    "G28 Error: G0/G1: insufficient axes homed" after months of use
    769
    • ignacmcundefined
      ignacmc
      Hello to all
      Today I was going to print in my Predator Delta (Duet3Mini5+ with optical endstops) but just after start up and connecting to the network, when I try to home the axes, the motors didn't even energize and I got the error "G28 Error: G0/G1 insufficient axis homed". What can it be? I have not touched anything in the wiring or electronics for months, and I have not upgraded the firmware since 3.3.0 release. I have been printing all this time without problems.
      M122
      RepRapFirmware for Duet 3 Mini 5+ version 3.3 (2021-06-15 21:46:11) running on Duet 3 Mini5plus WiFi (standalone mode)
      Board ID: ZBNF5-FV9RL-D65J0-40KM8-1NW2Z-RTPTG
      Used output buffers: 7 of 40 (19 max)
      Static ram: 102724
      Dynamic ram: 105912 of which 24 recycled
      Never used RAM 35044, free system stack 196 words
      Tasks: NETWORK(ready,12.2%,240) HEAT(notifyWait,0.0%,366) Move(notifyWait,0.1%,334) CanReceiv(notifyWait,0.0%,941) CanSender(notifyWait,0.0%,371) CanClock(delaying,0.0%,340) TMC(delaying,0.6%,115) MAIN(running,85.6%,426) IDLE(ready,0.8%,29) AIN(delaying,0.8%,273), total 100.0%
      Owned mutexes: WiFi(NETWORK)
      Last reset 00:00:30 ago, cause: power up
      Last software reset at 2022-01-05 20:50, reason: User, GCodes spinning, available RAM 35044, slot 0
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
      Error status: 0x00
      Aux0 errors 0,0,0
      MCU revision 3, ADC conversions started 30924, completed 30924, timed out 0, errs 0
      Step timer max interval 752
      MCU temperature: min 19.5, current 22.0, max 22.0
      Supply voltage: min 24.1, current 24.2, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 0: position 129195, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 11, reads 1586, writes 11, timeouts 0, DMA errors 0
      Driver 1: position 129195, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 11, reads 1586, writes 11, timeouts 0, DMA errors 0
      Driver 2: position 129195, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 10, reads 1587, writes 10, timeouts 0, DMA errors 0
      Driver 3: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 9, reads 1588, writes 9, timeouts 0, DMA errors 0
      Driver 4: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 9, reads 1588, writes 9, timeouts 0, DMA errors 0
      Driver 5: position 0, assumed not present
      Driver 6: position 0, assumed not present
      Date/time: 2022-01-06 00:18:10
      Cache data hit count 58914266
      Slowest loop: 6.82ms; fastest: 0.12ms
      === Storage ===
      Free file entries: 10
      SD card longest read time 3.2ms, write time 0.0ms, max retries 0
      === MainDDARing ===
      === AuxDDARing ===
      Bed heaters = 0 -1, chamberHeaters = -1 -1
      Heater 1 is on, I-accum = 0.0
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty.
      === Filament sensors ===
      Extruder 0 sensor: ok
      === CAN ===
      Messages queued 274, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 17 (min 17), ts 154/0/0
      Tx timeouts 0,0,153,0,0,119 last cancelled message type 30 dest 127
      === Network ===
      Slowest loop: 13.41ms; fastest: 0.00ms
      HTTP sessions: 1 of 8
      • WiFi -
        Network state is active
        WiFi firmware version 1.26
        WiFi MAC address 8c:aa:b5:f7:d1:82
        WiFi Vcc 3.31, reset reason Power up
        WiFi flash size 2097152, free heap 23360
        WiFi IP address 192.168.1.73
        WiFi signal strength -45dBm, mode 802.11n, reconnections 0, sleep mode modem
        Clock register 00002002
      Predator with Duet3 Mini 5+, Smarteffector v4 and LGX Lite Extruder
      botundefined giostarkundefined jay_s_ukundefined dc42undefined 4 Replies Last reply Reply Quote 0
      • botundefined
        bot @ignacmc
        Did the way you call G28 change at all? There are different macros for G28 X, or Y, or all of them, etc. Maybe one of your macros is not playing nicely with a new slicer start g-code.
        *not actually a robot
        ignacmcundefined 1 Reply Last reply Reply Quote 0
        • ignacmcundefined
          ignacmc @bot
          @bot No, in fact if i just issue G28 from the console, the error appears
          • giostarkundefined
            giostark @ignacmc
            @ignacmc
            If you didn't touch anything (and before was working) it sound as the endstop are not read correctly.
            Try to clean all of them. Look if the red light are operational.
            Have you checked all the endstop? Try a singular independent move to see if all of them work regularly:
            Testing the motors and endstops individually
            https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareDeltaPrinter#Section_Testing_the_motors_and_endstops_individually
            Not related now because you receive the error soon as you try to move, but it could be useful in future: When the head was placed on the extreme part of the bed and try to home is also happened that in the home.g this line had the X Y Z parameters too small and received your same error:
            ; Move all towers to the high end stopping at the endstops (first pass)
            G1 X640 Y640 Z640 F2500 H1
            I'm at shortage of other ideas... hope some more expert can provide more suggestions 😊
              Can you check your endstop state with M119 and post your full config? Also please send M98 P"config.g" for good measure and share the results?
                jay_s_uk @ignacmc
                @ignacmc post your config.g please
                • ignacmcundefined
                  ignacmc @Phaedrux
                  @phaedrux
                  • ignacmcundefined
                    ignacmc @jay_s_uk
                    @jay_s_uk config.g
                    Here you have it...sorry for the verbosity of my comments 😉
                      jay_s_uk @ignacmc
                      @ignacmc nothing i can see if your config file.
                      can you post homedelta?
                      • ignacmcundefined
                        ignacmc @jay_s_uk
                        @jay_s_uk homedelta.g
                          jay_s_uk @ignacmc
                          @ignacmc nothing in there either that would cause issue
                          • ignacmcundefined
                            ignacmc @jay_s_uk
                            @jay_s_uk Yes, I have been printing with these config files for months without issues. I suspect some hardware problem. As I was going to replace my LDO 0.9 motors for OMC equivalents, I will do it and recheck all wiring at the same time...
                              dc42 administrators @ignacmc
                              @ignacmc here's the problem, in your homedelta.g file:
                              G1 X0.01 Y0.01 Z0.01
                              Either add H2 to that line, or replace it by:
                              M17 X Y Z ; enable motors for stealthChop tuning
                              M17 is implemented in RRF 3.3 and later.
                              ignacmcundefined 1 Reply Last reply Reply Quote 2
                              • ignacmcundefined
                                ignacmc @dc42
                                @dc42 David....you are a father to me! It did the trick...
                                Stupid me, I forgot I have made that change a few days ago while researching here how to tune Stealthchop and didn't print since then so I was not aware of the problem I had just created.
                                Today in Spain is the Fairy Kings day, when tradionally Christmas presents arrived. This has been a very nice one!
                                Thanks for your outstanding support!
                                Ignacio
