Toolboard 1.1 - Driver not present
I installed a original brand new Toolboard 1.1 in my new voron 2.4, equipped with Duet 3 mini 5.The toolboard is perfectly working (fans, cartdrige ecc) but the stepper extruder is not working.
I checked with diagnostics and the is a "Not Present" about the driver 0.This is the diagnostic
m122 b121 Diagnostics for board 121: Duet TOOL1LC rev 1.1 or later firmware version 3.4.0beta6 (2021-11-06 11:56:11) Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1) Never used RAM 2576, free system stack 2788 words Tasks: Move(notifyWait,0.0%,153) HEAT(notifyWait,0.2%,113) CanAsync(notifyWait,0.0%,64) CanRecv(notifyWait,0.0%,77) CanClock(notifyWait,0.0%,64) ACCEL(notifyWait,0.0%,61) TMC(notifyWait,0.4%,67) MAIN(running,94.4%,350) IDLE(ready,0.0%,27) AIN(delaying,4.9%,142), total 100.0% Last reset 00:09:54 ago, cause: power up Last software reset data not available Driver 0: pos 0, 656.0 steps/mm,not present, steps req 0 done 0 Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0 Peak sync jitter -4/6, peak Rx sync delay 213, resyncs 0/0, no step interrupt scheduled VIN voltage: min 24.2, current 24.2, max 24.2 MCU temperature: min 30.3C, current 30.6C, max 35.0C Last sensors broadcast 0x00000002 found 1 135 ticks ago, 0 ordering errs, loop time 0 CAN messages queued 10672, send timeouts 0, received 4800, lost 0, free buffers 37, min 37, error reg 0 dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0 Accelerometer detected: yes, status: 00 I2C bus errors 0, naks 0, other errors 0
This is my config
; Configuration file for Duet3 Mini5+ with Mini2+ expansion (firmware version 3.3 or newer) ; executed by the firmware on start-up ; General preferences M80 C"pson" ; Turns on the ATX power supply M111 S0 ; Debugging off G21 ; Work in millimetres G90 ; Send absolute coordinates... M83 ; ...but relative extruder moves M669 K1 ; Select CoreXY mode M564 S1 H1 ; Forbid axis movements when not homed ;M918 P2 E4 F2000000 C30 R6 ; Fysetc 12864 display ; Wait a moment for the CAN expansion boards to start G4 S2 ; M575 P1 S1 B57600 ; enable support for PanelDue ; Network M550 P"Voron V2.4" ; Set machine name M552 S1 ; enable network M587 S"xxxxx" P"xxxxxx" ; Configure access point. You can delete this line once connected M586 P0 S1 ; enable HTTP M586 P1 S1 ; disable FTP M586 P2 S0 ; disable Telnet ; --- Z Drive map --- ; _______ ; | 1 | 2 | ; | ----- | ; | 0 | 3 | ; ------- ; front ; ; (looking at the printer from the top) ; Drive directions M569 P0 S1 D2 ; Z0 M569 P1 S0 D2 ; Z1 M569 P2 S1 D2 ; Z2 M569 P3 S0 D2 ; Z3 M569 P121.0 S0 ; Extruder M569 P5 S1 D2 ; A M569 P6 S1 D2 ; B ; Motor mapping and steps per mm M584 X5 Y6 Z0:1:2:3 E121.0 M350 X16 Y16 Z16 E16 I1 ; Use 1/16 microstepping with interpolation everywhere M92 X160 Y160 Z413 ; Set XY(0.9 deg motors)and Z(1.8deg motors)steps per mm ;M92 E432 ; BMG Extruder steps per mm M92 E656 ; GALILEO Extruder steps per mm ; Drive currents M906 X1250 Y1250 Z1400 E600 ; XYZ and E current M906 I30 ; Idle current percentage M84 S120 ; Idle timeout ; Accelerations and speed M98 P"/macros/print_scripts/setup_printing.g" ; Axis travel limits M208 X0 Y0 Z-8 S1 ; Set axis minima M208 X300 Y306 Z275 S0 ; Set axis maxima ; Endstops M574 X2 S1 P"io3.in" ; Xmax endstop on hall effect board M574 Y2 S1 P"io1.in" ; Ymax endstop on hall effect board M574 Z0 P"nil" ; No Z endstop ; Bed leveling M671 X-65:-65:365:365 Y0:395:395:0 S20 ; Define Z belts locations (Front_Left, Back_Left, Back_Right, Front_Right) M557 X25:275 Y25:275 P8:8 ; Define bed mesh grid (inductive probe, positions include the Y offset!) ;********************************************************************* Z PROBES ;SENSORE INDUTTIVO HOTEND M558 K0 P8 C"121.io2.in" T18000 F120 H5 A5 S0.01 R0.2 G31 K0 P500 X0 Y25 Z2 ; Offset sensore ;MICROSWITCH Z M558 K1 P8 C"^io6.in" T18000 F240:60 H2 A10 S0.005 R0.2 G31 K1 P500 X0 Y0 Z0.73 ; Z switch offset (if positive, greater value = lower nozzle. if negative, more negative = higher nozzle) ;******************************************************************************* ; Heaters M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0 M950 H0 C"out0" T0 ; create bed heater output on out0 and map it to sensor 0 M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S115 ; set temperature limit for heater 0 to 100C M308 S1 P"121.temp0" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin 121.temp0 M950 H1 C"121.out0" T1 ; create nozzle heater output on 121.out0 and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit ;M307 H1 B0 M143 H1 S280 ; set temperature limit for heater 1 to 280C ; Fans M950 F0 C"121.out1" Q500 ; create fan 0 on pin 121.out1 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"121.out2" Q500 ; create fan 1 on pin 121.out2 and set its frequency M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Misc ; M572 D0 S0.075 ; Pressure Advance ; M592 D0 A0.015 B0.0012 L0.2 ; Non-linear extrusion ; DAA tuning M955 P121.0 I05 ; create accelerometer on P121.0 ; M572 D0 S0.01 ; Pressure Advance ; M376 H10 ; Fade mesh out compensation over 10mm Z M575 P1 S1 B57600 ; enable support for PanelDue M501 ; load config-override.g T0 ; select tool 0
What i'm doing wrong?
Thanks -
I can't see anything obvious..
What do you have in the "Setup printing" macro?
@rjenkinsgb
Set stepper current to 100%
Set jerk, accelerations etc. -
Tried with 3.4.0 beta 7
After M122 b121 the driver info is like that:
"Driver 0: pos 6560, 656.0 steps/mm,ok, steps req 6560 done 6560"But the stepper is not working at all.
Check the motor wiring?
The motors on my extruders have the centre two pins swapped compared to the axis motors.
Are you trying to extrude without the temperature being above 160c?
@rjenkinsgb Wirings are ok, tested with 2 different steppers that are working on other boards (duet boards)
@phaedrux Driver not "drive" stepper. I tried with 200°c and using M302
This post is deleted! -
Problem solved....
Is the driver.
I have another toolboard (never used, unboxed and installed) from the same reseller (filafarm.de).
Same wirings, same config, and works like a charm.
So the first Toolboard have a not working driver.
Can a moderator allow (give ok) reseller to replace this board? -
Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
@phaedrux said in Toolboard 1.1 - Driver not present:
Done. Thanks
