    InputShaping-Plugin-0.2.0-pre8-2 released
    Plugins for DWC and DSF
    12
    24
    2.2k
    • mfs12undefined
      mfs12
      Repack to work with DWC-3.4-b7.
      For release notes check https://github.com/mfs12/DuetWebControl/releases/tag/inputshaping-plugin-0.2.0-pre8.
      Downloads can be found at https://github.com/mfs12/DuetWebControl/releases/tag/inputshaping-plugin-0.2.0-pre8-2
      Visit me on github at https://github.com/mfs12/
      j3dundefined ctilley79undefined GeneRisiundefined 4 Replies Last reply Reply Quote 2
      • j3dundefined
        j3d @mfs12
        @mfs12 This is a really neat plugin, thanks for all your work!
        I was wondering if you could make the A parameter of the M956 command editable? It seems to be hardcoded to A2 in InputShapingSession.js. I seem to get much better results with the following command in the documentation where A0 is used.
        Acceleration measurements captured during movement typically show higher frequency components caused by the motors and belts. For this reason, you may get results that are easier to interpret if you collect data immediately after a sharp stop, using a command such as this:
        ; Duet 3 and 2, accelerometer connected to mainboard (M956 P0)
        G1 X-50 G4 S2 G1 X50 F20000 M400 M956 P0 S1000 A0
        Source: https://duet3d.dozuki.com/Wiki/Accelerometers#Section_Sampling_rate_and_resolution
          dc42 administrators @j3d
          @j3d the A parameter of M956 doesn't work yet.
          j3dundefined 1 Reply Last reply Reply Quote 0
          • j3dundefined
            j3d @dc42
            @dc42 said in InputShaping-Plugin-0.2.0-pre8-2 released:
            Ah, so does it always evaluate to A0 currently?
            I also needed to switch my accelerometer to 12 bit resolution in order to capture any meaningful results.
            • Heartleander81undefined
              Heartleander81
              @mfs12 @dc42
              Today arrived my New tool board and the Accelerometer test worked now.
              I See the Hz .
              Thanks Dc42 and mfs12 for your help and Support.
              • ctilley79undefined
                ctilley79 @mfs12
                @mfs12 Can you repack this for 3.4 RC1 real quick?
                  jay_s_uk @ctilley79
                  @ctilley79 you can edit the json file in the zip to change the RRF version
                  ctilley79undefined 1 Reply Last reply Reply Quote 0
                    ctilley79 @jay_s_uk
                    @jay_s_uk No other dependencies in package.json between DWC 3.4 b7 and DWC 3.4 RC1 have changed that would affect Input Shaper Plugin 0.20 pre 8-2?
                      jay_s_uk @ctilley79
                      @ctilley79 nope
                      ctilley79undefined 1 Reply Last reply Reply Quote 1
                        ctilley79 @jay_s_uk
                        @jay_s_uk Thanks!
                          ctilley79 @mfs12
                          @mfs12
                          Tried to repackage the InputShaper plugin using the following steps.
                          • Downloaded source for DWC 3.4.0-RC1
                          • Copied InputShaper files from the 0.2.0-pre8-2 source into plugins folder
                          • Modified plugins/index.js to instantiate a new DwcPlugin for InputShaper
                          • Changed version number in src/plugins/InputShaping/plugin.json
                          • Installed some missing dependencies
                          • Ran npm run build and compiled successfully
                          • Grabbed the InputShaper JS and CSS files and structured the directories and files identical to the InputShaper plugin source code.
                          • zipped everything up and uploaded to DWC.
                          The issue is the last step. Uploading the plugin I get a brief notification that the files are being extracted, however the process dies silently with no errors. The popup to install a plugin never appears after upload. Am I missing something here?
                            jay_s_uk @ctilley79
                            @ctilley79 don't need to do that. Literally download the release zip file for 3.4b7 and edit the JSON file to say 3.4rc1.
                            ctilley79undefined 2 Replies Last reply Reply Quote 0
                              ctilley79 @jay_s_uk
                              @jay_s_uk Tried that bud. Did not work so I went the complicated route
                                ctilley79 @jay_s_uk
                                @jay_s_uk Unless my mac is not zipping up the files correctly then I'm at a loss
                                • Diamondbackundefined
                                  Diamondback
                                  Mine doesn't work either after changing just the version.
                                  SIamundefined 1 Reply Last reply Reply Quote 0
                                  • SIamundefined
                                    SIam @Diamondback
                                    I think we have to wait for the next version ....
                                    Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
                                    Duet WiFi 1.02 or later + DueX5
                                    RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
                                    Duet WiFi Server: 1.26
                                    Duet Web Control 3.4.0beta4 (2021-09-27)
                                    ctilley79undefined A Former User? 2 Replies Last reply Reply Quote 2
                                      ctilley79 @SIam
                                      @siam Hey. At least you got it to install
                                        jay_s_uk @ctilley79
                                        @ctilley79 InputShaping-0.2.0-pre8.txt
                                        rename it to .zip
                                          ctilley79 @jay_s_uk
                                          @jay_s_uk Nice way to get past the censors lol. Just out of curiosity, what process did you follow to fix the package?
                                            jay_s_uk @ctilley79
                                            @ctilley79 had to rebuild this one in the end due to DWC changes
