    BLTouch Probe Won't Deploy
    4.9k
    • fcwiltundefined
      fcwilt @Charlie
      @charlie said in BLTouch Probe Won't Deploy:
      With the modification to the homex.g file to include G91 before the M558, the probe is working intermittently. Any other considerations that Im not making? Could interference be a part of the problem?
      I would try this.
      • In the config.g file set your M558 to the values you want to use during probing.
      • Remove/comment out both M558s and one G30 in your home Z file
      • Reset
      • Home X
      • Home Y
      • Home Z
      Charlieundefined 1 Reply Last reply Reply Quote 0
      • Charlieundefined
        Charlie @fcwilt
        @fcwilt
        Thank you for your response. Unfortunately I tried this already, and it failed to deploy. Also, when performing a G29, the probe extended on the first probe point, but failed to deploy on the second one.
          Phaedrux Moderator @Phaedrux
          @phaedrux said in BLTouch Probe Won't Deploy:
          Are you using toolboards or expansion boards or just the 6HC?
          • Charlieundefined
            Charlie @Phaedrux
            @phaedrux
            Yes, I am using a Duet 3 Expansion board 3HC
            • fcwiltundefined
              fcwilt @Charlie
              @phaedrux
              Move your connection to the 6HC to rule out any problems with communications to the 3HC or the 3HC itself.
              • Charlieundefined
                Charlie @fcwilt
                @fcwilt said in BLTouch Probe Won't Deploy:
                It is.
                • fcwiltundefined
                  fcwilt @Charlie
                  It is.
                  Did you try it with the 3HC disconnected?
                  • Charlieundefined
                    Charlie @fcwilt
                    @fcwilt
                    Issue persists with 3HC disconnected at the can port and with the fuse removed.
                    • fcwiltundefined
                      fcwilt @Charlie
                      @fcwilt
                      This is just bizarre.
                      I did a number of tests on my printer, but it was with a Duet 2 WiFi board, and I could not create any conditions, short of incorrect code, to cause the probe to fail.
                      I do have a 6HC. It won't be hard to hook up one of my spare BLTouch.
                      But that is for tomorrow.
                      • Charlieundefined
                        Charlie @fcwilt
                        @fcwilt
                        I can't tell you how grateful I am for your assistance! Im going to re run the wire to rule out faulty wiring (not a small feat given the voron drag chains, lol). I will report back my findings.
                        • fcwiltundefined
                          fcwilt @Charlie
                          @fcwilt
                          I'm just upset that we haven't found the problem yet.
                          My first check on wiring would be to run something directly as possible from the board to the probe without worrying about making it actually work for printing. Just enough wire for testing.
                          • JoergS5undefined
                            JoergS5 @Charlie
                            M558 K0 P9 F120 H3 R0 T6000 A1 B0 C"0.io4.in"
                            I've found a comment here https://forum.duet3d.com/topic/16791/3-1-1-bltouch-doesn-t-function-after-cancelling-a-job/7 which may help, setting the R parameter higher than 0 for recovery time. Maybe you want to try it. This thread has other interesting proposals like noise reduction also.
                              Here are the things I would suggest trying:
                              1. Try a fresh basic config from the config tool to rule out something being weird in your current config.
                              2. Try temporarily switching to standalone mode to remove the SBC from the setup.
                              3. Try the 3.4 beta6 release.
                              • Charlieundefined
                                Charlie
                                Upon some preliminary testing, it appears as though the wiring may be to blame. In a few days Ill have the time to do some more digging. Ill keep you posted as to the results. Thank you all for your help so far!
                                • Charlieundefined
                                  Charlie
                                  After a long hiatus, Ive come back to the project and it definitely was a wiring issue. The silicone ribbon cable jacket was completely intact, but the wire inside was frayed. Hopefully with a Toolboard installed, I should have less wiring issues. Thank you again to everyone for your help in troubleshooting!
