    Extruder 0 has no filament sensor
    Filament Monitor
    1.6k
    • Dave Parryundefined
      Dave Parry
      I have installed a rotating magnetic filament monitor and used a crossover wiring as my unit is a v1.7b. The led is flashing alternativly red and green, which I understand is correct. I have put the following command in my config.sys
      M591 D0 P3 C3 S1 R70:130 L24.8 E3.0 ; Duet3D rotating magnet sensor for extruder drive 0 is connected to E0 endstop input, enabled, sensitivity 24.8mm.rev, 70% to 130% tolerance, 3mm detection length
      M591 D0 ; display filament sensor parameters for extruder drive 0
      Although I have remarked the second M591 out to see if that was the problem.
      When I send M591 D0 I get Extruder 0 has no filament sensor.
      I have checked the wiring continuety and that is ok.
      Duet Web Control is 3.4.0-b3
      Have I missed something out?
      alankilianundefined 1 Reply Last reply Reply Quote 0
      • alankilianundefined
        alankilian @Dave Parry
        @dave-parry
        Since the defaults are fine for me, I've got:
        M591 D0 P3 C"e0_stop" S1
        I'm not sure the C3 is right for RRF3?
        What version of firmware are you running?
        When I try your config, I get:
        Error: M591: expected string expression
        I'm running:
        RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.0beta5+1 (2021-10-28 21:18:12) running on Duet Ethernet 1.02 or later
        Dave Parryundefined 1 Reply Last reply Reply Quote 0
          Dave Parry @alankilian
          @alankilian I'm Running Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta6 (2021-11-06)
          I tried your config and no different, although I think your right about RRF 3. I think my version was for RRF 2 so I have changed it but still same error.
            @dave-parry
            Well, you've got blinking lights on the filament sensor, so you've got power and ground connected right.
            Can you post a photo of the wire going to the endstop input?
            That's about all that can go wrong. Either a bad connection or the wrong place on the Duet.
            Both easy problems to solve.
            Dave Parryundefined 1 Reply Last reply Reply Quote 1
              Its on the row next to the X end stop which I hope is E0 end stop. It is on my wiring connection drawing anyway. It is the wiring with the yellow heat shrink on.
              Apologies for crappy photo, but I have to take the heated bed off to get to the board, and then recalibrate.
                @dave-parry
                It looks like you've got the E0_STOP and GND wires reversed according to THIS PAGE.
                Dave Parryundefined 2 Replies Last reply Reply Quote 0
                  @alankilian Dont they reverse at the Sensor end, which would mean it doesnt matter? or have I misunderstood the instructions. If it is wrong its easy to change at the sensor end,
                    Dave Parry @Dave Parry
                    Just rechecked and on the sensor I have white wire(GnD) is going to the top connection (Gnd). Red to centre and Black Wire to Data.
                    This seems to me to be ok. Should I reverse the data and gnd to see if that cures it?
                    Agree would be better if I had Gnd as black, I Just connected the wrong end to the board.sensor end 2.jpg
                      @alankilian Have just double checked the wiring by testing from the underside of the Duet board to the sensor, and they check out ok.
                      Is there only one line of code in the config.sys.
                      ie - M591 D0 P3 C"e0_stop" S1
                      or have I missed a command out.
                        @dave-parry Do I need to define the end stop with M574?
                        I have used the following:-
                        M574 U2 S1 P"e0stop"
                          @dave-parry
                          It looks like your wiring is fine (except for the colors man 😆 ) so that's not it.
                          I do not have an M574 for the extruder stop, so that's probably the problem since it's defining a switch as the endstop type for pin e0_stop.
                          Also, make sure you have e0_stop in your M591.
                            @alankilian No I only just tried the 574 command, as I thought that might be the problem;
                            I'm using
                            M591 P3 C"e0_stop" S1
                            I have noticed that the led flashes Red-Green when no filament in and irregular green when printing. I assume thats correct.
                            alankilianundefined 2 Replies Last reply Reply Quote 0
                              @dave-parry
                              The only thing I can think of is to use an Ohm meter to check your black wire is complete.
                              Do you happen to have an oscilloscope or a USB analog capture device so you can look at the signal coming out of the sensor?
                              You could also use an LED and a resistor. (I'll have to think about how to do that a bit.)
                              Maybe someone else sees something I'm missing.
                                @dave-parry said in Extruder 0 has no filament sensor:
                                I'm using
                                You've got a D0 in there right?
                                Dave Parryundefined alankilianundefined 2 Replies Last reply Reply Quote 0
                                  @alankilian Have checked all the wires with a meter, from the back of the duet through to the pins on the connector. I also checked through to the pogo pins for the gnd and 3.3 v but the data doesnt go to them so cant check futher than the connector.
                                    @alankilian Where does that go?
                                      alankilian @alankilian
                                      Just for fun, I disconnected my sensor and did a power-on and I get:
                                      m591 d0
                                      Duet3D rotating magnet filament monitor v1 on pin e0stop, enabled, sensitivity 28.80mm/rev, allow 60% to 160%, check every 3.0mm, no data received
                                      So...... We can forget about wiring.
                                      Something else is wrong.
                                      Can you type this in the GCODE console and report back the results:
                                      • m591 D0 P1 C"e0_stop" S1
                                      • m591 D0
                                      • m591 D0 P3 C"e0_stop" S1
                                      • m591 D0
                                      Here's what I get:
                                      m591 D0
                                      Simple filament sensor on pin e0stop, enabled, output low when no filament, filament present: yes
                                      m591 D0
                                        @dave-parry Ah yes I have
                                        after the M591 command.
                                          @dave-parry
                                          Try the test commands I posted above you.
                                            @alankilian MiniKossel
                                            Status
                                            Idle
                                            Mode: FFF
                                            Tool Position
                                            X
                                            0.0
                                            Y
                                            0.0
                                            Z
                                            250.00
                                            Extruder Drives
                                            Drive 0
                                            0.0
                                            Speeds
                                            Requested Speed
                                            0 mm/s
                                            Top Speed
                                            0 mm/s
                                            Sensors
                                            Vin
                                            24.1 V
                                            MCU Temperature
                                            43.9 °C
                                            Z-Probe
                                            0
                                            Tools
                                            Extra
                                            Control Heaters
                                            Tool Heater Current Active Standby Hot End
                                            T0 - Load Filament Heater 1
                                            active 27.3 °C
                                            Bed Heater 0
                                            off 29.4 °C
                                            Temperature Chart
                                            30/12/2021, 17:48:31 m591 D0
                                            Duet3D rotating magnet filament monitor v3 on pin e0stop, enabled, sensitivity 28.80mm/rev, allow 60% to 160%, check printing moves every 3.0mm, version 3, mag 133 agc 61, no calibration data
                                            30/12/2021, 17:48:19 m591 D0 P3 C"e0_stop" S1
                                            30/12/2021, 17:48:05 m591 D0
                                            30/12/2021, 17:47:51 m591 D0 P1 C"e0_stop" S1
                                            30/12/2021, 17:47:26 m591 D0 P1 C"e0_stop" S1 m591 D0 m591 D0 P3 C"e0_stop" S1 m591 D0
                                            Simple filament sensor on pin e0stop, enabled, output low when no filament, filament present: no
                                            Duet3D rotating magnet filament monitor v1 on pin e0stop, enabled, sensitivity 28.80mm/rev, allow 60% to 160%, check printing moves every 3.0mm, no data received
