth a try. M558 may expect to know the M950 values.
      Charlieundefined 1 Reply Last reply Reply Quote 0
      • Charlieundefined
        Charlie @fcwilt
        @fcwilt
        That is correct. Homing just Z doesnt work.
        It also doesnt work if I use "Home All".
        fcwiltundefined JoergS5undefined 2 Replies Last reply Reply Quote 0
        • fcwiltundefined
          fcwilt @Charlie
          @charlie said in BLTouch Probe Won't Deploy:
          @fcwilt
          OK let's take the homing code out of the picture.
          Can you reset the printer and successfully home X and Y?
          • JoergS5undefined
            JoergS5 @Charlie
            @charlie a last additional idea: M208 has Z minimum 0 and the BLTouch starts at 3 mm height. It may be that it cannot probe below 0 because of M208. This was changed in 3.4 somewhere if I remember correct, but if you use 3.3 firmware, it may be a try to set the M208 Z limit below 0.
            • Charlieundefined
              Charlie @fcwilt
              @fcwilt
              Im assuming that "reset" means sending an M999 command, or powering off the duet. In that case, X and Y works wonderfully when I home them individually. Furthermore, the X and Y portions of the Home All function work as intended as well.
              • Charlieundefined
                Charlie @JoergS5
                @joergs5
                Unfortunately, this did not fix the issue. I appreciate the attempt though!
                • fcwiltundefined
                  fcwilt @Charlie
                  @fcwilt
                  Great.
                  So with X and Y homed:
                  • move X and Y to center of the bed either by jogging or issuing G1 commands
                  • issue a G92 Z3 to force Z to be marked as homed (this allows jogging Z)
                  • jog Z to 3 mm off the bed (now the logical and physical Z positions are in sync)
                  • change to the DWC Console page
                  • issue a G30
                  Post what happens.
                  • Charlieundefined
                    Charlie @fcwilt
                    @fcwilt
                    So I did this, but with one exception. I didnt jog the z to be 3mm off the bed, as I was concerned about crashing the nozzle.
                    The probe did not deploy, and the error: "Error: Probe was not triggered during probing move" was displayed on the console.
                    • Charlieundefined
                      Charlie @JoergS5
                      @joergs5 said in BLTouch Probe Won't Deploy:
                      Something odd happened that may help those smarter than I!
                      I issued an M208 S1 Z-100 command in the DWC console (which is along the lines of what I believed you asked me to do). I then issued a G30 command. Please keep in mind that this was after I did what @fcwilt asked, which was to issue a G92 Z3 command.
                      The print head seemed to move down around 3mm, and then the probe deployed.
                      • fcwiltundefined
                        fcwilt @Charlie
                        I made a post but came back to find your new post.
                        I need to think.
                        • fcwiltundefined
                          fcwilt @Charlie
                          @charlie
                          OK what are your current probe configuration commands (M950 M558 G31)?
                          • Charlieundefined
                            Charlie @fcwilt
                            @fcwilt
                            Here is the current Z Probe section of the config.g file, containing the M950, M558, and G31.
                            ; Z Probe
                            M558 K0 P9 F120 H3 R0 T6000 A1 B0 C"0.io4.in"  ; Set Z probe type.
        ; K (Z probe number): 0 (1).
        ; P (Z Probe type): 9 (BLTouch probe).
        ; F (Feed rate. Probing speed [mm/min]): 120.
        ; H (Dive height [mm]): 3.
        ; R (Recovery time [seconds]): 0.
        ; T (Travel speed [mm/min]): 6,000.
        ; A (Max number of times to probe each point): 1.
        ; B (Heaters): 0 (Leave all heaters on while probing).
        ; C (Endstop input): 0. (Mainboard) io4.in.
                            M950 S0 C"0.io4.out"                           ; Create GPIO/servo pin.
        ; S (Output/servo pin number): 0.
        ; C (Pin name): 0. (Mainboard) io4.out.
                            G31 P500 X0 Y22.0 Z3.105 K0                    ; Set Z probe.
        ; P (Trigger value): 500.
        ; X (Probe X offset [mm]): 0.
        ; Y (Probe Y offset [mm]): 22.000.
        ; Z (Probe Z offset [mm]): 3.105 (This is modified for Z probe calibration. A higher offset number moves the nozzle closer to the bed.).
        ; K (Z probe number): 0.
                            M557 X25:325 Y25:313.5 P3                      ; Define Z probe mesh grid (This is the probe point grid, not the nozzle grid).
        ; X (Min:Max X coordinates to probe [mm]): 35 (Min) : 325 (Max).
        ; Y (Min:Max Y coordinates to probe [mm]): 25 (Min) : 313.5 (Max).
        ; P (Points to probe in each direction): 3.
                            fcwiltundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                            • fcwiltundefined
                              fcwilt @Charlie
                              @charlie
                              Thanks.
                              Let's changes things just a bit:
                              M558 P9 C"0.io4.in" H3 T6000 F120 A1 R0.2 B0
                              G31 P25 X0 Y22.0 Z3.105
                              Reset and try what I suggested before BUT lets use G92 Z7 instead of G92 Z3
                              • Charlieundefined
                                Charlie @fcwilt
                                @fcwilt
                                Same problem. Probe did not deploy. Same error: "Error: Probe was not triggered during probing move"
                                • fcwiltundefined
                                  fcwilt @Charlie
                                  And yet when you issued the M208 S1 Z-100 and then the G30 it seemed to work?
                                  • Charlieundefined
                                    Charlie @fcwilt
                                    @fcwilt
                                    This is correct, but I cant seem to replicate the scenario in which it worked.
                                    • fcwiltundefined
                                      fcwilt @Charlie
                                      @fcwilt
                                      Well we are overlooking something simple.
                                      Did you post what the DWC Z Probe readout value is?
                                      • Charlieundefined
                                        Charlie @fcwilt
                                        @fcwilt
                                        Z Probe readout value is 0, and remains 0 for the entire homing attempt.
                                        Charlieundefined 1 Reply Last reply Reply Quote 1
                                        • Charlieundefined
                                          Charlie @Charlie
                                          Im unsure as to whether this means anything, but the BLTouch light remains a solid red when the machine is idle, as well as before and during the homing process. Of course the light shuts off when I power off the machine to prevent crashing, but the probe also deploys when power is turned off while the Z probe is occuring.
                                          • fcwiltundefined
                                            fcwilt @Charlie
                                            Well it's getting late and I've got to get some sleep.
                                            Sorry we couldn't get it sorted in this session.
                                            I will run some tests with my BLTouch and see I can determine what conditions could be causing your problems.
                                            Talk to you later.
                                            Good night.
