    rrf 3.4 beta update on ODROID sbc not possible
    Beta Firmware
    1.0k
    • joekoundefined
      joeko
      hi,
      i try to update my duet3 6 with sbc to the latest beta but i always get the message that updates hold back. i tried different os and of course i follow the guide. i searched for a solution what this message mean with debian and i always get the info that there is a problem with the sources but not solution work.
      now i look for a new 3.4 beta but until now there are no new beta.
      i ask me what is wrong. i follow the setupguide exactly and it seems that other use rrf 3.34 beta on sbc
      • rjenkinsgbundefined
        rjenkinsgb
        On mine, I just did
        sudo apt update
        sudo apt upgrade
        to get everything synced to the latest release versions first. and rebooted it.
        Then the unstable feed change:
        Upgrading to unstable packages
        This step is relatively trivial. Be aware that potential downgrades can involve more work.
        Change stable to unstable in /etc/apt/sources.list.d/duet3d.list (sudo bash -c "echo 'deb https://pkg.duet3d.com/ unstable armv7' > /etc/apt/sources.list.d/duet3d.list")
        Run a system update (sudo apt update && sudo apt upgrade)
        The latest unstable packages should be installed
        Downgrading to stable packages
        And repeat the update / upgrade as above.
        That should automatically reflash the Duet and any connected add-on boards.
        Downgrading is more complex...
        Note that the above is based on using the latest "DuetPi" card image to to run the Raspberry Pi - if you have used any other OS version, there is no guarantee the packages will match up and install properly, I'd guess.
        Robert J.
        Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
        joekoundefined 1 Reply Last reply Reply Quote 0
        • joekoundefined
          joeko @rjenkinsgb
          @rjenkinsgb said in rrf 3.4 beta update on sbc not possible:
          On mine, I just did
          sudo apt update
          sudo apt upgrade
          i did this more than 10 times 😞
          rrf 3.3 stable is all fine (after modify the the json) but update to the latest beta is not possible (on an odroid c4 with ubuntu or debian)
          rjenkinsgbundefined 1 Reply Last reply Reply Quote 0
            rjenkinsgb @joeko
            @joeko said in rrf 3.4 beta update on sbc not possible:
            on an odroid c4
            That appears to be the problem, then - if it's not the same base OS and packages as the DuetPi OS image, the new package dependencies may not be met.
            Unless someone else has used the exact same board and more information, you appear to be stuck with a non-standard system, at least until 3.4 is a formal release - you could try again then, or try building from scratch.
            Robert J.
            • joekoundefined
              joeko
              thank you for your answer.
              i will see.
              i like the odroid boards with the emmc card. stable and fast
              but the duetpi os is also based on debian...
              PCRundefined 1 Reply Last reply Reply Quote 0
              • PCRundefined
                PCR @joeko
                @joeko can you post the output of apt upgrade
                PCRundefined joekoundefined 3 Replies Last reply Reply Quote 0
                • PCRundefined
                  PCR @PCR
                  @pcr and apt update
                  • joekoundefined
                    joeko @PCR
                    @pcr said in rrf 3.4 beta update on ODROID sbc not possible:
                    hmm, at the moment i dont use this combination but there are no error message. apt update show that the unstable list is loading and apt upgrade also that the duet files "hold back" i have all tried what i have found to fix that but always the same. but !! no problem with the stable rrf 3.3
                    but if you have an idea i try it again of course and post the output
                    • Nurgelrotundefined
                      Nurgelrot
                      Try unholding the packages:
                      # sudo apt-mark unhold \
                          duetsoftwareframework \
                          duetcontrolserver \
                          duetruntime \
                          duetsd \
                          duettools \
                          duetwebcontrol \
                          duetwebserver \
                          reprapfirmware
                      # sudo apt update
                      # sudo apt upgrade
                      joekoundefined 2 Replies Last reply Reply Quote 0
                      • joekoundefined
                        joeko @Nurgelrot
                        @nurgelrot said in rrf 3.4 beta update on ODROID sbc not possible:
                            duetcontrolserver \
                            duetruntime \
                            duetsd \
                            duettools \
                            duetwebcontrol \
                            duetwebserver \
                            reprapfirmware
                        # sudo apt update
                        # sudo apt upgrade
                        i will do it
                        do you use your odroid c4 with the latest beta ?
                        if so, which os and did you do this on this way ?
                        • joekoundefined
                          joeko @PCR
                          here the apt-update and upgrade
                          OK:1 http://ppa.launchpad.net/hardkernel/ppa/ubuntu bionic InRelease
                          OK:2 http://archive.canonical.com/ubuntu focal InRelease
                          OK:3 http://ports.ubuntu.com/ubuntu-ports focal InRelease
                          OK:4 http://ports.ubuntu.com/ubuntu-ports focal-updates InRelease
                          OK:5 https://pkg.duet3d.com unstable InRelease
                          OK:6 http://ports.ubuntu.com/ubuntu-ports focal-backports InRelease
                          OK:7 http://ports.ubuntu.com/ubuntu-ports focal-security InRelease
                          Holen:8 http://deb.odroid.in/c4 focal InRelease [1.697 B]
                          Es wurden 1.697 B in 2 s geholt (733 B/s).
                          Paketlisten werden gelesen... Fertig
                          Abhängigkeitsbaum wird aufgebaut.
                          Statusinformationen werden eingelesen.... Fertig
                          Aktualisierung für 8 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
                          and upgrade
                          sudo apt upgrade
                          Paketaktualisierung (Upgrade) wird berechnet... Fertig
                          Die folgenden Pakete sind zurückgehalten worden:
                            duetcontrolserver duetpluginservice duetruntime duettools duetwebcontrol
                            duetwebserver reprapfirmware
                          0 aktualisiert, 0 neu installiert, 0 zu entfernen und 7 nicht aktualisiert.
                          but apt list --upgradable
                          Listing... Done
                          duetcontrolserver/unstable 3.4-b5 arm64 [upgradable from: 3.3.0]
                          duetpluginservice/unstable 3.4-b5 arm64 [upgradable from: 3.3.0]
                          duetruntime/unstable 3.4-b5 arm64 [upgradable from: 3.3.0]
                          duetsoftwareframework/unstable 3.4-b5 arm64 [upgradable from: 3.3.0]
                          duettools/unstable 3.4-b5 arm64 [upgradable from: 3.3.0]
                          duetwebcontrol/unstable 3.4-b5 all [upgradable from: 3.3.0]
                          duetwebserver/unstable 3.4-b5 arm64 [upgradable from: 3.3.0]
                          reprapfirmware/unstable 3.4-b6-1 all [upgradable from: 3.3.0-1]
                          is there a mix of beta version and make the problem ?
                          • joekoundefined
                            joeko @Nurgelrot
                                duetcontrolserver \
                                duetruntime \
                                duetsd \
                                duettools \
                                duetwebcontrol \
                                duetwebserver \
                                reprapfirmware
                            # sudo apt update
                            # sudo apt upgrade
                            thank you but the same like before. still hold back and update not possible. please look at my post one back
                            • o_lampeundefined
                              o_lampe @joeko
                              @joeko said in rrf 3.4 beta update on ODROID sbc not possible:
                              Have to tried to upgrade to beta5 first, and if successful, go for beta6?
                              • joekoundefined
                                joeko @o_lampe
                                @o_lampe said in rrf 3.4 beta update on ODROID sbc not possible:
                                no, fresh and new install this morning on duet3 mini.
                                first with rf 3.3 (all fine) and update to the beta
                                Nurgelrotundefined 1 Reply Last reply Reply Quote 0
                                • joekoundefined
                                  joeko @o_lampe
                                  hmm, if didnt try it but if possible i will.
                                  but how i can do this ? as far as i know i can only update to the latest beta.
                                    Nurgelrot @joeko
                                    @joeko So is this issue solved? I'm on 3.4 beta6 on both a Duet3d mini5 and a BTT GTR board using the STM32 port of RRF.
                                    using Armbian (debian 10.11 aka buster)
                                    • joekoundefined
                                      joeko @Nurgelrot
                                      no way, always the same.
                                      updates hold back and it seems that the betas are mixed....
                                      witch gpiochip and pinnumber did you set in the json ?
                                      witch way you have used for install, first stable and than beta ?
                                        Nurgelrot @joeko
                                        @joeko I'm always following unstable on these so I went from 3.4 Beta somthing to Beta 6
                                        I did have an issue with the STM32 version not patching right away it complained about a dependency problem with duetsoftwareframework requiring <= reprapfirmware 3.4-b5-999. I removed all the duet packages and reinstalled latest unstable and it worked.
                                        My transfer pin is 67 on /dev/gpiochip0. But these are different on different versions of linux on the odroid C4. I remember that the ubuntu version shipped with the Odroid had it at pin 68 on chip1
                                        if any version is installed but nothing is running (or you have shut it down) try running:
                                        sudo /opt/dsf/bin/DuetControlServer -ud
                                        that will produce errors on screen if you have any sort of communication problem. ^D or ^C to exit.
                                        • joekoundefined
                                          joeko @Nurgelrot
                                          with armbian buster it works. i also did it with buster from hardkernel (meveric from forum) but this was not possible. now it works.
                                          give me
                                          Duet Control Server v3.4-b6
                                          Written by Christian Hammacher for Duet3D
                                          Licensed under the terms of the GNU Public License Version 3
                                          [info] Settings loaded
                                          [fatal] Another instance is already running. Stopping.
                                          i think that is ok because it is running
                                          thank you for your help
                                          @chrishamm
                                          it would make it easier when it offer the choice to modify the json for the tfr pin while the installation...much easier.
                                          jay_s_ukundefined Nurgelrotundefined 2 Replies Last reply Reply Quote 0
                                            jay_s_uk @joeko
                                            @joeko I've updated our DSF on armbian instructions here
                                            https://teamgloomy.github.io/dsf_on_armbian.html
