Solved Printer don't heat after longer in IDLE state 3.4b7+1
I have an issue with firmware RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta7+1 (2021-12-22) when I'm printing one job at a time i have no problem but when the printer stays in idle mode for a longer time I can't heat up the bed / hotend. The only thing which helps is to reset the Printer.
Here you can see the issue in this small video: https://kleinersonnenschein.eu/video/heatingproblem.mp4and in the second video, you can see what's happens when I start a print job:
https://kleinersonnenschein.eu/video/startjob.mp4m122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.0beta7+1 (2021-12-22 18:48:09) running on Duet WiFi 1.02 or later + DueX5 Board ID: 08DGM-95BNL-MGPSJ-6J9FD-3SJ6N-K1W3Y Used output buffers: 3 of 24 (14 max) === RTOS === Static ram: 23804 Dynamic ram: 76772 of which 40 recycled Never used RAM 8008, free system stack 102 words Tasks: NETWORK(ready,35.0%,228) ACCEL(notifyWait,0.0%,348) HEAT(notifyWait,3.0%,311) Move(notifyWait,16.0%,275) DUEX(notifyWait,0.0%,24) MAIN(running,42.5%,440) IDLE(ready,3.5%,30), total 100.0% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 10:18:11 ago, cause: power up Last software reset at 2022-01-06 18:53, reason: User, GCodes spinning, available RAM 8296, slot 0 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x00 Step timer max interval 0 MCU temperature: min 15.0, current 31.2, max 32.2 Supply voltage: min 24.0, current 24.3, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/1204/1204, gc cycles 0 Events: 0 queued, 0 completed Driver 0: pos 31520, standstill, SG min 0 Driver 1: pos -15680, standstill, SG min 0 Driver 2: pos 12447, standstill, SG min 0 Driver 3: pos 0, standstill, SG min 0 Driver 4: pos 0, standstill, SG min 0 Driver 5: pos 0, standstill, SG min n/a Driver 6: pos 0, standstill, SG min 0 Driver 7: pos 0, standstill, SG min n/a Driver 8: pos 0, standstill, SG min n/a Driver 9: pos 0, standstill, SG min n/a Driver 10: pos 0 Driver 11: pos 0 Date/time: 2022-01-07 22:13:59 Cache data hit count 4294967295 Slowest loop: 149.89ms; fastest: 0.11ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 10 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 10.8ms, write time 8.5ms, max retries 0 === Move === DMs created 83, segments created 25, maxWait 32247376ms, bed compensation in use: mesh, comp offset 0.000 === MainDDARing === Scheduled moves 15146, completed 15146, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 12], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 0 is on, I-accum = nan Heater 1 is on, I-accum = nan === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty === Filament sensors === Extruder 0 sensor: ok === DueX === Read count 1, 0.00 reads/min === Network === Slowest loop: 153.15ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions HTTP sessions: 1 of 8 - WiFi - Network state is active WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 0 WiFi firmware version 1.26 WiFi MAC address 2c:3a:e8:0b:06:33 WiFi Vcc 3.44, reset reason Turned on by main processor WiFi flash size 4194304, free heap 22960 WiFi IP address 192.168.188.142 WiFi signal strength -50dBm, mode 802.11n, reconnections 0, sleep mode modem Clock register 00002002 Socket states: 4 0 0 0 0 0 0 0
I was playing around with the accelerometer and my printer suddenly restarted. here is the result of the m122 after the software crash
m122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.0beta7+1 (2021-12-22 18:48:09) running on Duet WiFi 1.02 or later + DueX5 Board ID: 08DGM-95BNL-MGPSJ-6J9FD-3SJ6N-K1W3Y Used output buffers: 3 of 24 (15 max) === RTOS === Static ram: 23804 Dynamic ram: 76708 of which 40 recycled Never used RAM 11528, free system stack 184 words Tasks: NETWORK(ready,10.8%,232) ACCEL(notifyWait,0.0%,348) HEAT(notifyWait,0.0%,336) Move(notifyWait,0.0%,364) DUEX(notifyWait,0.0%,24) MAIN(running,85.1%,442) IDLE(ready,4.1%,30), total 100.0% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 00:00:23 ago, cause: software Last software reset at 2022-01-07 23:54, reason: HeatTaskStuck, GCodes spinning, available RAM 8008, slot 1 Software reset code 0x4143 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f80f BFAR 0xe000ed38 SP 0x200123cc Task ACCE Freestk 324 ok Stack: 0045ce93 0045da14 010f0000 00000000 40900d60 369dc3a0 3edc7360 3331bb4c 40000000 b5ddc655 388ab355 3f000000 3f000000 486c9be0 3f800000 43818000 4354c416 44800000 3f838000 00000000 2000ce3c 20011d70 20011d70 00000001 0045a527 44000000 00434863 Error status: 0x00 Step timer max interval 0 MCU temperature: min 32.0, current 33.1, max 34.7 Supply voltage: min 24.2, current 24.3, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 0/0, heap memory allocated/used/recyclable 0/0/0, gc cycles 0 Events: 0 queued, 0 completed Driver 0: pos 0, standstill, SG min n/a Driver 1: pos 0, standstill, SG min n/a Driver 2: pos 0, standstill, SG min n/a Driver 3: pos 0, standstill, SG min n/a Driver 4: pos 0, standstill, SG min n/a Driver 5: pos 0, standstill, SG min n/a Driver 6: pos 0, standstill, SG min n/a Driver 7: pos 0, standstill, SG min n/a Driver 8: pos 0, standstill, SG min n/a Driver 9: pos 0, standstill, SG min n/a Driver 10: pos 0 Driver 11: pos 0 Date/time: 2022-01-07 23:54:42 Cache data hit count 850927046 Slowest loop: 27.28ms; fastest: 0.19ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 10 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 2.6ms, write time 0.0ms, max retries 0 === Move === DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 1 is on, I-accum = 0.0 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty === Filament sensors === Extruder 0 sensor: ok === DueX === Read count 1, 2.57 reads/min === Network === Slowest loop: 80.81ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions HTTP sessions: 1 of 8 - WiFi - Network state is active WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 0 WiFi firmware version 1.26 WiFi MAC address 2c:3a:e8:0b:06:33 WiFi Vcc 3.44, reset reason Turned on by main processor WiFi flash size 4194304, free heap 23128 WiFi IP address 192.168.188.142 WiFi signal strength -53dBm, mode 802.11n, reconnections 0, sleep mode modem Clock register 00002002 Socket states: 0 0 0 0 0 0 0 0
@SIam Similar problem but mine is on a Duet 3 platform.
@dc42 I can confirm a similar issue. In my case I have a 6HC+3HC+1LC. The only board effected is the 1LC. I am getting the exact same behavior as described above, except that a reset will not solve the problem.
I can check with and M105 and everything will show correct, but my hotend on the 1LC will not heat. I get the same behavior from Beta7, 7+1, and 7+2. I do not see this issue running Beta6.In my case the only way to fix the problem is to use an M303 command to get the heater running above idle. Then I perform a reset and can send the heating commands as usual and everything will work.
With the 1LC heater on and commanded to reach 150C (heater 1):
M105M105 T:19.5 /150.0 T0:19.5 /150.0 B:21.8 /0.0
M122 commands
6HCM122 === Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.4.0beta7+2 (2021-12-30 17:36:30) running on Duet 3 MB6HC v0.6 or 1.0 (standalone mode) Board ID: 08DJM-956L2-G43S4-6J1FD-3SJ6T-TB6QH Used output buffers: 1 of 40 (28 max) === RTOS === Static ram: 150728 Dynamic ram: 97576 of which 20 recycled Never used RAM 98628, free system stack 130 words Tasks: NETWORK(ready,24.5%,229) ETHERNET(notifyWait,0.1%,165) HEAT(notifyWait,0.0%,324) Move(notifyWait,0.0%,248) CanReceiv(notifyWait,0.0%,772) CanSender(notifyWait,0.0%,338) CanClock(delaying,0.0%,339) TMC(notifyWait,7.6%,58) MAIN(running,67.7%,925) IDLE(ready,0.0%,30), total 100.0% Owned mutexes: HTTP(MAIN) === Platform === Last reset 10:28:49 ago, cause: software Last software reset at 2022-01-07 13:17, reason: User, GCodes spinning, available RAM 99708, slot 0 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0044a000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x00 Step timer max interval 148 MCU temperature: min 23.8, current 24.5, max 25.1 Supply voltage: min 24.0, current 24.1, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 12.1, current 12.2, max 12.2, under voltage events: 0 Heap OK, handles allocated/used 99/43, heap memory allocated/used/recyclable 2048/1702/810, gc cycles 4770 Events: 0 queued, 0 completed Driver 0: pos 71120, standstill, SG min n/a, mspos 260, reads 35308, writes 0 timeouts 0 Driver 1: pos -39120, standstill, SG min n/a, mspos 612, reads 35308, writes 0 timeouts 0 Driver 2: pos 14440, standstill, SG min n/a, mspos 120, reads 35307, writes 0 timeouts 0 Driver 3: pos 0, standstill, SG min n/a, mspos 200, reads 35307, writes 0 timeouts 0 Driver 4: pos 0, standstill, SG min n/a, mspos 840, reads 35307, writes 0 timeouts 0 Driver 5: pos 0, standstill, SG min n/a, mspos 776, reads 35308, writes 0 timeouts 0 Date/time: 2022-01-07 23:46:43 Slowest loop: 3.71ms; fastest: 0.07ms === Storage === Free file entries: 9 SD card 0 detected, interface speed: 25.0MBytes/sec SD card longest read time 3.2ms, write time 0.0ms, max retries 0 === Move === DMs created 125, segments created 36, maxWait 0ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 82403, completed 82403, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 0 is on, I-accum = 0.3 Heater 1 is on, I-accum = 0.0 === GCodes === Segments left: 0 Movement lock held by null HTTP is ready with "M122 " in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is doing "G4 P1000 " in state(s) 0 0, running macro Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty === CAN === Messages queued 1743, received 6970, lost 0, boc 0 Longest wait 0ms for reply type 0, peak Tx sync delay 362, free buffers 50 (min 50), ts 968/968/0 Tx timeouts 0,0,0,0,0,0 === Network === Slowest loop: 3.69ms; fastest: 0.02ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions HTTP sessions: 1 of 8 - Ethernet - State: active Error counts: 0 0 1 0 0 Socket states: 5 2 2 2 2 0 0 0
1LC M122
M122 B20 Diagnostics for board 20: Duet TOOL1LC rev 1.1 or later firmware version 3.4.0beta7+1 (2021-12-22 18:45:45) Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1) All averaging filters OK Never used RAM 2540, free system stack 2745 words Tasks: Move(notifyWait,0.0%,99) HEAT(notifyWait,0.4%,93) CanAsync(notifyWait,0.0%,57) CanRecv(notifyWait,0.0%,74) CanClock(notifyWait,0.0%,65) ACCEL(notifyWait,0.0%,61) TMC(notifyWait,3.0%,57) MAIN(running,91.6%,351) IDLE(ready,0.0%,26) AIN(delaying,5.0%,142), total 100.0% Last reset 10:29:35 ago, cause: power up Last software reset time unknown, reason: AssertionFailed, available RAM 3392, slot 0 Software reset code 0x0120 ICSR 0x00000000 SP 0x2000415c Task Freestk 129 bad marker Stack: 00000544 00022ffc 00019b65 20003134 00016cff 20003134 000163d1 20000ed0 00000000 00000001 00008275 200071c8 200071c8 200071e0 00000000 20000f50 00011647 000223b8 00022474 00021ac8 00019b05 200071c8 200071c8 20000f50 000083ed 200071d8 000009c7 Driver 0: pos 778167, 406.0 steps/mm,standstill, SG min 2, read errors 0, write errors 0, ifcnt 13, reads 21326, writes 0, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 0 Moves scheduled 77807, completed 77807, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0 Peak sync jitter 5/16, peak Rx sync delay 213, resyncs 0/0, no step interrupt scheduled VIN voltage: min 24.2, current 24.2, max 24.2 MCU temperature: min 33.7C, current 38.8C, max 67.1C Last sensors broadcast 0x00000004 found 1 15 ticks ago, 0 ordering errs, loop time 0 CAN messages queued 6135, send timeouts 0, received 3971, lost 0, free buffers 37, min 37, error reg 0 dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0 Accelerometer: LIS3DH, status: 00 I2C bus errors 0, naks 0, other errors 0
This is the same error we reported here: https://forum.duet3d.com/topic/26463/bed-heater-stops-working-after-being-idle-for-some-time
For me it is happening on both Duet 2 wifi and Duet 3 Mini 5+; I'm pretty sure it was not always both heaters (Bed & hotend).
I don't remember having the issue on b6. -
Its also happening to me with firmware Beta7+2 using duet3 + 3HC
I just finished one print job, loaded up another, had a cup of coffee and then clicked start.
20 mins later it still wasnt started and the bed was cold yet the print status was in printing state
Same here, after one print is done I can not heat up hotend nor bed (from drop down menu and/or sending M104/M140)
Duet 2 WiFi fw3.4b7
Quite convinced I didn't had this issue with fw3.4b6, to confirm this I've downgraded now and will print a thing or too. Will report back.
Also I'll upgrade my Duet 2 Ethernet tomorrow or so and see if that's the case with Ethernet variant too.
All those of you experiencing this issue, please can you answer the following:
Does this issue only occur after you have done a print and then left the machine idle for some time?
Does it affect the bed heater, the tool heater, or both?
How does your GCode print file end? In particular:
- Does it turn off the bed heater using M140 ?
- Does it turn off the tool heater(s) using M104 ? Or does it set the temperatures low using G10? Or neither?
- Does it use M0 ?
- What (if anything) do you have in your stop.g file?
no, it has happened to me if i have left the printer on for a long time without printing and it has happened after a print if left powered on for a long time before starting a 2nd print
its only affected the bed heater for me
end g-code
M122 ; debug following print
M104 S0
M140 S0
;Retract the filament
G92 E1
G1 E-10 F50
G28 X0 Y320 -
my stop.g
G91 ; relative moves M140 S0 ; turn off bed M106 S0 ; part cooling fan off G1 E-1 F300 ; retract the filament a bit before lifting the nozzle, to release some of the pressure G1 Z+10.0 E-2 ; move Z up a bit and retract filament even more M104 S0 G28 X0 ; move X to min endstops, so the head is out of the way G90 G1 Y300 F2000 M84 ; steppers off M42 P2 S0 ; set heatbed contactor off M300 P300 S4000 ; play beep sound
Also,
I have a macro to turn on off my heatebed contactor, even turning the heatebed contactor off/on with m42 it still will not heat the bed.
i have to power off/on the machine. -
@dc42 said in Printer don't heat after longer in IDLE state 3.4b7+1:
Yes, but I have to say that I don't have tested it without a print this I can do today I will post the result this evening
in my case, Both
G90 ; Switch to relative mode G1 E-5 f3600 ; retrac filamnet G91 ; Switch to absolute mode M104 S0 ; turn off extruder M140 S0 ; turn off bed G91 ; use relative coordinates G1 Z5 F1200 H2; lift nozzle by 5mm G90 ; use absolute coordinates G28 X0 ; home X axis G1 Y195 ; move Y axis to end position M106 P0 S0 ; Bauteilkhler aus M106 P2 S0 ; beleuchtung aus M107 ; turn off fan
Yes
Yes
Does it use M0 ?
No
stop.g is empty
@mikedc M140 S0 and M104 S0 will not turn the heaters off; only change the target temperature to zero. Could it be that this generates a heater fault when it fails to reach that temperature? The release notes mention that earlier versions did set the heaters to the "off"-state after a finished print while the current (beta) version does not if there is a stop.g file present.
- Haven't tried to do next job earlier than 30mins after 1st finished, I'll see if I can spot next print finish to test straight away.
- Both, although I haven't tried cold bed print, always both heaters are on.
- Just M104 and M140 to zero, XY home and M84
- This is fairly new build so it's as generic as it gets out of online configurator.
On the previous post of mine, after downgrade to 3.4.0b6 on Duet 2 WiFI it works fine and 3.4.0b7 Duet 2 Ethernet has the same issue.
Ta
Kris
@dc42 My printer was 9 hours in idle state without a print job and the heating works
Basically, if the temp of the hot end goes below 18C or so. If I remove power for 24+ hours and then fire the machine up it will occur.
Mine just effects my hot end on my 1LC. My bed heater on my 6HC works fine.
Yes to all 3 questions.
4.stop.g
G1 E-3.0 F1500 ; clear extruder G91 G1 Z5.0 F20000 ; move Z from part G90 M104 S0 ; Extruder heater off M140 S0 ; Bed heater off M141 S0 ; Chamber heater off M106 P3 S0 ;turn off lights M106 P2 S0 ;turn off MCU fans M106 P0 S0 ; Turn part fan off M106 P6 S0 ; turn off Nevermore fan M220 S100 ; Set speed factor back to 100% in case it was changed M221 S100 ; Set extrusion factor back to 100% in case it was changed M98 P"/macros/print_scripts/goto_bucket.g" ;go to park position over bucket
I finished a long print around 3 hours ago today and left the printer idle afterwards.
I have just tried another print,
My main contactor does switch on but the bed is not heating.
i cancelled the print and thought i would do a couple of tests.
I can heat the nozzle manually and disable the nozzle heater
I have full control of it from both paneldue and dwcthe bed heater no control on temperature
i can manually turn the contactor on and off both by the paneldue and dwc
i can appear to enable / disable the bed heater
but it just doesnt heat up.Only a full power reset will allow it to work again
@mikedc This is fixed in 3.4.0beta7+4, see https://forum.duet3d.com/topic/26787/unofficial-rrf-3-4-0beta7-2-files.
is this a different b7+2 to what i am on ?
I used b7+2 to fix the z on expansion card issue but i still have this issue with bed not heating up after idle -
@mikedc yes. the latest builds on that thread are now 3.4b7+5
ahh now b7+4 thankyou :)))I will install after my print has finished
@dc42 It looks good ! Thanks for fixing this issue
for me, b7+4 don't resolve problem
@bastien New version have been published since b7+4, I believe the last one is +7
I don't remember having this error lately.You should be able to download b7+7 from here:
https://forum.duet3d.com/topic/26787/unofficial-rrf-3-4-0beta7-4-files/17?_=1642785164011
Need to scroll to get the link.
