Precision Piezo z probes guide for duet users reference
@en_passant
Try swapping the wires from the Piezo Sensor to the Piezo motherboard.If the Piezo triggers on press, its correct, but if it triggers on release try swapping the sensor wires and see if that fixes it.
@BlueDust I have an Orion V2. It doesn't have any wires?
It came with the disc pre-connected to the board. That certainly does sound like my symptom (video here) but the I have checked the wiring and it is 100% correct (I'm confident, as it's only 3 wires) from the piezoPCB to the duet probe connector.
So it behaves great with a (very light) tap from my finger... but when I run my homeall... nope!
My homeall, for reference:
G91 ; relative co-ords (from last position, not origin)
G1 Z10 F500 H1 ; z 10mm @ 500mm/min (ensure it's below probe trigger height)
G1 X-500 Y-500 F3000 H1 ; x & y -500mm [relative] (> max) @3000mm/min - until limit sw. detects
G1 X-500 H1 ; x -500mm [relative] (> max) @ 3000mm/min - until limit sw. detects
G1 Y-500 H1 ; y -500mm [relative] (> max) @ 3000mm/min - until limit sw. detects
G1 X5 Y5 F500 ; x & y 5mm @ 500mm/min
G1 X-10 H1 ; x -10mm @ 500mm/min - until limit sw. detects
G1 Y-10 H1 ; y -10mm @ 500mm/min - until limit sw. detects
G90 ; absolute co-ords (relative to origin)
G1 X172.5 Y172.5 F15000 ; x & y 172.5mm [absolute] @ 15000mm/min
G1 X177.5 Y177.5 F1000 ; x & y 177.5mm [absolute] (bed-centre) @ 1000mm/min
G30 ; raise bed until probe triggered & set z to trigger height
G1 Z300 F1000 H1 ; z 300mm @ 1000mm/min
G1 Z100 F150 H3 ; z 100mm (> max) @ 150mm/min [until endstop] & set temporary z max (until power-cycled)
G1 X-172.5 Y-172.5 F15000 H1 ; x & y -172.5mm [relative] @ 15000mm/min
G1 X-50 Y-50 F1000 H1 ; x & y -50mm [relative] (> max) @1000mm/min - until limit sw. detects
G1 X-50 H1 ; x -50mm (> max) @ 1000mm/min - until limit sw. detects
G1 Y-50 H1 ; y -50mm (> max) @ 1000mm/min - until limit sw. detects
G90 ; absolute co-ords (relative to origin)Also, the relevant parts of my config:
M558 P8 I1 R0.4 F800 T15000 H5 ; probe type, inverted (active high), 0.4s recovery (travel stop to probe dive), 800mm/min probing speed, 15000mm/min travel between probes, 5mm dive height
G31 X0 Y0 Z-0.1 P500 ; x,y,z probe offset from nozzle, probe thresholdM201 X2000 Y2000 Z100 E4000 ; accelerations (mm/s^2)
M203 X33000 Y33000 Z1000 E10000 ; max speeds (mm/min)
M566 X600 Y600 Z40 E950 ; max jerk speeds (mm/min)I have reduced my z settings for M201, M203 & M566 to try to help with this but still the same!
e_p
@en_passant for the same exact problem I removed the PP from my printer and returned bltouch but I can give you few pointers on what I did to make it work so far (I just gave up finally as don't have nervez to fiddle with it every time I change something on the x-carriage)...
use analog output, your pp supports it, the digital one is impossible to setup properly (you have to connect the analog signal to zprobe input)
after a lot of fiddling I hooked the scope to the wires, lot of garbage, feed the gnd+analog-signal to the zmin,gnd connector on the duet using coax cable, I ended up using some high end rf cable but a simple coaxial microphone cable or balanced audio cable or something like that will get the job done. With coax cable you get lot of noise down
if you have a heat break fan attached on the heatbreak (like on E3D V6 for e.g. ) very good idea is to attach that fan to a controllable fan output port on the duet and have that fan shut down when you do Z-probing. Slight imbalance of the fan's propeller will increase noise on the PP a lot. I personally have that fan configured to run only if nozzle temp is greater than 35C and probing cold solves that issue
use RRF3 and dynamic code so for e.g. my homez.g looks like this:
G90 G0 X0Y0 F3000 ; wait 3sec for the probe to "stabilize" G4S3 ; configure the probe treshold to "now+3" G31 P{sensors.probes[0].value[0] + 3} ; probe the point G30
"very light tap from your finger" is "fast", PP need a "fast change" in order to react, when your board "sneak slowly" it does not trigger
while orion should be very sensitive, it kinda isn't so you need to tweak it out a bit. The 4 screws holding the orion in sandwitch between top and bottom .. you need to get them loose. I fingertighten them and then loose all four 1/4 of the circle, test the probe, loose again 1/4 circle, test probe ... and that till it's loose enough to properly trigger.
When you look on the scope how the signal on the analog output looks like, it goes down and then up so to properly trigger you want to configure your probe inverted (the ! in front of zprobe.in) and this "dip" will actually be "jump" that way.
M558 P1 C"!zprobe.in" R2 H6 F2400 T3600 A4 S0.03 K0 G31 X0 Y0 Z-0.1 P250
The "step 6" is what you need to do every time you reassemble the darn thing and is why I gave up and went with easier solution as with orion I was getting even worse repeatability than with bltouch and last time I had to reassemble everything 2 hours of fiddling with screws were just too much
there's btw a part that supposedly work better, it adds 4 o-rings. Have not tried but if you can get the o-rings might worth the try.
https://www.thingiverse.com/thing:3122283
Forgot one more thing, the top part, make sure you drill those holes so that screws can slide through them easily. The screws need to be biting only the bottom part, they need to be able to slide easily through the top part. Ideally, you should use screws that are threaded only at the bottom
@BlueDust said in Precision Piezo z probes guide for duet users reference:
@en_passant
I feel like I'm endlessly trying to get my underbed piezo's work. I'm using the Precision Piezo – Piezo Z-Probe Universal Kit V2.75
I'm using analog settings and have my bed setup in such a way that the piezo is supported along the edged and another part presses into the center.
It worked okay before, I have tuned them to be as sensitive as I can get them, when I read the comment about reversing polarity of the discs I was intrigued and it appeared that my discs would also only get a signal upon release and not upon depression of the bed.
So I turned around the wires for the discs and it actually made it way worse. Now the nozzle has just been pushing into the bed so hard that it deformed and damaged my printing surface.
Reversing the polarity again back to how I think it should be, the probing works a lot better but still it tends to push hard into the bed, just not as hard as to damage the surface.
There once was a time where my setup worked better, having a near-hair trigger. I would like to find that again.
Are there other things I can try such as tuning the dive speed for each probe? I have seen some people use this underbed piezo setup with great success and it looks like their probing scheme moves much faster than mine. I'm thinking a faster dive speed might also help with getting better readings.
These are my current settings:
M558 P5 R1 C"!probe" H2 F3000 T6000 B1 ; set Z probe type to effector and the dive height + speeds G31 P100 X0 Y0 Z-0.216 S0
I also find it hard to get an exact adjustment on VR2, it's either triggered by me tapping the frame and only a fraction of a turn, and it barely registers tapping on the bed.
Update:
Just wanted to add that I have been tuning the feedrates for probing a bit and raising the speeds have helped make it more precise.This is what I got now:
https://youtube.com/shorts/eEXjATJ_640The only issue being that the machine doesn't seem to print perfect first layers across the bed. Would a Delta printer require a mesh from G29? The bed is perfectly flat (alu bed), even when heated.
I'm thinking any typenof distortion is still caused by the auto calibration despite consistently hitting sub 0.03 deviation as can be seen in the video.
