Duet 3 Mini 5+ sensor less homing setup and tune help required
Hi setting up a new custom core xy , the Z axis is belt driven on a 4:1 gear box .
M122
RepRapFirmware for Duet 3 Mini 5+ version 3.3 (2021-06-15 21:46:11) running on Duet 3 Mini5plus WiFi (standalone mode)
Board ID: 3R9YY-6T9RL-D65J0-40KMN-2UW2Z-RHYT0
Used output buffers: 3 of 40 (22 max)config.g
; generated by RepRapFirmware Configuration Tool v3.3.10 on Thu Dec 30 2021 11:07:38 GMT+1300 (New Zealand Daylight Time); General preferences
M550 P"3030 V001" ; set printer name
M669 K1 ; core xy
G29 S1 ; Set Units to Millimeters; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0.0 S1 ; physical drive 0 goes forwardsM569 P0.1 S1
M569 P0.1 S1 ; physical drive 1 goes forwardsM569 P0.1 S1
M569 P0.2 S1 ; physical drive 2 goes forwards
M569 P0.3 S1 ; physical drive 3 goes forwards
M569 P0.4 S1 D3 ; physical drive 4 goes backwards D3=stealthchop
M569 P0.5 S0 D3 ; physical drive 5 goes forwards
M569 P0.6 S1 D3 ; physical drive 6 goes forwardsM584 X0.1 Y0.0 E0.3 Z0.4:0.5:0.6 ; set drive mapping FL,FR,RC
M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolationM92 X80.00 Y80.00 Z400.00 E100.00 ; set steps per m
M566 X400.00 Y400.00 Z60.00 E900.00 P1 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z3000.00 E1200.00 ; set maximum speeds (mm/min)
M201 X1000.00 Y1000.00 Z600.00 E250.00 ; set accelerations (mm/s^2)
M906 X800 Y800 Z800 E600 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X300 Y300 Z300 S0 ; set axis maxima; Endstops
M574 X1 S1 P"io0.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin io0.in
M574 Y1 S1 P"io1.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io1.in
;M574 Z2 S2 P"!io4.in" ; != invert signal
M574 Z2 S4 ; configure sensorless endstop for high end on Z, 1 = low end, 2 = high end. S4 multipule motors
M915 P0.4:0.5:0.6 S10 F1 R1
; 3Z
M671 X-10:320:155 Y-10:-10:320 S25 ; leadscrews at front left,front right, rear Center s= max correction factor must be in same order as M584; Sensorless config
;M915 P0.4:0.5:0.6 S-50 F0 R0 ; Lower values less sensitive S3, F filter, R =Action; Z-Probe
M558 P1 C"io3.in" H5 F300 T6000 ; set Z probe type to unmodulated and the dive height + speeds
G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
M557 X15:215 Y15:195 S20 ; define mesh grid; Heaters
M143 H1 S280 ; set temperature limit for heater 1 to 280C; Fans
M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on; Tools
Macro to home Z at max
M400
;M913 Z50 ; make sure everything has stopped before we make changes
M906 Z300
G91 ; relative positioning
G1 H2 Z0.01
M400
G4 P200
M915 P0.4:0.5:0.6 S-63 F0 R0 ; Configure Z-Axis Stall Detection
M574 Z2 S4
G4 P200
G1 F3000
G1 H1 Z350 ; Home Z-Axis actuators independently
M400 ; make sure everything has stopped before we make changes
M906 Z600 ; Reset motor current
G90 ; absolute positioning
G92 Z301The issue i have is that the motors are not turning of(stall detection) when they hit the end stops, i have tried the S value from -63 to +63 .
Any help would be appreciated .
I think you will find trying to home multiple Z motors with stall detection exceedingly difficult especially through the extra compliance of the gear box.
It looks like you have a probe configured, why not use that?
@phaedrux thanks for the reply but not an option for this design as i need all the i/o inputs for other things
@moth4017 Let us know how it goes.
I'm also thinking it's going to be tough to do stall detection through a 4:1 gearbox, so if you get it working, please post the details of your settings here.
@alankilian I will post up the files when i have it working, ive been trying to sort this problem out for days now, works on the duet2 ok , but it seems the TMC2209 that seems to be making it more difficult.
My Stepper motor Details
stepper motor XY42STH40-1684A
2.8V
1.68A
1.65 Ohms/Phase
3.2mH/Phase
3.6 g/cm holding torque
54 g/cm ^2 Rotor Inertia
Weight 280g
150 g/cm Detent Torque -
Are you trying to stall it against the print head or the z max end of travel?
@moth4017 said in Duet 3 Mini 5+ sensor less homing setup and tune help required:
But you have a probe defined...
@phaedrux
stalling Z at Max to make sure the Bed is close to level on switch/on before doing the 3 Point tramming etc -
Try higher speeds? There needs to be enough back emf to detect a stall.
@phaedrux Iev tried a few speeds and i did get one of the 3 motors to stall ( this turned out to be a mechanical issue )2 motors went to the physical end stops "skipped steps for 4 seconds" then stopped.
How out of tram do you expect it to become before doing the auto leveling?
If it's bottoming out at the physical stop doesn't that have the same effect?
@phaedrux if the Bed goes to Z max the motors make a horrible noise until they all time out, not very elegant when the Stall feature ( sensorless homing) is exactly what i require .
@moth4017 I am sending z to max to get the bed in a 90% tram position before doing the auto Tram/bed level, the issue i have is that when the power is removed the bed will become out of tram so sending to Z max gets me in the 90% correct position.
Hence the sensor less homing require for Z max with multiple motors. i dont have enough inputs to install 3 extra limit switches .
