    Industrial AC servo drive compatibility?
    • Luka_Damundefined
      Luka_Dam
      Hello I am trying to use a Duet 3 MB6HC with a E1XD to control a servo driver with the step/dir signals of the E1XD.
      The problem is that the step and dir pins of the E1XD are 5V while the step and dir inputs of the driver are 12-24V, my question is if there is any way to use higher signal voltages on the expansion board.
      The driver that I'm trying to control is a Hiwin ED1S-VN-0422-A1.
      https://www.hiwin.de/en/Products/Servo-drives/Servo-drive-ED1/Servo-drive-ED1S-VN-0422-A1/p/23.00097
      Thanks.
      mrehorstdmdundefined Falkiaundefined 2 Replies Last reply Reply Quote 0
      • mrehorstdmdundefined
        mrehorstdmd @Luka_Dam
        @luka_dam something like this might do the job: https://www.petervis.com/electronics guides/frequency multiplier 2/5v to 12v conversion.html
        • Falkiaundefined
          Falkia @Luka_Dam
          @luka_dam made a quick check in the manual and it looks like positioning mode type 6 supports TTL levels.
          Printer: "Deltacus" Delta with 510mm bed diameter and 925mm build height. Powered by Duet 2 WiFi. Duet Smart Effector with E3D Volcano.
          Luka_Damundefined 1 Reply Last reply Reply Quote 1
          • Luka_Damundefined
            Luka_Dam @Falkia
            @falkia thank you! I guess I missed it when I was looking in the manual.
            Falkiaundefined 1 Reply Last reply Reply Quote 0
            • Falkiaundefined
              Falkia @Luka_Dam
              @luka_dam You are welcome. Please mark this topic as "Solved".
              • Luka_Damundefined Luka_Dam has marked this topic as solved
