    12864 command M701 S"nnn"
    473
    • demonlibraundefined
      demonlibra
      Good day.
      Is it possible to add command M701 S"ABS" to menu.
      Tryed to write command:
      button R20 C2 T"LOAD ABS" A"M701 S#0" L"ABS"
      but nothing happened.
        Perhaps it doesn't like the S#0?
          demonlibra
          The command must be
          M701 S"ABS"
          but in configuration menu file I cannot write like this
          button R20 C2 T"LOAD ABS" A"M701 S"ABS""
          Doudble double quote will not working correctly.
          How to write this command correctly?
            dc42 administrators @demonlibra
            @demonlibra try this:
            button R20 C2 T"LOAD ABS" A"M701 S""ABS"""
              demonlibra
              The line can be selected, but no characters are displayed.
              The filament load command does not start.
                Phaedrux Moderator @demonlibra
                @demonlibra said in 12864 command M701 S"nnn":
                A"M701
                Is this missing a " ?
                demonlibraundefined 1 Reply Last reply Reply Quote 0
                  demonlibra @Phaedrux
                  @Phaedrux
                  Sorry, I dont understand
                    @demonlibra Nevermind, I misstook the command.
                    I'm not sure what the problem would be.
                      @phaedrux To use command M701 we must put in double quote name of the filament.
                      But to write line in menu we must put in double quote whole command.
                      Double double quote did not working.
                      Sorry for my english.
                      • rjenkinsgbundefined
                        rjenkinsgb
                        How about making a macro file containing the command, then just call the macro with the button line?
                        Robert J.
                        Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
                        demonlibraundefined 1 Reply Last reply Reply Quote 1
                          demonlibra @rjenkinsgb
                          @rjenkinsgb I am already thinking about it.
                          I will use this option if I don’t find another solution.
                            demonlibra
                            created folder "/menu/filaments"
                            created files pla, abs, petg with content
                            M701 S"PLA"
                            M701 S"ABS"
                            Working fine.
