Mapping PT1000 sensors on Toolboard to Heater Outputs on 6HC
I am very close to having my machine ready but I am running into one issue. The sensor appears to not exist to the system when mapping my two PT1000 sensors connected to my Toolboard and my two heaters on my 6HC. I get "M308 S1 H999
Error: M308: Sensor 1 does not exist" and "Error: Temperature reading fault on heater 1: unknown sensor" when trying to interact with them. Here is my config; the S2 is set to be a redundant backup for failures:; configuration file for Duet 3 Mini 5+ (firmware version 3.3) with Duet 3 Toolboard1LC, Rotating Magnet Filament Monitor ; executed by the firmware on start-up ; General preferences M575 P1 S1 B57600 ; enable support for PanelDue G21 ; work in millimeters G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"duet3" ; set printer name M669 K1 ; select CoreXY mode ; Tool board (CAN ID #121) G4 S6 ; wait for tool board to start ; PanelDue Enable M575 P1 S1 B57600 ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0.0 S0 D3 ; physical drive 0.0 goes forwards use stealthChop2 M569 P0.1 S0 D3 ; physical drive 0.1 goes forwards use stealthChop2 M569 P0.2 S0 D3 ; physical drive 0.2 goes forwards use stealthChop2 M569 P0.3 S1 D3 ; physical drive 0.3 goes forwards use stealthChop2 M569 P0.4 S1 D3 ; physical drive 0.4 goes forwards use stealthChop2 M569 P121.0 S1 D3 ; physical drive 121.5 goes forwards use stealthChop2 M584 X0.4 Y0.3 Z0.0:0.1:0.2 E121.0 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z800.00 E830.00 ; set steps per mm M566 X400.00 Y400.00 Z6.00 E120.00 P1 ; set maximum instantaneous speed changes (mm/min) M203 X10800.00 Y10800.00 Z1000.00 E3600.00 ; set maximum speeds (mm/min) M201 X3000.00 Y3000.00 Z100.00 E3600.00 ; set accelerations (mm/s^2) M906 X1000 Y1000 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in percent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X505 Y500 Z500 S0 ; set axis maxima ; Endstops M574 X1 S1 P"121.io2.in" ; configure switch-type (e.g. microswitch) endstop for high end on X via pin io2.in on toolboard M574 Y2 S1 P"io6.in" ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin io6.in M574 Z1 S2 ; configure Z-probe endstop for low end on Z ; Z-Probe M950 S0 C"121.io0.out" ; create servo pin 0 for BLTouch on tool board M558 P9 C"121.io0.in" H5 F120 T6000 A5 ; set Z probe type to bltouch and the dive height + speeds on tool board G31 P500 X-40 Y-30 Z0.9 ; set Z probe trigger value, offset and trigger height M671 X-4.5:250:500 Y-4.52:500:-4.52 S5 ; define positions of Z leadscrews, 5mm maximum correction M557 X20:280 Y20:280 P5 ; define 5x5 mesh grid ; Bed Heater M308 S0 Q10 P"temp0" Y"thermistor" T100000 B3950 A"Bed" ; configure sensor 0 as thermistor on pin temp0 M950 H0 C"out0" T0 ; create bed heater output on out1 and map it to sensor 0 M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C ; Mosquito Magnum+ Separate Heaters Single Tool (Two Sensors) ; Two Temperature Sensors M308 S1 P"121.temp0" Y"pt1000" A"RightTemp" ;Pt1000 located in right side of hot block M308 S2 P"121.temp1" Y"pt1000" A"LeftTemp" ;Pt1000 located in left side of hot block ; Define Mosquito Magnum+ heaters M950 H1 C"out2" T1 ;Single Heater M950 H2 C"out3" T1 ;Second Heater ; Define Monitor Temperature Sensor M143 H1 P1 S310 T2 A0 M143 H2 P1 S310 T2 A0 ;Mosquito Magnum+ Max Temperatures M143 H1 S310 M143 H2 S310 ;Tool Definition Mosquito Magnum+ ;M563 P0 D0 H1:2 S"Mosquito Magnum+" F1 ;Define Mosquito Magnum+ Tool ;T0 ;Set tool 0 as active tool ;G10 P0 S0:0 R0:0 ;Set tool operating and standby temperatures ;; Run Bed PID Tune!! Below is an example for a 300x300 bed ;; M307 H0 A303.1 C356.7 D1.4 S1.00 V24.0 B0 ;; Run Heater PID Tune!! ;; M307 H1 A751.5 C196.6 D4.7 S1.00 V23.9 B0 ; Fans M950 F0 C"out5" Q500; create fan 0 on pin out1 on tool board and set its frequency M106 P0 C"Watercooling Fan" S1 H1 T45 ; set fan 0 value. Thermostatic control is turned on M950 F1 C"121.out2" Q500 ; create fan 1 on pin out2 on tool board and set its frequency M106 P1 C"Layer Fan" S1 H-1 ; set fan 1 value. Thermostatic control is turned off ; Tools M563 P0 S"Mosquito Magnum+" D0 H1:2 F1 ; define tool 0 with extruder drive 0 heater 1 and fan 1 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C M302 S180 R180 ; allow extrusion starting from 180C and retractions already from 180C ; Accelerometer M955 P121.0 I12 ; Accelerometer on tool board, oriented counter-clockwise 90 ; Filament Monitor M591 D0 P3 C"121.io1.in" S1 R70:130 L24.8 E3.0 ; Duet3D rotating magnet sensor for extruder drive 0 is connected to io1.in on tool board, ; enabled, 70% to 130% tolerance, sensitivity 24.8mm.rev, 3mm detection length ; Custom settings M404 N1.75 D0.4 ; set filament width and nozzle diameter -
As far as I am aware, this is a current limitation imposed by RRF. Heaters and their sensors must be present on the same board to function correctly. (I am trying to find the documentation that explains this in detail.)
@alex-cr Damn! That may be a serious issue. I cut my PT1000 wires for Toolboard length. I wanted to run the heaters separately, mainly for safety, as it is 100 watts of heater.
@alex-cr Maybe running one PT1000 off the Toolboard and then running one back to the mainboard...hmmm idk. I wonder if there is a trick to override that.
The only real way around it would be to drive the heaters with an external mosfet off of the toolboard. This way the toolboard does all of the work but power could come from some place besides the toolboard itself.
Edit: Somthing like this. link text
@alex-cr Well damn...seems just running the PT1000s back to the board is the only option, really. The mosfets would defeat the purpose.
Not entirely. You can still drive all of your fans and temp sensors from the toolboard itself. The power wires that run to the toolboard could be branched to power the mosfet. This way you don't need to rerun any major wiring back to the mainboard. That being said it might be easier to extend the wires for the PT1000s and call it a day.
https://duet3d.dozuki.com/Wiki/Duet_3_firmware_configuration_limitations
Do you mean these limitations?
