US Repair service?
I am out of warranty by about a week.
I purchased a Duet 3 6HC board for a special project a year ago and the project got delayed and I put the board on the shelf and just now tried to use it.
I flashed an SD card with the initial network configuration of DHCP and expected it to appear on the network.
Then I tried the USB port and it was unrecognized by three different computers and cables under Windows 11, 7 and 10.
I then did the erase procedure and still no result other than powering the Duet board.
I do have an operational 3D printer with a Duet 2 Wify board and I am also unable to get the USB port to work on this board also. This board is way behind on updates so now leery of trying to update it if the USB port is not working.
Any suggestions ?
The project all of a sudden reached critically so I am going to have to buy another board, but I would still like the previous one repaired.
Thanks
You have two boards (both tested at factory) one never used, that are not communicating via USB, and your conclusion is that both are bad, not that you have done something wrong?
@elmoret Ok a prefect storm of stuff.
Duet 2 Wify was in a 3D printed case that was destroying the USB cables as I used them. Enlarged the hole and the USB connection started working.
Duet 3 6HC board is still inoperative.
@fredsairplane said in US Repair service?:
I'd repeat this step and make sure it works. SD-card needs a special formatter and it has to be FAT16/32
For more specific help, we'd need more info about LED status, onboard voltages (5V, 3.3V present?) etc.
Ok I blew right past these steps because I did the erase procedure.
At this point I absolutely need the USB port to function.
Had I not done the erase procedure I could have tried a Raspberry PI communicating via the SPI data lines.
I expected the Bossa Port device ID to appear in the windows Device Manager after erasing the device.
At this point I need to know if there is replaceable chip between the USB port and the CPU to possibly resurrect this board. So that it appears to any USB host as a Bossa Port to reload the correct firmware.
Or per my original request is there somewhere I can send this not inexpensive board to be repaired?
@fredsairplane when the firmware is erased the SAME70 chip on the MB6HC goes into high speed USB mode and is very fussy about the USB cable and USB port. Cables that work with Duet 2 don't necessarily work with the MB6HC and USB extension cables in particular don't work. So try a different USB cable, and a different USB port on the PC.
A USB hub might also help.
And an independently powered USB hub at that
Ideally, but people have reported good results with just a hub.
Ok a USB3 hub allowed me to see the Bossa Program port!!! Standard USB hub failed...
Now trying a firmware upgrade configuration generation.
